Toying with the idea of installing one of these in a F250 for the svo and then installing a small tank in the bed for the dino.
Thoughts? Aero Tanks |
I see some people using coolant lines to heat up WVO in plastic gas cans. Can it be any plastic gas can or does the plastic have to be a specific kind or rating?
s |
i believe it should be HDPE rating; which means it can handle temperatures up to 300F. Jetta 2002 frybrid kit Jetta 2006 chipped, Bilstein Sport, Neuspeed Sport Springs, Neuspeed endlinks, DG SS, Evolution skid plate, Eibach RSB, |
s |
Say! That looks pretty slick. Almost afraid to ask how many sheckels?
I confess that frequently it is beyond my capacity to follow the jumbled mix of thoughts in this and other threads. The best I can hope for is to not get beat up to badly for asking questions for which smarter folks have already been able to extract an answer. |
I cut the center section out of the 2" non standard bung with a dull 1 7/8" hole saw. It ended up being a very tight fit, so tight I had to press in the coupling with a rubber mallet.
The coupling is a 1 1/4" weldable steel type found on the end of uncut pipe that is used to protect the threads. I tack welded the washer to the top of the coupling and JB welded the heck out of it before putting it together. This pic was before gluing it all together. Installing it in the tank included even more JB weld and a couple of screws to help keep the threads for coming loose. I had to grind off a bit of the barrels 2" bungs plastic ring. Otherwise the cap would not screw in all the way. The second bung has a 2" x 1 1/4" bushing JB welded and tightly screwed into place. The washer was JB welded to the top of the bushing with screws added to also help keep the threads from coming loose. I will be adding a hot fox type heater to this opening The pvc cap is a home made breather cap/filler tube. |
Why not use the stock tank for diesel? And:I couldn't find the tank that you've posted pics of on the Aero website - can you tell us the price? Thanks! Craig PlantDriver http://www.PlantDrive.com craigreece@plantdrive.com Land Rover Defender/Series hybrid with 300Tdi, PlantDrive system: Vormax, Vegtherm, HotFox, manual brass 6-port valve Wife's car: 2001 New Beetle, VegMax, Vegtherm, 2 gallon donut tank for start-stop fuel and WVO in stock tank, 3 - 3-port valves, controller. |
This tanks is 26ish gallons and was custom made with all of the fittings you see and the fuel sender gauge installed less than $300. He is also workig on a different tank for a truck that is 60 inches wide and 65 gallons that one is $550 with all of the fittings. There are baffles on the insdie of both tanks also and aluminum coil heat exchanger.
Point is sometimes you can get a nice custom tank for less than the price of a poorly welded tank from Northern Tools or one of those places you get factory tanks. Robert In Fort Lauderdale running a 1985 Gold Mercedes 300d custom aluminum tank (18) gallons looped return with return to diesel tank. HOH wraped filter FPHE. Greasecar valves. PICT0005.JPG (28 KB, 92 downloads) |
Here are some custom underside tanks for a customers MBZ 300TDT w/3rd rear seat. The veg tank fills through the stock filler and mounts in place of original tank with all factory mounting hardware, tank is about 18 Gal. The diesel tank is around 7 gallon and is accessed from the top, it uses the stock MBZ sender. The tanks fit perfectly, I want to do a set for my TDT next.
300TD Samurai Veggen WVO shop heat |
http://www.4secondsflat.com/Fuel_Tank_Sealer.html
RED-KOTE ® FUEL TANK LINER STAYS FLEXIBLE - Will never crack or peel off. ALCOHOL - GASOLINE RESISTANT BRIGHT COLOR - You can see the results. COVERS RUST - Seals old rust in and prevents future rusting. SEALS LEAKS - Gets the multitude of pin-holes you can't find. Red-Kote ® is a new polymer coating developed by Damon Chemical. Red-Kote ® is resistant to gasoline, diesel fuel, alcohol and other fuel additives. Its major use is to seal leaking fuel tanks. Solvents such as methyl ethyl ketone (MEK), acetone, methylene chloride and propylene oxide (POP) will completely dissolve the polymer. Other industrial solvents may affect the coating but, not completely dissolve it. Red-Kote ® is easy to use if the directions are followed closely. It seals the multitude of small leaks that often form where the straps wrap around the tank. You fix the obvious leaks and Red-Kote ® seals the rest. Contrary to what some people will tell you, rust does form inside gas tanks. The cause is condensation and water in gas. Red-Kote ® seals rust under the coating so it cannot flake off to plug fuel-line filters or cause engine damage. Further rusting is reduced also. |
i have one of these wedge tanks for a benz if any one is interested. needs some work, but much less than starting from scratch. pat |
Where do you live in OR i am at Sacraemnto. How much do you want for the tank. Does it leak?
Thanks |
more ideas at this link http://www.vegrev.com/veg%20rev%20projects.html#jackson good luck Omar www.omarsales.com |
Will this tank work? I'm converting a Suburban and the dimensions of this tank are very similar to someone who sent me a sketch of his custom tank.
What would you suggest for heat? Thanks. http://www.westmarine.com/webapp/wcs/stores/servlet/pro...77123/10001/257/78/6 |
