See this page from a typical, basic, diesel manual. Like most diesel manuals it says "Excess fuel...cools and lubricates the injection pump and nozzles".
For companies that make fuel COOLERS, see Kuhler's web page, or Hydro web page. I have some Bosch tchnical manuals at home, in addition to the SAE Fuels and Lubricants Manual from a few years ago that also describe fuel temperature limitations and Injector pump temperature management. I'll post their recommendations when I have time. I have not seen a specific temperature listed that will cause damage to an injector pump. There may be a recommended temperature range given in one of the Bosch books. I seem to recall that the Bosch books list specific ranges of viscosities that the IP's are designed for. Cheers, JohnO |
Thanks for the discussion guys- I'm going to replace the fphe and see how it goes- hopefully with diesel backflush on shutdown I won't gum it up. Other than that I can't think of anything else- the VO is good/no water and everything else seems 100%. I'll ketp the closed loop T return between the fphe and VO filter so I don't backflush my filter on shutdown.
Thanks again '03 jetta TDI wagon greasecar kit conversion HotFox pickup HOH FPHE/vegtherm std zerostart coolant heater |
Thanks for the heads up, I have never heard of such a product until now.
96 Dodge 4x4,5sp, not stock |
In normal use in unconverted engines diesel isn't passed through a high temp fuel heater or coolant/fuel heat exchanger. It's lubricity is not therefore lowered and no fuel cooler is needed. However there ARE quite a few diesel fuel additives that are designed to provide additional lubricity to diesel fuel. These are available mainly for those who believe that the ambent temps are high enough to justify the extra protection. Dana दान danalinscott@yahoo.com http://vegoilconversions.netfirms.com/ VegOil Conversions by Dana Linscott- VO Conversion Consultation for large and small trucks, VO fuel related businesses, and co-generation(power/heat)projects, |
A friend tried a variety of different things to dissolve sticky goo in his fuel system, eventually finding that CRC carburetor spray cleaner worked best. It's most acive ingredient appears to be toluene. It might be work a "shot".
Cheers, JohnO |
Johno, please clarify, was that CRC carb cleaner that cleaned up sticky diesel goo or sticky WVO goo?
S. Caxambu |
The original source for the goo wasn't certain, but was strongly suspected to have been a "bad" tank of purchased "commercial" biodiesel, not "diesel goo", but closely related to "SVO goo". It took a couple months to clear up, trying all sorts of things to dissolve the remains. The tank was eventually cleaned with and an assortment of hot water, detergents and solvents, leaving the fuel lines to be cleaned with whatever worked best. That turned out to be the CRC spray Carburetor cleaner.
I haven't tried it on polymerized SVO residue, yet. Cheers, JohnO |
Do you know what the process was? Did fill the fuel lines w/ the carb cleaner, let it sit a few days, then blow them out with compressed air?
S. Caxambu |
He stuck the little spray tube in one end of the fuel line and just sprayed it on through until it was clean. It worked pretty much instantly as I understood his description.
Cheers, JohnO |
choke off your radiator with a radiator block controlled by a cable in the cab until everything is up to op. temps. insulate all your heated VO components then add additional shielding to protect form airflow. engine compartments are a multi-directional wind tunnel. 80's NA VWs & NA and turbo Benzes, '91 E350 7.3 IDI NA various bicycles with trailers and gearing low enough to ride up a cliff ;-) |
