Topic Closed|
Ebay. I got my RCI's there for 25 buks each but they are HIGH VOLUME ones for large tank cleaning. Need fluid going at about 15gpm thru them to be effective. _________________________ If you believe you can't YOUR RIGHT; But equally so.... if you believe you can, YOUR RIGHT as well. |
member 2008 Sponsor |
This is a link to another similar link on this forum called "G-Force seperation", a bit more discussion about washing machine ideas.
--------------------------------------------------------------------- 92 dodge cummins with over 260,000 miles. Running an unheated 50% diesel/50% WVO blend for about the last 75,000 miles when temps above 50 deg f, no modifications or heating except the addition of a throw-away in-line fuel filter (removed during cold weather). As of 8-01-05 I have been testing a 75% WVO/15% gasahol (90% RUG/10% ethanol)/10% diesel blend. Works fine down to about 65 f then starts rough. Runs ok once engine warms up. Back to a 50/50 diesel blend sence 9-15-05, just to cool now. -- 11-01-05 Modified stock fuel tank internal fuel pickup to have I.D. of 3/8 inch, this eliminated cold start slow idle and bogg on acceleration. Now adding 1 ounce each of acetone and pure gum spirits of turpentine to each 5 gallons of any blend, seems to help keep the fats in solution to a lower temperature --Heated 2nd tank in the works |
I got a spinner II on ebay for $180. It works great.
2002 Dodge 2500 Biodiesel |
You guys are making me really jealous on these eBay deals! I haven't found any centrifugal/cyclonic type oil filters using searches including "oil, filter, filtration" etc.
How do these work with colder/thicker oils? Do you have to heat the oil to at least 90 degrees to get the flow rate up? Thanks, Todd 2002 F-250, 7.3l PSD on grease since 2004 |
I've always run the oil/BD through it at about 140 F. On ebay I searched for "centrifuge".
So how does the Spinner II do at water separation? Anyone test this? How does it compare for filtration and water separation with say a Racor 1000 type filter?
Barclay -- Barclay in So Cal Planning WVO conversion of 72 GM 4108 DD 8v71 bus |
| Previous Topic | Next Topic | powered by eve community | Page 1 2 3 4 |
Topic Closed
