Heat Xchanger before welding. The can is a used GM A/C receiver drier. They can be obtained for free from your local A/C shop. There is 20-some feet of Aluminum tubing rolled on a mandrel and stuffed inside. Bungs were turned and threaded, then welded on. Heat exchanger on left - heated filter right - fully plumbed with Dayco Gen II 1/4" ID Fuel Injection Line, biodiesel rated and cheaper than Viton. you can see more of this install at this link http://www.rf.org/gallery/view_album.php?set_albumName=Traviss-Veggie-Benz Travis's Veggie Benz - 1985 300SD lots of great ideas on this install! Omar www.omarsales.com |
http://www.lovecraftbiofuels.com/index.php?page=shop.pr...virtuemart&Itemid=26 found this here is a video of it installed http://www.lovecraftbiofuels.com/index.php?option=com_c...gory&id=10&Itemid=34 Omar www.omarsales.com |
http://img.auctiva.com/imgdata/2/1/3/6/6/6/webimg/20501532_tp.jpg anyone having good luck with a Davco? eletric heat how many amps? Omar |
Ron, I am pretty sure you are right. Even though there is more coolant than oil, the viscosity of the oil is much different than the coolant. The coolant should heat up first. Remember, the thermostat will keep the coolant stationary until it opens up. Most people with gauges say 5-10 minutes more to get the oil to temp after the coolant is at temp. The coolant "oil coolers" are used to get the oil up to temp faster by having more direct connection to the oil. The coolant would get to temp faster, but the oil would get hotter than the coolant, since it doesn't have a temperature controller, just a pressure controller. |
Shaman quoteRemember, the thermostat will keep the coolant stationary until it opens up.
This is not quite right. Most vehicle heater systems (which we vegos tap into, do not circulate thru the thermostat but bypass it. Heating in the heater circuit and therefore the vege oil heating circuit occurs at the same rate as the coolant in the block, whereas the thermostat only opens to let coolant into the radiator once it reaches its opening temp. specified by the engine manufacturer. Johnno 4WD Isuzu Jackaroo 3.1 45,000km on WVO 2 tank home built system 6 solenoids. Mk. 7 version. Currently researching Mk. 8 |
The davco 234 is a very expensive filter but well worth the money. The 12v heater in the 234 is a heater/thermocoupler combo, there are two different models, one for bioD shutting off at 60* and one for SVO shuting off at 110*F. It draws 12.5 amps and the element is in the bottom of the fuel chamber with a coolant radiator. These heaters being in dirrect contact with the fuel and located in the bottom of the fuel chamber seem to make the most sense. If You have the extra space I suggest the davco384 it is about $100 more than the 234. It uses the same fillter as the 234plus but has a much larger oil chamber. It has thermostat on the coolant inlet that shuts off at 90* but can be disabled for constant flow. The 12v heater is seperate from the thermo coupler and draws 18.5amps. Since the 12v heater and the thermo coupler are seperate the thermocoupler can be bypassed for constant duty. In addition to the unmatched heating ability of this fillter, it's fillter changes are quick, easy, and CLEAN. If you have the space and the money this is the filter you want. Davco has alot of info at there sight www.davcotec.com/fp384.htm One small note, although these filters are desiged for use with B100 and SVO the Warrenty on these filters only covers B20. Arctic Fox use to make a heated fillter that had a centurfuge on the bottom. Has anyone used on of these? Do you know where to get them? |
I think Nat and Nini or Justin sell Artic Fox heaters here is a clip http://homepage.mac.com/withinsightvideo/Sites/withinsight/videos/trucks.htm Business Name Enviofuel Contact Person Nate Gunn Phone Number 541.231.1499 Email Address info@enviofuel.com Street Address # Wake Robin Corvallis Oregon, 97330 USA Truck clip http://homepage.mac.com/withinsightvideo/Sites/withinsight/videos/nini.htm Omar www.omarsales.com |
http://www.mercedesshop.com/shopforum/showthread.php?t=171668
link to install photo's and lots of info 4. As far as the heater goes, the thermostat is not capable of being changed since it is built into the heater and will automatically regulate itself. Depending on what heater he has here are the following on/off temperature cycles. a. 100 Watt heater: On at 58˚F, off at 85˚F b. 150 Watt heater: On at 42˚F, off at 75˚F http://www.reliableindustries.com/catalog/viewpart.php?qiid=STN_33641 another heated filter Omar www.omarsales.com |
I used a davco 234 with electric heat and I wasn't pleased with it. I run TIH to the davco and the davco was losing heat. Oil entering the davco was hotter than leaving it (infared thermometer) by about 30 F
Keep in mind the infared was picking up the temp of the outside of the fuel line and the reading at the end of the TIH could have been off due to the hot coolant so close to where the tube exits the hose 86 F250 veggie since May 2005 25,000 miles and counting 78 Benz 300D converted Feb 2006 2,500 miles and no longer counting 92 F250 converted on May 2,2005 14 000 miles and counting 81 rabbitt 84 benz 300d |
I am going to wrap a secondary filter on my rig with an Artic Fox pad heater,using a big hose clamp to hold it. Probably wire it to a simple switch somewhere. Question- has anyone used the Artic Fox insulated hose wrap. Coolant hoses disapate heat the longer they go.
HHS3201T-10-MICRON Item #: HHS3201T COOLANT HEATED FILTER Hot head coolant heated filter includes: filter restriction gauge-lets you know when its time to change your filter, 1 RACOR S3201T 10 micron fuel filter with bottom BOWL & drain and mounting hardware overall dimensions: 13" tall x 4.5" wide 4" fr to bk, 3/8" female NPT coolant ports, 1/4" female fuel ports, compact size (over Davco or Vormax) makes for easier mounting in engine bay, suitable for cars and up to full size pickups. http://vegpower.com/order/prodpage.cfm?cat_selected=92&...ected=374&startrow=1 anyone out there use this one? Omar www.omarsales.com |
I have never used one but I just wonder how many square inches of surface area there is in the heat exchange in the head.
Ron '85 300D '83 300D Since '80 former WVO conversions: '83 240D '80 Audi 4000D '83 Isuzu Pup '86 Golf '76 Honda Civic with Kubota engine Several generators Kubota Tractor |
FWIW
I am working on a custom built cleanable filter aluminum housing and top, stainless mesh filter. Will be heated in the center electrically (as opposed to the top) Will be internally temp controlled so as to not overheat becasue this baby will HEAT. Will have port for temp probe or pressure gauge. Of course will be pricey, but will save on filter replacement costs. |
Sometimes you need to save the best for last, shotgun truck!! 250 sq.in. of heating surface area and a top loading 10 micron $8.00 filter element. no purge, no mess 160 degree pre-injection temps!!
GreaseKing of Cali This message has been edited. Last edited by: Shaun, |
Hi Tom Yaz,
something like my filter from BIODRIVE ? BMW Fan BMW 324 TD Touring 2x BMW 324d Mercedes 300 SD Deutz INTRAC ( Farm tractor ) Unimog Listeroids biodrive_filter_disassembled.jpg (447 KB, 88 downloads) |
Something like that, but of course mine will be better |
