The wimpy single coil exchanger on the left is the stock cooler on the MKIV tdi... The middle cooler is a stock gasser V6 4motion Passat oil cooler, which appears to be identical to the Dieselgeek oil cooler. I used to have a Dieselgeek OC on my auto and it bolts right up. I've confirmed the V6 the 4motion Passat will also bolt up as well. It should be noted that although it bolts right up, it stresses the coolant lines a bit, as they aren't long enough to connect to the lower connectors on the cooler. I belive Oldpoopie discussed how difficult it is get that the little booger in place a while back. Dieselegeek sells these for $210 complete, which isn't a bad price. If you know a good parts counter, you can get everything for about $185 new. The part numbers you'll need are: 028117021E OIL COOLER (should come with upper gasket) 038117061 LOWER COVER TO OIL COOLER WITH SEAL Now, the big daddy on the right is the oil cooler from a 04 130HP PD Passat. It will bolt right up as well, as Lito has been running it for a few weeks now. The coolant connectors sit on top of the cooler... you can either trim your coolant lines about 2 inches, or leave them long (just zip tie the excess). Install is a snap according to Lito. All the parts you need can be gotten for about $200 from vwparts.com (call Jerry!), or any other parts vendor out there that you know and trust. 038117021B OIL COOLER 038117061 LOWER COVER TO OIL COOLER WITH SEAL 038117070B SEAL There ya go... Oil cooling options for all. more at this link http://forums.tdiclub.com/showthread.php?t=78993 have a good read Omar www.omarsales.com |
Trying to get there (WVO 100%) with my 83 mb 300sd. Anyone found any AC/DC heat tape? Seems you could wrap it anywhere (or everywhere)and use the house current for extra cold morning starts.
Also am considering an xtra battery in the truck, hooked to a quick filtering system for road trips (stop for a burger, drain their grease trap, dump the two filters, clean the sump screen) Any leads? I can only find ac tape for preventing pipe freezing.
http://www.green-trust.org/Nick's%202000%20F250%20Veggi...onversion%20012.html another heated filter Omar www.omarsales.com |
another one O |
Wow my filter got on there fast.
grease gun ... what can you tell us about your heated wvo filter??? thanks
Omar |
Well I can't say anything bad about this filter except the size, it is about 18" tall. I don't think there is a vehicle out there besides a semi that could fit this under the hood. Mine is mounted behind the back seat of my truck (as we see in this pic) It is coolant and electric heated. I have used this filter in -40C weather. The filters last very long and aren't that expensive.
I bought it off this guy s www.svocomponents.com but doesn't seem like it works anymore. |
fuel heater, $48. Jegs racing,hoses and fittings home depot, $26. 45*F ambient 90sec temp top of unit 100*,10 min driving IP temp 110*,20min drive IP 130*,,,95*F ambient, 10 min drive 160* IP, central Tx.
small he and filter with glow plug!
found it on ebay under wvo http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewIte...%26po%3DOp2%26ps%3D5 good luck out there Omar www.omarsales.com |
The guy wants $400 for a FPHE and a filter head? Wow...
| Powered by Eve Community | Page 1 ... 12 13 14 15 16 17 18 19 |
