| Location: Kirkland | Registered: 10 January 2003 |    |
I simply wrapped 10 feet of copper around my filter, it works good gets the filter up to about 120 degrees.. the filter i uses are larger disposable metal ones.. I also insulated the outside of the copper coil.. this provides lots of heat for the VO going into the filter.
1993 ford Van IDI 7.3 non turbo 15k + veggie miles 1983 300d Benz Turbo diesel, dirt cheap $350 conversion 1993 Chevy 1 ton dually Crew Cab turbo diesel awaiting conversion
Ron Paul for Prez 2008!
| Location: West Central Minnesota | Registered: 16 May 2007 |    |
quote: ok the last one scares the hell out of me!!!!
ya! what do you do when that coolant hose springs a leak going down the freeway
1985 300SD 290K no mods, his 20K on veg(since October 05) 01 Jetta TDI 179K stock, hers (ours)35K on veg(since august 06) 99 Suburban 6.5L 252K stock, 0 K on veg(since sept 08),75% WVO, 15% stale RUG, AMSOIL cetane boost, AMSOIL diesel fuel modifier, acetone, startron, pure gum turpentine
| Location: Uncasville, CT | Registered: 15 July 2006 |    |
quote: Racor Turbine Series Fuel Filter / Water Separators
Just so newbies don't get unintentionally mislead. These don't separate suspended water microdroplets from wvo.
| Location: Central MN..Brrrrrr! | Registered: 06 November 2001 |    |
quote: Originally posted by Dikyviking: quote: Originally posted by Omar: http://www.parker.com/racor/dfh_intro.html anyone tryed this heated filter head by racor? Omar www.omarsales.com
Cann't seem to find the link to order. Can you?
Kind of pricy
______________________________________ '97 Ford F-350 7.3L PSD - Plant Drive kit '84 Mercedes Euro 300D NA - Custom two-tank Running on vegoil and biodiesel since May 2006
| Location: SF Bay Area | Registered: 14 February 2003 |    |
