Sponsors    Home    Forums  Hop To Forum Categories  General SVO Discussion    UPFLOW SETTLING - DEWATERING: Simple VO cleaning system
Page 1 ... 6 7 8 9 10 11
Hello Coach,
Excellent point, and I agree 100%. Will set up another pair of tests with just the raw oil sitting for a week and test the top layer, then decant it into an upflow bucket and test that after another week.
Baking soda and water - an acid neutralization and FAA-to-soap wash? I'll give that a try as well.
Thanks for the suggestion.
Big(Bio)Bertha 1987 GMC Suburban V2500 6.2L V8 IDI J-code 3/4Ton 4x4 4in lift, cargo hauler.
Brunhilde 1985 Merc 300TD, commuter
1968 Caterpillar D4D 3304 bulldozer
1971 Waldon 4100 payloader
1981 IHI 30F crawler excavator
1995 Changfa 195 w/ ST 10kw genset
Registered: 31 December 2007Reply With QuoteEdit or Delete MessageReport This Post
Originally posted by Burbarian:
Hello Coach,
Excellent point, and I agree 100%. Will set up another pair of tests with just the raw oil sitting for a week and test the top layer, then decant it into an upflow bucket and test that after another week. ...
Why the week? Do it exactly like your other test or it won't be an actualy control to compare with.
_________________________
Just taken 25 gallon from tank.stored in 5 gallon jacks AKA carboys. pan tested every jack no water.
ddreigiau danio
Location: South Wales.uk | Registered: 16 May 2007Reply With QuoteEdit or Delete MessageReport This Post
had to do this with plans as they are pdf documents it wont let me post the whole document this is made from standard uk plumbing fittings some of the pipe and fittings that you use are hard to get on this side of the pond
ddreigiau danio
VAPOR LOCK
ddreigiau danio
Pipe in side ibc
ddreigiau danio
ibc
ddreigiau danio
Nicely done drawings with some interesting design variations.
Let us know if you get any green slime growing on the copper. Some have advised not using copper, but I've never tested it personally.
Hey, now we can add "internationally acclaimed" to the description of upflow processing. Well done!!
'89 Toyota 3.4L TDI + FPHE
BD+ULSD+VO+JetB blends
Hi John
LOL i think it only goes green when air is in the system, and at uk price for diesel @ £1.10 per ltr. I dont think there will ever be air in the system.
Best regards Will
ddreigiau danio
John & Will international men of Mystery.
ddreigiau danio
Pulled 25 more gallons today, pan test, no water,going to try speed it up to 35 gallons per week. All the best Di
ddreigiau danio
Karl Fisher shows water as high as 2700ppm in oil used for cook chicken and very high FFA, dimers and trimmers. Also water as high as 900ppm in soy oils used to cook frozen foods like fires and chicken fingers from a bar. These results are repeatable. cgoodwin
If an oil has a significant amount of FFAs (many of which form Azerotropes with water) then no amount of settling, centrifuging or heating will remove it at atmospheric pressure. This is also my theory of why the more heavily used oils seem to have a higher water content even though they have been subjected to more extended heat levels. Even if new oil is exposed to O2 it begins to decompose into FFAs and other polymers which are also probably highly hygroscopic. Chris also touched on some of the other gunk which comes out of the food in the fryer(which include glycerols. sorbitols, crazy shaped trans fats which like water very much, etc..). The good news is that the water which is bound to these chemicals is "usually" poorly reactive with fuel system components like IPs and injectors. nursecosmo
Not surprising, since hydrogenated oil and animal fats attract and retain moisture. Remove the hydrogenated oil and animal fats and most of the water goes with it. cold upflow settling process removes those hygroscopic components in the used VO, and along with that most of the moisture is separated out as well. The clear, dry oil off the top of the cold upflow barrel tests dry by weight or hot pan test. Any moisture that fails to register on either of those tests isn't a problem with the inline IP on my truck.
This message has been edited. Last edited by: john galt,
Hello Coach,
Burbian, can you please start a new thread detailing what your system looks like (just a description) and the use it to keep me posted on how your modifications to the upflow system is working? I think that any research done to adapt the upflow method to a wider variety of oil needs to be shared.
John Galt: I have a modification to your upflow tank, which I introduced while I was filling up the tank initially. I have about 2 inches of exhaust pipe that sticks up into the upsidedown 15 gallon bucket. Rather than saw those 2 inches off, I put a sock in there, folded it over the edge, and put a pipe clamp on it. I'm not bothering with a screen any or pantyhose anymore, as there is absolutely nothing in my oil after 5 days of settling (I can almost gaze right through a cubie full of oil) and there is only a smear of tallow in the bottoms of the cubies. Is the sock going to pre-filter it enough?
As a note, I've found that a basement with a concrete floor is almost perfect for settling. It's probably only about 55F right on the floor, but the oil settles out great and it pours VERY easily at that temperature, almost like regular #2.
Unheated upflow system: Initial batch in progress
1993 GMC Sierra K2500 6.5L mechanically injected (yay no PMD) w/ 74 gallon aux tank + homebuilt veg kit NOT YET INSTALLED (because it's 0F outside)
Location: Pembine, WI | Registered: 26 December 2007Reply With QuoteEdit or Delete MessageReport This Post
I have never seen any info showing that PHO attracts moisture any more than non PHO. Can you point me to some study of that?
Hi,
Attached is a photo my upflow settling system.
The tanks are old steel hot water systems, being tall and skinney they are ideal for settling.
Since I took the photo Ive added a breather with a shut off valve on the first tank, so when I drain the unwanted oil from the bottom of tank one it can draw air in from the breather as these are sealed units.
Registered: 02 February 2008Reply With QuoteEdit or Delete MessageReport This Post
... Since I took the photo Ive added a breather with a shut off valve on the first tank, so when I drain the unwanted oil from the bottom of tank one it can draw air in from the breather as these are sealed units.
Could you please give us details on your breather? What is it made from?
Honestly have not wrapped my head around the breather concept on the upflow settling yet.
I get the oil in the system with a boat bilge pump once the first tank fills it drains from the top into the 2nd tank via gravity, the 2nd tank is slightly lower than the first tank, once the second tank is full you are in business, put 50trs in the fist tank and take 50ltrs out of the 2nd tank, the tanks stay 100% full all of the time. The settling time is roughly 6 weeks,
As these tanks hold 160ltrs each.
As for the breather question.
Its just a plumbing fitting. If you dont put a breather on the first tank you would be sucking oil from the bottom of the second tank when you drain the muck from bottom of the first tank.
i just finished my test of the upflow system and i have been unable to produce the same results. between 1-12-08 and 3-21-08 i added 15 gallons of oil a week, hot pan testing at the cubie and at the blue jean filter.
a hot pan test from the top of the second drum yesterday, showed water. the least amount of water i have ever gotten, but still too wet. the bottom of the pan was full of bubbles that were the size of the head of a pin, then rose to the surface.
i know how much you guys love to fight, and im sure some of you will call me a liar, others will call john a liar, but, i am only saying i was not able to produce the same results. which i believe only proves this system is not for all types of oil, and no one ever claimed it was.
it is possible that with better oil, or better settled oil, i could get this to work, but i also noticed the following problems with this system, that have caused me to lose interest in it.
1. i cant see more then 15 gallons a week being produced, far less then what i will need. i would need several of these systems running at the same time. i would rather add heat and speed it way up.
2. my oil does not move below 40F. it is liquid, but thick. it will not pass through the panty hose, i had to put it on the stove and heat it.
these reasons have caused me to abandon further testing. i will now try adding heat.
i believe everyone who says this system works for them. i am not trying to prove anybody wrong.
if anyone would like to question my test, i will respond. i will not defend my findings or join anyone in attacking this system.
i will not join in a fight.
i would like to thank everyone in this thread, i have learned a lot, but this system is not for me.
1995 ram pick up. 2500. not converted yet, but working on it.
Location: conn. | Registered: 07 December 2007Reply With QuoteEdit or Delete MessageReport This Post
If the oil you're using won't dry with cold upflow settling then use Ron's heated upflow system.
I have a trouble free settling system that gets me more than 1000 gallons thru a 2 micron Racor filter element.
My settling tank is very evenly heated and well insulated. I introduce the oil into the bottom of the tank slowly to not stir up the oil already in the tank. The outlet is about 6" from the TOP of the tank so I am only draining the top 10% of the oil in the tank. The outlet gravity flows thru the 2 micron filter into my storage tank. If I put 5 gallons into the tank a day, it takes over a week for that oil to work it's way up to the outlet. by that time almost all of the water and solids have settled out. I get over 1000 gallons thru the filtering station filter and I have NEVER had to replace an in the car WVO filter even after 70,000 miles on WVO.
I use a settling tank that has a little more capacity than the amount of oil I use in a week. With PHO Soy, I ran a little over 120F in the settling tank and about 80 in the storage tank (I am intentionally keeping the animal fat clear). With Canola, I am running about 100F.
No problems with polymerization.
I can heat it either with hot water from my boiler or with electricity. The tank is wrapped with PEX pipe with a spacing of about 3" turn to turn and is also wrapped with ice melt cable between the PEX turns.
The water loop is fed from a tempering valve so a constant water temperature is circulated around the settling tank. The circulating pump that I am using only draws 5 watts.
The electric heat is controlled by a proportional controller rather than an on/off controller. Once up to temperature, it takes less than 60 watts to maintain temperature. With good enough insulation a 60 to 80 foot ice melt cable will get you over 200F. That temperature will probably damage the cable. I have had no problems up to 150F.
Normally I just use the circulating hot water heat.
I also heat the incoming waste oil with an inline thermostatically controlled electric heater (like a 120V version of a veggietherm) to the same temperature as the tank so there is no temperature differential between the incoming oil and the oil already in the tank.
My in home filtering has been working so well that I used a stock fuel filter for WVO on my last WVO conversion ('85 MB 300D)
Ron
'85 300D
Since '81 former WVO conversions:
'83 240D
'80 Audi 4000D
'83 Isuzu Pup
'86 Golf
Several generators
Kubota Tractor
thank you for the advice. i am looking at several ways of heating .
i will probably heat the upflow system, as i do like that design and i think heat will solve the problems i have with it.
  Powered by Eve Community Page 1 ... 6 7 8 9 10 11
