Oh man, I knew there must be an easier way..Phil
Yep; I got one off a Citroen a couple of years ago. Many Peugeots and Cits had them at the time of manufacture. Drawback is the old Lucas/CAV element which dumps a cupful of diesel/VO on the ground when you change it, but that's countered by the price of the elements - about 2bucks a shot. Kilkenny, Ireland. 2001 Ford Transit - 40,000 miles on WVO and BD |
Me too, got one. Use it in a Fiat Ducato RV, for 33000 km on WVO so far.
And I agree. the filter is a mess to change and to small for my engine.... Planning of exchanging it to an another construction and easier to exchange. |
^^looks-like-isusu-diesel-pikup-filters Be the change you hope to find in this world.-Gandhi |
It's a stock unheated filter with a glow plug in the base. The guy selling them was trying to get the coolant heated bases from me but the price of them has got a bit excessive in the few years or so. (well too much for him) See http://vegburner.co.uk/heatfilter.htm I can get a big selection of parts for this range of filter. Single heads, single heads with pumps, parallel flow twin filter heads, series flow twin filter heads. Short and long filters for filter flow (down centre tube up through media) short and long filters for agglomerator flow (down through media up tube in middle) which has slightly better water blocking ability and slightly shorter filter life. Heated bases, small and big glass bases plexi glass bases, short or long aluminium bases. Glass section to go between filter and any base, coolant heater to go between filter and head, 12V electric heater to go between filter and head, vortex style sedimenter/water separator to go in place of filter cartridge. diaphragm hand pump to go on M14 inlet or outlet port, nylon mesh glass pre filter/mini sedimenter to go on M14 inlet or outlet port, M10 restricted orifice air bleed for double filter heads or single without pump, M14 pressure relief valve to allow the use of a powerful lift pump, Banjo connectors suitable for 6mm, 8mm, 10mm or 12mm rubber or nylon pipe. |
This is a industrial hydraulic filter that I made with Jegs 1/2 aluminum tubing, Earls fittings and some other water and hydraulic fittings. I have 4 new 10 micron filters to go with housing. Comes with mounting bracket, SS bolts and top plug has been tapped to 1/8 NPT to put temp. gauge if you wish; if not I will send original spare plug http://cgi.ebay.com/ebaymotors/WVO-Heated-Filter_W0QQcm...fPartsQ5fAccessories found on ebay good luck Omar www.omarsales.com |
http://www.stripmindmedia.net/blog/2008/02/single-tank-conversion.html anyway have a good read Omar www.omarsales.com |
http://i6.ebayimg.com/05/i/001/2e/28/61ff_2.JPG
DAVCO 322 MODEL FUEL/WATER FILTER PROCESSER. THE LOWER UNIT OF THIS MODEL IS EXACTLY LIKE THE DAVCO 382 WITH THE SPIN ON FILTER REPLACING THE SEE THRU FILTER TOP. THE UNIT IS COOLANT HEATED FROM ENGINE COOLANT OR FROM RETURN FUEL TO THE TANK. THIS MODEL HAS A BALDWIN SPIN ON FILTER, PART # BF7613. THERE ARE SEVERAL MANUFACTURERS FOR FILTERS THAT WILL FIT THIS UNIT. THE OEM PART # FOR THIS DAVCO IS: 322030SNIB. http://cgi.ebay.com/ebaymotors...AUS%3A1123&viewitem= have a look omar www.omarsales.com |
The new "VM2" from PlantDrive.ca
VM2 Edward Beggs PlantDrive(tm) International plantdrive.ca@gmail.com http://www.PlantDrive.ca SVO Consultations; Component/Kit Supplier; SVO Conversions; since 1999. VM2stack.jpg (14 KB, 16 downloads) |
Dana दान danalinscott@yahoo.com http://vegoilconversions.netfirms.com/ VegOil Conversions by Dana Linscott- VO Conversion Consultation for large and small trucks, VO fuel related businesses, and co-generation(power/heat)projects, |
I used foil tape backwards,attacked fattywagon line heaters wrapped around my FM100 filter.This makes a removable slevee,With household electric water heater thermostat.When coolant heat takes over,electric heater shuts off.
do you have a photo you could post thanks Omar
Can't load photo.
126 diesels yahoo groups 83 SD straight exhaust 94 Cobra Cold air,real cold.Cobra electric radiator fan,Monark nozzles,5 psi electric fuel pump.85 amp alternator 12" subs.26 psi boost 0-60 10.8, 37 mpg highest 2 tank,wvo,boost guage ,line heaters,coolant heater Fattywagons customer. electric_heater_2.JPG (34 KB, 33 downloads) |
check here bob
I did away with the heat on the filter,and bought a good used heatexchanger for $60,like Omars 16 plate.
However I foil wrap my injection line heaters,and use water heater therm to control heat.Line heaters by themselves will lose heat fast,but if you insulate with layers of aluminum foil,then aluminum tap.Wow we. This message has been edited. Last edited by: Nathan, 126 diesels yahoo groups 83 SD straight exhaust 94 Cobra Cold air,real cold.Cobra electric radiator fan,Monark nozzles,5 psi electric fuel pump.85 amp alternator 12" subs.26 psi boost 0-60 10.8, 37 mpg highest 2 tank,wvo,boost guage ,line heaters,coolant heater Fattywagons customer. IMG_0040_yah.jpg (40 KB, 9 downloads) |
Coolant Heated Fuel Filter and Water separator made of aluminum flat plate heat exchanger (FPHE) heats vegetable oil to engine coolant temperature before it flows through filter media. Eliminates waxing and makes WVO thinner in cold climates. Compact size but very efficient. Easily replaceable filter element. Preferable mounting vertical (less spills when changing filter cartridge) but also can be mounted at any angle Comes with one filter cartridge WIX 33616 with drain at the bottom to purge water out. http://cgi.ebay.com/ebaymotors...fPartsQ5fAccessories another vw heated filter Omar www.omarsales.com |
