Sponsors    Biodiesel & SVO Home    Biodiesel & SVO Forums  Hop To Forum Categories  General SVO Discussion    Spin Clean centrifuge
Page 1 ... 9 10 11 12 13 14 15 ... 41
Can you deadhead a gear pump? My guess is not. Anyone got the answer?
Muleears
Hampton Roads, VA USA
87 MB 300D Turbo, 340K mi. WVO Blend
98 E300 Turbodiesel 188K mi.
2 tanked Greasecar+FPHE
Very tolerant wife
You can if it has an internal pressure relief.
Registered: 01 April 2003Reply With QuoteEdit or Delete MessageReport This Post
Mine (Spin Clean), has a bolt opposite the intake but no valve inside the bolt. I got it for that price because it did not have the low pressure valve. According to Dave at Spin Clean.
on page 3 the valve is shown with a sping and the rest of the parts. if you have the parts you have the valve. its designed to openup at 20psi, but if you payed $30 less then that is quite the savings. i guess the valve is there for automotive purposes and rightly so.
Jetta 96 1.9TD coverted SOLD
Jetta 2002 slowly installing frybrid kit Frown
Jetta 2006 chipped, Bilstein Sport, Neuspeed Sport Springs, Neuspeed endlinks, DG SS, Evolution skid plate, Eibach RSB, 18" RS4 wheels
just finished my first cf clean and there was next to no bouble when the skillet heat was between 350f - 365f.
started the CF at 120F, 80psi, filtered for about 6 hours and the temp had reached 180F.
evangelos- Did you get this problem resolved ( manufacturering defect ?) ? . I am getting close r buying a Spin Clean or Dieselcraft unit . I would like to save some money but want make sure that I am buying the best quality unit.
Originally posted by evangelos:
SpinClean or ANN+HUMMEL SG centrifuge??
http://www.mann-hummel.com.sg/EN/centrifugal/fm025.html
when i first send David am email replied that the filter came from the UK so this can very well be a German product.
perhaps mine came with a crack that was not noticed during production??
hopefully i will get word this week.
1994 F250 IDI 7.3 NA E4OD
Posted 16 September 2007 08:21 AM Hide Post
hi pat,
the defect was confirmed from the UK and the canadian source sent me a new turbine without any problems whatsoever.
listem MANN makes amazing filters period.
building CF's is not a new business to them and i was also dealing with a seller from the UK on these CF and although 90psi will work it not nessecary because 1/10th of a micron will be attained at below 80psi. but this is all on their pdf document.
i did not know that its possible to order the SpinClean CF without the shutoff valve and their being a price difference. i happen to have one and it open at psi.
when i campare the DC and SC they are identical with the exception of the center shaft. but like both manufacturers indicate the psi needs to be introduced VERY slowly and that is important.
hope this helps.
Originally posted by plugly:
does anyone know if these centrifuges are available in the UK or something similar
thanks
plugly
Hi Plugly,
I've just had a Dieselcraft delivered to the UK, delivery was sub one week.
All in (including tax and carriage) it cost about £230.
Would be interested to here the cost of the Mann + hummel one if you get the info.
Mike
Location: Sunny Devon | Registered: 15 September 2005Reply With QuoteEdit or Delete MessageReport This Post
Hey !
Why buy CF so expencive?
Stationary engineparts sell them alot cheaper in UK.
I myself sell them in Norway and Sweden.
Write to Steve, info@stationaryengineparts.com info@stationaryengineparts.com
and say Hello from me.
Steinar
/Sweden
Location: Sweden | Registered: 07 February 2007Reply With QuoteEdit or Delete MessageReport This Post
I'm about to configure my Spin Clean setup and echo some of the questions asked before but never quite completely answered.
The Spin clean comes with a British Standard Pipe Thread inlet. The IDP company that sold me mine ($160 plus 10 shipping a couple weeks ago) included the flare adapter but I don't want to use that.
Will 1/4" NPT work??? I saw someone say they thought that's what they used. Also, I saw that one member used a hydraulic hose. Any special fitting there? I just want to be sure it will seal right. Do I need to use pipe dope? Any other things I need to do?
Thanks!
Nick
87 MB 300d Turbo
84 GMC 6.2 Diesel Suburban
84 MB 300d TurboDiesel
Location: Missouri | Registered: 19 December 2006Reply With QuoteEdit or Delete MessageReport This Post
I too have a new spin clean and am worried if the 1/4" will seal properly. Does anyone make an adapter from BSPT to NPT?
Muleears
Very tolerant wife
What size is that flare adapter ? BTW ,
www.mcmaster.com sells BSPP and BSPT fitings and adapters . Search
there for - British Standard Pipe Thread fittings . Their shippng is very prompt.
I think I saw that. I'll go ahead and order the adapter. I read somewhere in these 12 pages that one successful member just used 1/4" regular ole pipe thread.
Anyways, may as well do it right.
Are people using pipe dope or just counting on the threads to seal the connections?
87 MB 300d Turbo
Nick or Muleears - So what is the size of the included flare fitting adapter ? Could one of you please post a picture of it ?
You still need to use a sealant on the correct size adapter threads -yellow teflon tape or that white Permatex stuff. Be careful not to overtighten .
This is what I ordered from mcmaster:
5832T122
(Same as 5832T2)
BSPT-to-NPT Std-Wall Brass Thrd Pipe Nipple 1/4" Pipe Sz, 1-1/2" L, Threaded Both Ends, Sch 40
Hope this works
Muleears
Very tolerant wife
It's a screw in fitting that came with the Spin Clean. It's about 1" in length and screws into the spinclean input. The other side is a usa flare fitting. But kindof a cumbersome way to do it I think. I'd rather use the conversion nipple.
As far as sealing the pipes... does plain old pipe dope paste work? What did you use?
87 MB 300d Turbo
Originally posted by steinar:
Hey !
Steinar
/Sweden
Thanks for the info Steinar, A large chunk was courtesy of the lovely people at customs...
Thanks for the link though as it looks like they do suitable pumps which will make life easier Smile
A bit off topic but I'm trying to wire the motor for my pump. The attached pics are all the instructions I have. Please PM so as not to clutter the thread.
Muleears
Very tolerant wife
sorry can only do one at a time
Muleears
Very tolerant wife
last one, thanks
Muleears
Very tolerant wife
that person was i,
i went to the local plumbing specialty store and i asked for an adapter 1/4 on each. one side for the spinclean and the other for the standard stainless steel weaved covered hose which is a compressin fitting i beleive. i gave me a coupling that is compression one side and npt on the other. its npt because that is all they sell.
btw, i did not recieve any adapter when i got my CF , just the gasket.
i used thread sealant from loctite on the npt to the CF and teflon on all the other joints.
i guess i can post a picture tomorrow
 Previous Topic | Next Topic powered by eve community Page 1 ... 9 10 11 12 13 14 15 ... 41
