Sponsors    Home    Forums  Hop To Forum Categories  General SVO Discussion    WVO Tank ideas
Page 1 2 3 4 5 6 7 8 9
I noticed that very few of the tank options presented had low point drains.
I made my tank out of a 37 gallon NH pickup bed unit. I welded a 2" nipple to the bottom of the tank, cut out the hole inside of the nipple with a torch and then screwed in my own hot stick design. This does require about a 3" hole in pickup/vehicle bottom.
My hot stick is made out of standard black iron plumbing, some brass valves and a hose connections. The heated part consists of a 1/2" pipe inside of a 1" pipe. The 1" pipe is capped and welded so it will not leak. Heated engine coolant flows up the 1" pipe and is returned down the center through the 1/2" pipe. The fuel exits out of a 2" T with reducers that is located below the pickup bed. The hot stick runs up through the 2" T so the fuel is warm rather quickly. Then there is a low point drain below the pickup. It is very reassuring to take a fuel sample from the drain and see nice clear fuel.
Scott
Registered: 06 December 2006Reply With QuoteEdit or Delete MessageReport This Post
Scott can you post a photo
Omar
Aluminium is surely the ideal tank making material. It is light, easy to work, inert to vege oil, rust free and the same material as aluminium piping (funnily) so no corrrosion due to dissimilar metals. Here's mine Tank & pickup
Johnno
Johnno
4WD Isuzu Jackaroo 3.1 45,000km on WVO 2 tank home built system 6 solenoids. Mk. 7 version. Currently researching Mk. 8
Location: South Oz | Registered: 11 October 2005Reply With QuoteEdit or Delete MessageReport This Post
Once I finally get mine finished, I will post a picture or 2. I don't have a lower point in the tank like a sump, but I tilted my tank so the low point is the front inside corner, closest to the pickup.
Johnno,
Is that 3/4 inch aluminum tubing? Where did you get it? Thanks.
Pat
Registered: 15 July 2006Reply With QuoteEdit or Delete MessageReport This Post
Originally posted by amosquito:
Johnno,
Pat
No it is 12mm OD tubing. It is a bit of an awkward size as 1/2" coolant hose is a bit loose on it and hard to seal. I got it from an aluminium supplier and bent it by hand. It was cheap tho about $2 per metre.
Johnno Smile
Johnno
TDI install to read thru
http://www.nickpisca.com/Alamo/InstImages3.html
have a good read
Omar
www.omarsales.com
240 D mercedes install
here is a link to the install by BGKAST ... great photo's
http://www.mercedesshop.com/shopforum/showthread.php?t=148416
Omar
www.omarsales.com
JB weld tank!
http://greasebenz.com/node/4
A tank heater was designed using a 60" long gas appliance connector. The connector is inserted into the tank and coiled around the fuel pickup screen. Hot coolant is run though the connector, thus heating the fuel pickup and melting congealed SVO on sub-zero mornings
have a good read
Omar
www.omarsales.com
Scary
GreaseKing of Cali
www.greasekings.com
I actually like the idea of a fuel tank under the hood. .......but not that tank.....
My very first grease vehicle (1980 Audi 4000) had an 8 gallon grease tank with a heated sump under the hood. There was a huge amount of space under the hood and I needed the trunk.
Since then I have done several conversions with a small diesel tank under the hood.
Ron
'85 300D
'83 300D
'83 240D
'80 Audi 4000D
'83 Isuzu Pup
'86 Golf
Several generators
Kubota Tractor
http://cgi.ebay.com/ebaymotors/100-Gallon-Nomad-WVO-tan...dZ1QQsspagenameZWDVW
100 Gallon NOMAD WVO conversion kit from Golden Fuel Systems – formerly known as Greasel Conversions
more on 190D install
http://qtband.com/wvo.htm
have a good read
Omar
www.omarsales.com
on a 96 AAZ engine.
This message has been edited. Last edited by: evangelos,
Jetta 2002 frybrid kit
Jetta 2006 chipped, Bilstein Sport, Neuspeed Sport Springs, Neuspeed endlinks, DG SS, Evolution skid plate, Eibach RSB,
