Thanks Omar. It looks like the heads are either Hayden or Perma-cool. I still couldn't seem to figure out the brand of the heat exchanger though.
Welder, in 'other products from this seller' he lists the filter head as 'Toyota Supra Celica Spyder Remote Oil Filter Base~New'. 25 dollars. I bought the Permacool one from Summit racing. We have tons of the filter mount HEs at work as well. Aluminum and brazed copper? I think? I'll have to cut open one of those, I already cut an aluminum one in half. I posted pictures here somewhere. HTH
Blessings. Joe 1999 Chevy Suburban 6.5L TD 1987 Mercedes 300TD and 1986 Chevy Cube van 6.2L. WWW.RillaBioFuels.com WWW.RillaBioFuels.com |
Thanks Rk! I think Frybrid also mentioned that those HE units have VW origins.
Thanks Joe! I'd love to know if the guts of those heat exchangers are brazed or what? Frybrid sells them as part of their filters. If they are copper brazed, polymerization might be a concern. Nickel brazed would be fine though, I think. |
So I bought an oil cooler unit http://stores.ebay.com/tmvtaylor
from this guy and made one of these filter units my self out of a vw oil cooler. This oil cooler is HAYDEN brand. The head of the oil cooler I bought is the same as his SVO filter unit. Also the nipple that goes up the center is 3/4 16 I'm pretty sure, and had a hard time finding anything with that tread. If I had to make it again I would have waited, because he dropped his price on this unit from $300 to $150. |
Just checked my link and found this http://cgi.ebay.com/WVO-BIO-SVO-Diesel-Fuel-Heater-Whol...Z42604QQcmdZViewItem It is for a lot of 10 of these filters for $1300. But would not be worth wile as a group buy.
Thanks for the info Steve! I'm just basically trying to figure out where I can buy the oil cooler heat exchanger heads and the Hayden or Permacool heads for wholesale prices.
I'm trying to start my own svo supply company and I want to be able to offer cheaper units like the Frybrid/tvmtaylor style units as well as high end custom units that heat the filter element instead of the head. This would really only matter in cold climates. In warm climates the Frybrid/tvmtaylor unit would work just fine after the cold oil in the element was replaced by the hot oil flowing in from the heat exchanger head. I actually followed Omars link and read through about 40 pages of tvmtaylors' feedback checking his supplier info in an attempt to find his heat exchanger supplier. I finally gave up. His volume is huge. Napa or some other major player might be able to wholesale them to me. I had planned to have my custom svo filters out on the market by now, but I've had a lot of problems trying to find reliable machinists. I've got one now. I may have a display photo to post this thread soon. Hopefully, anyway. |
First off, heres a link to a thread that covers my filter.
http://schumanautomotive.com/forums/showthread.php?t=3350 also, the greasecar link that omar posted w/ the pics has some info.
I would call reliable and talk it over with them. they were very helpful to me on the phone when I called. Be the change you hope to find in this world.-Gandhi |
Hi mobetta,
It looks like the Stanadyne uses special filters rather than screw on ones. What is the price of replacement elements? How is the heater spear attached? Is it threaded or a bayonet? Ron '85 300D '83 300D Since '80 former WVO conversions: '83 240D '80 Audi 4000D '83 Isuzu Pup '86 Golf '76 Honda Civic with Kubota engine Several generators Kubota Tractor |
good read lots of links and info http://www.noendpress.com/caleb/biodiesel/index.php Omar www.omarsales.com |
hello- the filters are a press fit, with a plastic ring that locks them on. way easier than unscrewing an element that's inside a coolant wrap. also, this design puts the incoming fuel on the bottom of the filter, and draws from the top. the replacement elements are about $15(5um,6") from reliable, or $9.70 from the local carquest(wix,5um, 5"). they accept a 5um filter used on 96-02 gm diesel vans, and also a unit which is OE on bobcats and other equipment,(both are 5um, one is 4.3", the other 5") so are pretty easy to find. they also can be had in 30um and 2 um. heres the heater- it drops in, and has a plastic nut which holds it. sealed w/ o ring. I am very happy with it. I did clog the first one in less than 500 miles, so I revised my home filtering setup quite a bit. I was amazed by the fact that the oe filter would last 3-4k, running the same grease. to me that means this is way superior filter, and I am glad that I had to re-vamp my home filtering. I now have only 300ish miles on the second filter- but the first was a 4.3", this is a 6", so I cannot directly compare them. Be the change you hope to find in this world.-Gandhi |
http://www.parker.com/racor/dfh_intro.html
anyone tryed this heated filter head by racor? Omar www.omarsales.com |
About the filter price- I was "misqouted" on the phone when I ordered my filters- I went to pick them up and they tried to get me for $48 for 2
I didn't buy them- but went to filter1.com and get them for $11.50 ea/ w/ free shipping on orders of 6 or more. not much more than the MB(wix) spin-on's are, and a way better filter. got over 1k on this one, since I rehabbed the home filtering. Be the change you hope to find in this world.-Gandhi |
Thanks for the reply but the filters from that link aren't the ones I'm looking for. I'm lookinig for something similar to the old lovecraft filter, but not one where I have to add a heat exchanger in place of the stock fuel filter.
I use the Racor with the heater in it on one of my E350s . Easy to install all I got was the bottom part with the S45 filter and it fits into the top part of the Ford filter head .
2 - E350 - 7.3 Ford cube vans , 5 ton International , Bens and heating my home all on B100. |
Cann't seem to find the link to order. Can you? |
| Powered by Eve Community | Page 1 3 4 5 6 7 8 9 ... 19 |
