Home
Forums
General SVO Discussion
Good Source for non-gear hose clamps? The type that don't mar hoses?|
I've bought many from Napa Auto Parts but they're like $1.50ea. I've decided to use these exclusively from now on and was hoping to find a less expensive source. please post links!
Here's what I'm looking for: http://www.mcmaster.com/#53175k82/=3l2i5l ------ 2001 Ford Excursion 7.3l PSD 1984 Ford F-250 6.9l IDI Conceptually identical Home Brewed WVO Conversions w/ completely parallel fuel systems. Over 18,000 miles on WVO. http://www.boulderveggieoil.com |
Sweeet! McMaster would seem to be making a killing... ------ 2001 Ford Excursion 7.3l PSD 1984 Ford F-250 6.9l IDI Conceptually identical Home Brewed WVO Conversions w/ completely parallel fuel systems. Over 18,000 miles on WVO. http://www.boulderveggieoil.com |
These are called fuel hose style clamps.
All the clamps in my Mercedes for every hose came in this style, or the worm gear style that has depressions as groves on the band but not slats cut right through the band.. I think you know what I mean. Anyway, both are excellent at not cutting rubber. So maybe if you ever come across a wrecked Benz take every hose clamp off it you can find. Probably as good as the day they were put on... Regards, Scott 1987 Mercedes 300D - 2 tank VO |
Good advice! But since the clamps at the site suggested are $.50ea I ordered 50 ------ 2001 Ford Excursion 7.3l PSD 1984 Ford F-250 6.9l IDI Conceptually identical Home Brewed WVO Conversions w/ completely parallel fuel systems. Over 18,000 miles on WVO. http://www.boulderveggieoil.com |
Yup great prices BUT there is a $25 minimum.
______________________________________ '97 Ford F-350 7.3L PSD - Plant Drive kit '84 Mercedes Euro 300D NA - Custom two-tank Running on vegoil and biodiesel since May 2006 |
The pvc shrink wrap tubing is very cheap too - I had no trouble assembling an order
Cool
I like to get rid of the hose clamps and just use push lock fittings No Hose clamp required. My local ACE Hardware store carries them. If you design from the begining and do not buy barb fitting it is not even that much more money. A flare fitting and a push lock in fuel hose sizes is about $5 for both. Then never leak and are easy to disconnect.
Robert In Fort Lauderdale running a 1985 Gold Mercedes 300d custom aluminum tank (18) gallons looped return with return to diesel tank. HOH wraped filter FPHE. Greasecar valves. |
I guess I don't understand how a push lock fitting could keep a hose on. Does the little ring get forced over the OD of the hose to secure it?
http://fittingsandadapters.com/pushosbar.html
push-lok fittings JIC, AN, etc...go to thread #5 http://www.frybrid.com/forum/showthread.php?t=13562 |
Actually the grove on the barb are canted and the hose goes on tight it digs into the hose in order to remove the hose you have to cut it with a razor knife get it off.
On my Cummins truck I was blowing holes in the fuel lines usually around the hose clamp especially on long trips then I switched to Gate LOL fuel line that works exceptionally well with pushlock fittings (LockOnLine)? I changed them all but two. I develop a leak around the Veg-therm where one of the hose clamps was and I removed the veg-therm and all of the hose clamps and never had a leak again. Push-lock are really great as attachments for the fuel filter. You can just disconnect them remove the filter and reinstall easily. If you order them from the above post they are even cheap! Robert In Fort Lauderdale running a 1985 Gold Mercedes 300d custom aluminum tank (18) gallons looped return with return to diesel tank. HOH wraped filter FPHE. Greasecar valves. |
So what is your experience using these Push-Lok fittings on non-push-lok hose? I use mostly Gates 3/8" SAE 30r9 and some 30r7 hose in my installations...
I've used these fittings on my track car fuel injection feed - I run upwards of 60 psi on 3/8" ID line. They have been dry and solid for 5 years now, no issues.
They work especially well on gates hoses. You would have to cut them off to remove the hose. I can make a pretty good bet if you use the right size hose and fitting they will not come off without a knife or cutters or a torch.
Home
Forums
