here is a picture of what i have done, nothing special but effective. filtered a smaller batch and no or not visible with my eye any suspended wanter.
just in case i am doing something wrong on the hotpan test. i heat a skillet to about 350F and add the oil - naturally the temp will drop after the oil is emptied so i allow the temp to increase again an no visible boubles at all this time. CF was filtering the oil at 194F when i did the test and filtered for 9 hours total. did not raise the pressure past 80 psi in the process. any comments? Jetta 96 1.9TD coverted SOLD Jetta 2002 slowly installing frybrid kit Jetta 2006 chipped, Bilstein Sport, Neuspeed Sport Springs, Neuspeed endlinks, DG SS, Evolution skid plate, Eibach RSB, 18" RS4 wheels IMG_1114.jpg (161 Kb, 243 downloads) |
evangelos - That fitting looks like a pipe to flare fitting adapter .
This message has been edited. Last edited by: rkpatt, 1994 F250 IDI 7.3 NA E4OD |
It really does. Dave at IDP who sells the Centrifuge (the number was given earlier in the post), told me this was a British Pipe Thread to USA conversion. I don't know... We'll see. I think their is not much of a difference. USA pipe thread has one less thread per inch as I can tell.
87 MB 300d Turbo 84 GMC 6.2 Diesel Suburban 84 MB 300d TurboDiesel |
How are folks sealing the water heaters into the pipe?
I've got teflon added thread compound (pipe dope), but I want to only do this once. I don't want leaks. Any suggestions? 87 MB 300d Turbo 84 GMC 6.2 Diesel Suburban 84 MB 300d TurboDiesel |
i started with dope but later had to add teflon tape and no problems ever since.
i can remove the coupling and take another picture later on. evan Jetta 96 1.9TD coverted SOLD Jetta 2002 slowly installing frybrid kit Jetta 2006 chipped, Bilstein Sport, Neuspeed Sport Springs, Neuspeed endlinks, DG SS, Evolution skid plate, Eibach RSB, 18" RS4 wheels |
member 2008 Sponsor |
I must correct something I said earlier. I stated that I did not receive the adapter with my Spin Clean. That was incorrect I did in fact.
However: This is what I ordered from mcmaster: 5832T122 (Same as 5832T2) BSPT-to-NPT Std-Wall Brass Thrd Pipe Nipple 1/4" Pipe Sz, 1-1/2" L, Threaded Both Ends, Sch 40 British pipe thread for the CF, npt for our pipes, and it works perfectly. And McMaster had it to me the day after I ordered it. This message has been edited. Last edited by: Muleears, Muleears Hampton Roads, VA USA 87 MB 300D Turbo, 340K mi. WVO Blend 98 E300 Turbodiesel 188K mi. 2 tanked Greasecar+FPHE Very tolerant wife |
evangelos - Is that hose in your photo a few posts up an off the shelf plumbing connector hose or did you get it from a hydraulic supply house ? - Thanks
It almost looks like a standard water facuet/dishwasher hose in stainless steel braid.
Elvia the HandyMan 2000 f350 XL utility/service truck Vegistroke V3 |
its standard hose 1/4 npt, i brought the CF to the plumbing shop and that was it. this also reminds me of the time when first made the firts big order on the fphe's. they were supposed to come with british threads and Dana retapped his in order to for the npt's to fit but i did not have that problem. i was able to tighten the npt fitting to 2 full turns and no leaks. maybe i am so eager to get things happening that i dont play close attention to the FULL scope of the matter. even if it leaks one day i only filter every 3 - 4 weeks so a drop hear and there wont make a difference to me; the oil is only going to go back in the drum anyway!! btw, it really, really hard to find anything past the standard here in Montreal ; this plumbing place is the only place i have seen to have liquid filled psi gauges, i could not find adjustable relief valves actually thats a lie the one shop that had wanted close to $100 for ONE so had to get one off of ebay. did i mention my oil is super dry. so worth the money and so easy to setup its a joke. hope this helps. Jetta 96 1.9TD coverted SOLD Jetta 2002 slowly installing frybrid kit Jetta 2006 chipped, Bilstein Sport, Neuspeed Sport Springs, Neuspeed endlinks, DG SS, Evolution skid plate, Eibach RSB, 18" RS4 wheels |
I am a little confused on the price - how much with the valve ? how much without the valve ?. Also anyone know what the price is for the next model up ( ff60 )? - Thanks
i have tried to contact the guyes that are making the "simple centrifuge" but with out luck. Are the company still active?
I need a bowl so that i can make a centrifuge for my small PPO plant. (sorry for the bad spelling) All the best. Theis |
mr. turbine, are you in Denmark?
Do you want a centrifuge? I got CF for sale, pm me if you r interested. I am in South Sweden |
What going on with you guys and your spin cleans? No one has posted here in a while, how about an update.
I am having difficulty finding the parts to connect my pump (Oberdorfer 991R) to my motor (AO Smith 1/3hp carbonator). The pump has a recessed shaft. I am ordering the adapter kit as soon as I find a source but I think that will only allow me to mount the pump on the motor, it will not connect the shafts. How have you all done this? Both the output shaft of the motor, and the input shaft of the pump have a large notch cut in the end. I have been to lovejoy and have not found a coupling that looks like it would work. Will the carbonator motor not work with this pump? Help! I want to get my spin clean going!
Just curious, has anyone yet tried using an automotive oil pump , like the $15 GM small block V8 Melling M-55 (with the bypass plunger locked down) coupled to to 1/3 or 1/2 hp motor ) to run their Dieselcraft / Spinclean rig ? It would seep a little around the shaft but it could be mounted over the barrel .
(I use one of those pumps connected to drill for a transfer pump - http://biodiesel.infopop.cc/eve/forums/a/tpc/f/919605551/m/8091082281/p/2) and http://biodiesel.infopop.cc/eve/forums/a/tpc/f/91960555...7608061/r/7851085351) 1994 F250 IDI 7.3 NA E4OD |
Carbonator motors need a special coupler, here is some on ebay for $5 Hopefully your pump is designed for that same size coupler. My oberdorfer 991 uses a lovejoy coupling on a shaft so couldn't be used with a carbonator motor, yours sounds different. YVORMV - Your veg. oil results may vary, see www.burnveg.com/forum 95 Dodge Cummins 4x4 +87 300TD wagon Running on 2 tank WVO, 81 Mercedes 300D on V80/D20 blend Low fossil house- 100% solar/wind power, 90% solar heated. |
I just got my rig set up and running. What a job it was to get done too. I bought a feeder funnel and welded it to the bottom of a 55 gal drum, all my piping is rigid piping, no hoses. I tried using a flat heating element, which I welded to a 1-1/4 to 1" bushing and screwed it into a 1-1/4 tee, its leaking a bit, I will have to do some touch up welds on it.
I am running my first batch right now, I can hear my rig hum from inside the house. I will get some pictures up soon. what are people using for transfer pumps? I got one of the harbor frieght 1" water pumps to try, but I have had no luck with it so far. |
is just under 200usd Jetta 96 1.9TD coverted SOLD Jetta 2002 slowly installing frybrid kit Jetta 2006 chipped, Bilstein Sport, Neuspeed Sport Springs, Neuspeed endlinks, DG SS, Evolution skid plate, Eibach RSB, 18" RS4 wheels |
Since I posted that previous message , I recently requested a quote from them and it looks like the price went up from $ 170 USD shipped . They quoted : FF25LE (no valve) - $185 , FF60LE (no valve) - $ 299 , + $10 shipping . At this point I would buy a Dieselcraft OC20 instead of the FF25 because it has the valve and Dieselcraft's proven customer service to folks here . The FF60LE still seems like good deal for the price .
| Previous Topic | Next Topic | powered by eve community | Page 1 ... 10 11 12 13 14 15 16 ... 41 |
