Sponsors    Home    Forums  Hop To Forum Categories  General SVO Discussion    Chevy 6.5 TD Lift Pump Question
Page 1 2 3
Hello All,
I am not a newbee but I think this is my first post! I have been running on WVO for ~3 years in my 93 truck and ~5 years in my MB 240D. I built the truck kit from scratch. The coolant heated kit consists of; a heated aluminum tank, Hose in Hose,(pex tube), 6 port and 3 port valves and a copper coil heated Racor Filter. I also added a Carter lift pump before the IP after the 6 port. So, in short it is not back at the tank. I switch off the diesel lift pump and switch on the grease lift pump (carter) to switch to veggy. Anyway, during a routine inspection I determined that the Carter pump is dead. From reading I gather that I could have been driving a long time like this taxing the IP. Bummer! I am not on diesel and the 150 buck fill up has modivated me! Question: Is the lift pump in the correct location? If it needs to be back at the tank I need to re-configure my hose-in-hose. Is the Carter pump the recommended pump? From ready threads it seems to be up on the Holly Blue. Thanks in advance for any help!
Registered: 20 March 2005Reply With QuoteEdit or Delete MessageReport This Post
I use a Carter at the tank, and a Walbro 6065(new model # is FRB-5) in the engine bay. I JUST ordered 5 of the Walbro pumps as a group buy, they are supposed to work well on veggie but I haven't tried one yet. The old 6065 is working well, though. Not sure on the Holley pump.
B.K Hosken,
You use TWO pumps before the IP! Wow! Do they operate off the same switch? Are the the samePSI? I have a Hose-in-Hose (HIH) system coming from my tank, so ...in order to put a pump there I would need to seperate the coolant and grease, put the grease through the pump and then connect back into the HIH set up. Hmmm... maybe just make two fittings into and out of tank and then into the HIH? How much was the Walbro? I will read up on them. Have you heard anything about them on this forum? Thanks for the help! Chris
B.K. Hosken,
Thanks for the tip. I read up on the Walbro FRB-5. Are you sure that the pressure rating is good for the Suburban? I thought the system was designed for a 4-7 PSI? The FRB-5 is rated for 8-11 PSI. I will investigate more. If this is what I want, are you interested in selling any of the 5? Thanks, Chris
I've got the Walbro FRB-5 pump on my 7.3 IDI which is alot like your engine. I've been really happy with mine. It runs both the Diesel and WVO system and when on veggy it pull through a racor filter and the factory 6 port switch.
Location: Asheville, NC | Registered: 15 April 2005Reply With QuoteEdit or Delete MessageReport This Post
I do switch both pumps at the same time, on the same switch (relay). The FRB-5 is rated for 8-11, but pumping thicker WVO I figure it's going to slow a little. I think the Carter is about a 10 psi, and that's what I think the stock pump is rated, too.
This message has been edited. Last edited by: B.K. Hosken,
Guys,
OK I am giong to get a FRB-5. I just bought a cheapy at Auto Zone today that is rated at 4-7 PSI. It only costs 30 bucks and I will safe that in diesel in 3 days. B.K. can you shoot me some picks of your system and a schematic? I am thinking about my current system in my 1993 6.5 TD truck and how I can improve it. Also I know I have to cool the PMD in the 1999. How do you cool yours? Also, I think a lift pump at the tank is a good idea. I have to make a tank that fits under the Suburban, where is yours mounted.
Chris
I didn't have a schematic when I started mine...still don't. If you want an FRB-5, you can get in on the next group purchase, I got in 5 and will be mailing them out tomorrow, but I can order another batch, since I forgot to get myself one!
I put in hose on hose 5/8" heater hose to the tank and back. I have a 16 plate FPHE epoxied to the front of the tank, the Carter pumps from there thru 3/8" aluminum fuel line to the engine bay, there it hits the Walbro pump and a 26 plate FPHE, then thru a Permacool filter (2 micron, $40) with a 5/8" heater hose wrap, then T's into the IP feed line. I only have one valve, and it's for the return. The whole thing is controlled by a VOControl controller, fully automated.
I bought the HeathDiesel new PMD, relocator kit and heat sink, pricey at $500 but guaranteed for 7 years.
My tank is mounted underneath along the frame rail on the driver's side, here's a pic of it from the front outside, you can see the edge of the body/door.
Shot of the engine area, filter and wrap, right near it is the 26 plate FPHE wrapped in silver insulation.
B.K.
What is the price on the FRB-5's? I would like to get 2 if we can get the order rolling soon. Do you think ordering a back up is necessary? How about having two of them on one system? One near the tank, the other just after the input valve but before my FPHE. I have a FPHE but have yet to install it! I also like the veg-therm. My MB has a veg-therm just before the IP. I appreciate the pics! What size tank is that?
I think the FRB-5 is good enough to go by itself, but I have not played with them too much. I have gotten 2 others wanting a pump, so i will give it another week and make another order. They will be $82 each if you mail the money, or $85 by Paypal. I didn't quite break even on the last order, so I have to bump up the price a little.
what would it cost with shipping to central NY 13326
Flyboyd8, Central NY
93 f250, 7.3 N/A, ext cab, >103K+ on veg (5-06 DIY conversion) FASS HDPP on Veg, Facet 59SV for diesel. 100 Gal. veg tank :-) >283K total. Three winters on veg with DIY system. converted. in 5-06, "NO Fancy Gizmo's", it came stock with all the power I need. Long Live the IDI!!!
Join the NRA today! Freedom was never free! thank a Vet!!
Location: At the flying field, or my 1000 yard. range | Registered: 05 April 2007Reply With QuoteEdit or Delete MessageReport This Post
The price above includes shipping to you in the lower 48.
Hey, could I get one on this order, too??
I have a stock lift pump (one each side) on both the Diesel and WVO circuits -- and have never felt like the stock design was quite robust enough for the WVO. I'd love to get in on this order, if possible...
Drizzle
________________
'99 Suburban 2500 -- Heath remote PMD, PlantDrive kit with: HotFox (in stock 42gal tank for WVO), 16-plate FPHE (winter was proving a bit tough on my WVO filter, given that it's only head-heated), VorMax 2-stage filter, Stock-style lift pump dedicated to WVO (heavier duty version from Heath Diesel), 2nd 16-plate FPHE, VegTherm Mega, Pollak 6-port motor-driven valve, looped return on WVO.
Over 40,000 miles on WVO and RUNNING GREAT! :-)
See more here: http://www.dieselplace.com/for...e.php?do=view&g=3908
Location: Greensboro, NC | Registered: 16 September 2005Reply With QuoteEdit or Delete MessageReport This Post
Anyone who wants to get in on the next purchase, I will wait a week before i order. Please paypal, or send me a PM and I will tell you where to send a check.
Should I PayPal the $85 to the e-mail addy (yahoo) in your profile?
(An aside: your profile states you are a radio tech in the AF -- I was a weather tech in the AF 20 years ago... Cool )
________________
Yes, use the @yahoo.com address for Paypal.
Done.
________________
Walbro 6065
Will the Walbro allow the fuel to flow even if it dies? Drizzle, nice truck. I have a 99 also running Bio.
Cheers
A
Location: Dayton, VA | Registered: 25 January 2006Reply With QuoteEdit or Delete MessageReport This Post
The Walbro FRB5 will flow through when off. When purchasing these, make sure you get the 420 mic intake screen, the one that comes in the pump is too fine and will clog very quickly. The 420 mic screen is the coursest offered and still meets warranty requirements. also know that these pumps are pretty loud, mounting them on rubber (and running separate ground) may help.
They are a very good quality pump though, seem pretty much indestructable, I just wished they maintained PSI a little better. Expect around 5PSI w/ your 6.5
300TD
Samurai
Veggen
WVO shop heat
Location: Randolph, VT | Registered: 30 October 2003Reply With QuoteEdit or Delete MessageReport This Post
