Sponsors    Home    Forums  Hop To Forum Categories  General SVO Discussion    WVO Tank ideas
Page 1 2 3 4 5 6 7 8 9
541-942-5920
Fuel Tanks
FBO Handcrafted Spare Tire Well Aluminum Fuel Cell
......Tired of the Square Peg in the Round Hole?
Now Available with Deep Sump add $75.00
$375.00
anyone tryed this one ?
O
60+ gal for pickup truck using a modified HIH. setup.
Location: Fayetteville, AR | Registered: 03 August 2006Reply With QuoteEdit or Delete MessageReport This Post
28 Gallon boat tank with a HotFox it barely fit in my 240D but i made it work with a BFH.
06 VW Jetta TDI
Location: 85616 | Registered: 19 April 2007Reply With QuoteEdit or Delete MessageReport This Post
tdi front wvo tank
read about the install by Ben
http://www.benjaminellis.net/benjaminellisdotnet/projects/WVO/TDI.htm
http://home.earthlink.net/~joemama1/LC.html
1983 FJ-60 Land Cruiser Diesel & WVO Conversion
have a good read Omar
www.omarsales.com
Fleet tank, 30 gallon aluminum.20 bucks from out the jaws of the scrapyard crusher. Bulkhead's 1/8" plate aluminum ($1 'no parking' sign from same scrapyard).
Location: NWArkansas | Registered: 24 June 2006Reply With QuoteEdit or Delete MessageReport This Post
Stock Merc 190 tank. Aluminum evaporater coil mounted inside for a heat exchanger
My 190D
Ken
Location: STL | Registered: 04 September 2006Reply With QuoteEdit or Delete MessageReport This Post
Here is a 1979 VW rabbit install 16 plate HE with coolant wrap wvo filter. Wvo tank is a cut down (6 3/4 inch high ) 55 gal. drum fits in the spare tire spot ....
Omar
www.omarsales.com
Registered: 05 August 2006Reply With QuoteEdit or Delete MessageReport This Post
stock tank as 2nd wvo tank ($10 at the pull a part)
good luck
Omar
www.omarsales.com
06 VW Jetta TDI
Here is my tank, an RCI tank from Summit It fits in the space in front of the wheel well still allowing use of the full 4x8' bed for things like my camper.
And the heated pickup inside:
Registered: 15 July 2006Reply With QuoteEdit or Delete MessageReport This Post
SunWizard,
Am also thinking about using the RCI tank for my conversion. Can you tell me how you made your heat exchanger and from what material? Did you drill extra holes in the top of the tank for coolant in and out from the exchanger? Thanks.
Pat
The heated pickup (no heat exchanger in tank) is aluminum tube, bent in a loop around the bottom of the existing pickup tube, 1/2" from the floor of the tank, you can see in the pics. I used 2 of the existing threaded fittings on the top of the tank. 1 of the ports was a vent and had a ball bearing in it that I had to hammer and pry out. I drilled an extra hole for a vent on the left, and put a tire valve stem on it with the core taken out.
This has worked even with thick partially hydrogenated VO in winter as cold as -10F.
heres own I built for my truck
 http://biodiesel.infopop.cc/eve/forums/a/tpc/f/959605551/m/8481078602
