Biodiesel and SVO Forums Home
Forums
Straight Vegetable Oil (SVO) as fuel
General SVO Discussion
WVO Tank ideasGo ![]() | New ![]() | Find ![]() | Notify ![]() | Tools ![]() | Reply ![]() | |
| Member |
here is a link that will help you out with your suburban http://biodiesel.infopop.cc/eve/forums/a/tpc/f/159605551/m/5701080002 B.K. Hosken install good luck Omar www.omarsales.com | |||
| member |
I found a 55 gallon stainless tank on Ebay for $cheap$. It's out of a boat. It took a little work but it's been great. It's baffled and has a 2" bung to fill. I had to have a fitting welded into the bottom for fuel-out and I also added a heat exchanger... ------------------------ 1985 Mercedes 300D with Greasecar kit. 1993 Chevy 3500, my own conversion. | |||
| Member |
| Member |
| Member |
| member |
Motown Fire - That looks like a galvanized tank . Zinc (galvanizing ) and WVO (or the acids found it it ) are reactive (see- http://biodiesel.infopop.cc/eve/forums/a/tpc/f/159605551/m/122607161/inc/1 ) . It would be better choose at tank made of another material ( preferably aluminum , palstic, or stainless steels ). You heated pickup configuration looks good but use it in a another tank . 1994 F250 IDI 7.3 NA E4OD Remember that the forum search/"find" feature does not include the archives . Search the forum archives here- http://www.biodieseldiscussion.com/forums/search.php | |||
| member |
Seeking tank options for my 1994 Ford F250 7.3 long bed pickup truck ? - I have been using the front stock tank for WVO (heavy polymerized WVO buildup aka "chicken skin") and rusty rear tank for diesel . I want to replace the steel WVO tank with aluminum or plastic and also need to deal with a rusty rear tank for diesel . I am looking for some under the bed tank options than stock type replacement tanks. ( Cheap metal stock replacement tanks are available for around $100 shipped front or rear , plastic tanks for about $200 ea- www.mts.company.com ) . edit - see this photo -for a good reason why not to use a steel tank for WVO - http://i33.photobucket.com/albums/d70/rkpatt/ppstuff090708a004.jpg I have a very limited budget for this so unfortunately those direct fit plastic tanks from www.mtscompany.com are not a choice in this case .This message has been edited. Last edited by: rkpatt, 1994 F250 IDI 7.3 NA E4OD Remember that the forum search/"find" feature does not include the archives . Search the forum archives here- http://www.biodieseldiscussion.com/forums/search.php | |||
| Member |
rkpatt, A steel powder keg would not be a good idea, i.e. sparks. I imagine it is aluminumn and they proably use plastic these days. | |||
| Member |
This is what I hope is my finished tank. The wrecking yard gave me the gas neck. Next time I am going to hold out for a Diesel filler neck but free is free. Scott 1994 Dodge Cummins converted Aug. 08 using Sunwizards design with elecrtic valves. 1990 Ford 7.3 N/A 1979 Mercedes 300CD (Sold) 1982 240D Two tank Ace Hardware and Autozone system. Linscott dewatering/filtering/Lil Angle Pat Carr Plumbing Wetzel Fuel Cell 20mm ammo can for WVO tank | |||
| Member |
http://www.freewebs.com/peteolson/apps/photos/ 85 ford f250 stock tank heated wvo fuel pickup good read have fun Omar www.omarsales | |||
| Member |
| Member |
| Member |
25 gallon auxillary fuel tank which fits a 1992-1999 GMC/Chevrolet Suburban. The tank was built on 6/12/2007, and manufactured by Northwest Metal Products of Forest Grove, Oregon | |||
| Member |
| Member |
| Member |
this is the same "vegwedge" tank i used. careful- the vent is in the fill cap and it can/will get crudded up and the tank will pressureize and split the seams. add a positive vent- i connected to the top of the diesel tank. if anyone needs the one i have send me a note it's not that bad. patThis message has been edited. Last edited by: patcarr, | |||
| Member |
more here http://www.turbodieselregister.com/forums/alternative-f...-wvo-conversion.html hot fox in a spray tank Omar www.omarsales.com | |||
| Member |
| Member |
| Powered by Social Strata | Page 1 ... 5 6 7 8 9 10 11 12 |
