Sponsors    Biodiesel and SVO Forums Home    Forums  Hop To Forum Categories  Straight Vegetable Oil (SVO) as fuel  Hop To Forums  General SVO Discussion    Teach to solve car software system failure
Often car maintenance, always concerned about, even if you can best maintenance program, a couple of years large numbers of owners still will obviously feel the car driving performance and efficiency is constantly declining, but ...... I do not know what the reason is? For example: automotive electronics systems will result in the loss of old cars more fuel, throttle flow, ignition efficiency is not high, poor transmission, lack of motivation, etc. These indeed affect the whole body of small problems related to the car related circuitry, and eventually can not solve the problem. Many are old friends car when facing this kind of a bunch of small problems, electrical problems seem small car will make a series of problems arise?
These questions and phenomena can be referred to as "soft fault car." According to statistics, more than 60 percent of car body parts and mechanical systems require the direct or indirect use of electricity before they can work. The use and development of modern automotive electronics technology is more and more use of electronic control components, Audi Ignition Coil. In particular the use of electronic sensors, can be classified as to measure temperature, pressure, flow, position, gas concentration, velocity, brightness, humidity sensors dry function, distance, they perform their duties, if a sensor fails, the corresponding the device components will not even work properly. The use of a wide variety of electronic components, electrical equipment, making the car's features increased automation of the process is also a lot of growing up, but the corresponding soft fault on these systems has also increased.
If you want to effectively resolve these problems, he will need a more comprehensive understanding and awareness of automotive electrical systems maintenance, electronic components. Minimize the workload of these devices, delay aging on their loss and electrical systems, as soon as possible with a car power protection device with Toyota Crankshaft can effectively prevent and resolve soft fault systems on these circuits.
Automotive power protection systems do improve the circuit from the car, the car stable supply of electric power system protection, improve the efficiency of the car all the electronics and electrical equipment, appliances significantly extend the life of the car electronic parts, auto electrical systems concern problem, while also concerned about the quality of the car's intake air mass and gasoline, if the state of the car's mechanical system is good, and that the efficiency of automobile ring shadow aspect is the largest of the three; electricity, air and gasoline, and jet fuel can combustion, will not waste fuel, underpowered, engine efficiency is not high. Car performance race parts degradation because of incomplete combustion caused by lifting the car and fuel, electricity and air these three software systems. Can effectively solve and prevent these problems soft faults.
Recommend blog http://enginesrod.exblog.jp/
Registered: September 18, 2014Reply With QuoteReport This Post
