Biodiesel & SVO Home
Biodiesel & SVO Forums
General SVO Discussion
Lye stripping high FFA wvo
Topic Closed|
I think your information about the maths is wrong. If your oil titrates by the usual method with NaOH to x ml you should use x grams of NaOH per litre of oil to react with the FFA.
The problem with this method is that it tends to make an emulsion which would take forever to settle out. In industry a centrifuge is used and it works well. If you use less than the titration amount you will only partly reduce the FFA, as you found, but it appears to settle better than happens if you attempt a full extraction. The question is: how much oil is lost in the emulsion? And how does this loss compare with the loss which occurs in the normal biodiesel base-only reaction. It may turn out that a partial removal of FFA in this way will have the advantage of cleaning the oil better than simply settling or water washing. Looking forward to more results. |
What is the purpose of this experiment if we are not making biodiesel? Is this a way of lowering the gelpoint of VO without going the biodiesel route?
Werner *************** 96 Passat TDI Wagon, converted to WVO/SVO! 11000 km's and counting. Two tank system. |
I don't know that this removes FFAs, but what about a brine wash?
did some experimenting a while back and found that a solution of baking soda in water mixed w/ WVO and agitated (shook up) produces an emulsion that settles rapidly and completely and, I'm guessing, neutralizes some of the acid content of the WVO worth trying a sample and titrating before and after and see what you get no oil lost and baking soda is safer than lye rOLf 2 yrs and 100k mi on WVO - '93 VW EuroVan 2-tank w/ tank heat/HOH/10-micron heated Fleetguard, FPHE |
member 2008 Sponsor |
Form the similar washing research I did several years ago I suspect this may simply be removing/neutralizing water soluble acids.
Dana दान danalinscott@yahoo.com http://vegoilconversions.netfirms.com/ VegOil Conversions by Dana Linscott- VO Conversion Consultation for large and small trucks, VO fuel related businesses, and co-generation(power/heat)projects, |
neutral, can a centrifuge be built? I don't know anything about them. By the name I assume something spins really fast but that's about it. In layman’s terms, how does a centrifuge work?
Cleaning the wvo this way seems to work, I assume that it will also lower the gel point of svo for those that run it. I don't know what the highest titration is that can be used on the strait base method of making BD and I haven't had a chance to figure out the acid-base process. The bad oil I'm using seems to have something in it that keeps particles in suspension with every other method I have tried to use. This is slow but it seems to work. I plan to make BD from the two samples I treated yesterday and see how much difference there will be in the final production rate. -mcguyver 2002 Excursion 4 x 4 with a 7.3 liter powerstroke and Several diesel trucks and equipment associated with the arborist field. |
When i need to reduce the FFA of wvo i use heat , methanol , sulfuric acid and time .
David Norwood 2001 F350 DI on blend . Only one fuel tank . Up to 85 % wvo . HOH for fuel line heat. Add-on Amber Goldenrod 10 micron before OEM filter . dttk44@bellsouth.net |
McGuyver...A centrefuge on the scale of what you probably want to do will very much resemble a carnaval ride. My thinking is to maybe use a diesel engine and using a connecting tranny to power the spinner pole. Then, connected to chains and a suitable metal container or basket to hold 5 gallon buckets (sealed of course) with wvo. An hour of spinning should do the job of seperating. Any thoughts????
Your joking...right? Dana दान danalinscott@yahoo.com http://vegoilconversions.netfirms.com/ VegOil Conversions by Dana Linscott- VO Conversion Consultation for large and small trucks, VO fuel related businesses, and co-generation(power/heat)projects, |
A backyard centrifuge? If designed like a carnival ride, turning at modest speed, it would have to be large. The industrial machine is quite small but turns at enormous speeds and is a continuous process, treating small amounts of material at any one time. It is not feasible to attempt to build one - the prior art is very far advanced.
A better idea for the backyard would be to do the FFA stripping not with water but with the glycerine from the previous batch. It is too hard to dissolve NaOH in glycerine but KOH will do it. The high density of glycerine ensures that separation will occur without the need for a centrifuge, just as happens with the biod reaction. Due to the high viscosity of the glycerine this must all be done at high temp and drained hot. It is all a substantial work load however and I think the preferred route for high FFA oil is the two stage acid/base process. This has the added advantage that it permits the recovery of the FFA so that they may be included in the next batch, thus eliminating them from the waste stream, an option not available with any other process. This is a substantial saving as for every litre of FFA (in soap) that goes down the drain there will be two litres of perfectly good biodiesel going down the drain with it. |
DN
I haven't had a chance to learn about the acid-base method yet. I haven't built a good mini batch vessel that I can heat and stir while sealed. Do you think you could greatly reduce the ffa of wvo with a titration of 17 or 18? It is really bad oil and seems to hold tremendous amounts of water in suspension. It's been filtered through a 20 micron sock filter and smells terrible. Ivoryman I'm beginning to get the idea of how it works. I assume the "crud" and water is heavier than the oil so it settles to the bottom of the bucket. Right?? I don’t know if running an engine for an hour for just 10 gallons of wvo is the best means but it might be a stepping stone to building something better. I’m going through about 120 gallons per week so I’d probably have to have something a little bigger or something with a continuous supply. Does a small continuous unit exist or is it even possible? After your description, I see a wheel with 5 or 6 vials spinning and the vials swing further and further out as the rpms increase. danalinscott You mentioned something about some research about brine wash? Is this something that could be done on real bad oil? I've been super busy this week and haven’t had a chance to update my results on the two test batches. So far, both have settled but I haven't titrated the second sample yet. -Mcguyver 2002 Excursion 4 x 4 with a 7.3 liter powerstroke and Several diesel trucks and equipment associated with the arborist field. |
Check out this thread called "DIY centrifuge". the 8th post down from top has a link to an actual experimental centrigug built by john o. (here).
There is another post HERE indicating someone was having success with a "spinner" type centrifuge but the post never went anywhere. Don't know if the "spinner" refered to in this post is the "spinner on-board oil filter" for diesel engines or not. I have been monitering centrifuges on ebay for some time now, lots and lots of the small testube lab centrifuges but I have not yet seen a large continious feed unit. I am told by employees of the local Humco/Kraft vegoil processing plant that these large continious units are what is used there to seperate different weight vegoils and water from oil. --------------------------------------------------------------------- 92 dodge cummins with over 260,000 miles. Running an unheated 50% diesel/50% WVO blend for about the last 75,000 miles when temps above 50 deg f, no modifications or heating except the addition of a throw-away in-line fuel filter (removed during cold weather). As of 8-01-05 I have been testing a 75% WVO/15% gasahol (90% RUG/10% ethanol)/10% diesel blend. Works fine down to about 65 f then starts rough. Runs ok once engine warms up. Back to a 50/50 diesel blend sence 9-15-05, just to cool now. -- 11-01-05 Modified stock fuel tank internal fuel pickup to have I.D. of 3/8 inch, this eliminated cold start slow idle and bogg on acceleration. Now adding 1 ounce each of acetone and pure gum spirits of turpentine to each 5 gallons of any blend, seems to help keep the fats in solution to a lower temperature --Heated 2nd tank in the works |
http://biodiesel.infopop.cc/eve/forums/a/tpc/f/919605551/m/341102225/p/2
I haven't worked with this lately, but maybe there's potential?? |
After reading about hydrocyclones in the above link I was wondering -- What if we combined the idea of the hydrocyclone and a centrifuge, Yes - a bit outside the box thinking -BUT- Start with a fairly large centrifugal pump, say 6-8 inches in diameter, mount it so the input opening (center) is pointing straight up, hook the shaft to a motor like normal. A centrifugal pump can have its output flow completely blocked with no problems, it just makes some amount of pressure and then spins the fluid round and round. What if now we use another smaller pump to push fluid BACKWARDS through the centrifugal pump so that fluid is being forced into what is normaly the OUTLET of this pump, This fluid is going to go round and round at 1750 or 3450 rpm or whatever, as fluid is pushed into the outlet other fluid near the center HAS to be forced up and out of what is normaly the INLET -- If we choose a pump with a flat backplate it would be fairly easy to remove the outer housing to remove the solids that should get deposited on the inside wall of the pump housing, actualy would not be to difficult to fab a flat sided housing with a small center outlet (original inlet) as this is not a crucial part of the pump and nothing is moving about it. The impeller can be increased or reduced in diameter as might be nescicary, this is one of the ways used to control the G/M flowrate of a centrifugal pump anyway. This should also seperate the free water or heavy oil from the lighter oil, just put another outlet in the outer wall and control the output flow rate of this outlet to match the amount of water or heavy oil being seperated, maybe several outlets across the face of the outer housing from the center to the outside edge, each outlet would be for a different weight fluid.
Continuous feed and seperation, High "G" forces, no balance problems, sealed shaft, scalable, small and mobile, could be powered by a 12 volt DC motor -- Sounds to good to be true... OH YAH -- Pat. Pend. --------------------------------------------------------------------- 92 dodge cummins with over 260,000 miles. Running an unheated 50% diesel/50% WVO blend for about the last 75,000 miles when temps above 50 deg f, no modifications or heating except the addition of a throw-away in-line fuel filter (removed during cold weather). As of 8-01-05 I have been testing a 75% WVO/15% gasahol (90% RUG/10% ethanol)/10% diesel blend. Works fine down to about 65 f then starts rough. Runs ok once engine warms up. Back to a 50/50 diesel blend sence 9-15-05, just to cool now. -- 11-01-05 Modified stock fuel tank internal fuel pickup to have I.D. of 3/8 inch, this eliminated cold start slow idle and bogg on acceleration. Now adding 1 ounce each of acetone and pure gum spirits of turpentine to each 5 gallons of any blend, seems to help keep the fats in solution to a lower temperature --Heated 2nd tank in the works |
The problem in continuous centrifugation is that you need not only immense G forces but also an environment without churning so that settling can occur. The industrial machines have a central stack of discs so that the oil has to move in a constrained way through tiny slits.
Neutral -- Ok, we may have to machine a custom impeller that has a stack of closely spaced thin plates with small radial slits, may not need the radial slits ? May not be perfect but this is the first idea I have come up with to give mobile filtering at least a glimmer of hope. I invisioned the feed to be at a very slow rate, I would think this would allow the time needed for seperation and migration of the thinner fluid to the center outlet ? will need to do lots of testing.
May take two of these units in series, the first one using a normal impeller to force the particulates to adhere to the outer housing and a second unit to seperate water ? Maybe several ? --------------------------------------------------------------------- 92 dodge cummins with over 260,000 miles. Running an unheated 50% diesel/50% WVO blend for about the last 75,000 miles when temps above 50 deg f, no modifications or heating except the addition of a throw-away in-line fuel filter (removed during cold weather). As of 8-01-05 I have been testing a 75% WVO/15% gasahol (90% RUG/10% ethanol)/10% diesel blend. Works fine down to about 65 f then starts rough. Runs ok once engine warms up. Back to a 50/50 diesel blend sence 9-15-05, just to cool now. -- 11-01-05 Modified stock fuel tank internal fuel pickup to have I.D. of 3/8 inch, this eliminated cold start slow idle and bogg on acceleration. Now adding 1 ounce each of acetone and pure gum spirits of turpentine to each 5 gallons of any blend, seems to help keep the fats in solution to a lower temperature --Heated 2nd tank in the works |
It would be wise to have a look at a centrifuge before doing anything I think. And if the chemistry is right do you really need a centrifuge?
Nahh -- just dive in - you have already shortened my initial research and testing time considerably.
To bad you don't burn straight vegoil, you are stuck in a biodiesel frame of mind. There is not a lot of chemistry to consider in cleaning straight vegoil, just a lot of filter clogging. --------------------------------------------------------------------- 92 dodge cummins with over 260,000 miles. Running an unheated 50% diesel/50% WVO blend for about the last 75,000 miles when temps above 50 deg f, no modifications or heating except the addition of a throw-away in-line fuel filter (removed during cold weather). As of 8-01-05 I have been testing a 75% WVO/15% gasahol (90% RUG/10% ethanol)/10% diesel blend. Works fine down to about 65 f then starts rough. Runs ok once engine warms up. Back to a 50/50 diesel blend sence 9-15-05, just to cool now. -- 11-01-05 Modified stock fuel tank internal fuel pickup to have I.D. of 3/8 inch, this eliminated cold start slow idle and bogg on acceleration. Now adding 1 ounce each of acetone and pure gum spirits of turpentine to each 5 gallons of any blend, seems to help keep the fats in solution to a lower temperature --Heated 2nd tank in the works |
McGuyver...I was talking about 5-10 buckets swinging which would make it worth while. The thing we need to figure out is the speed the revolution needs to be for separation as well as the time. My wife uses a centrifuge for blood work as a doctor. The revolutions per minute on the machine she uses is staggering. I don't think it has to be blinding speed to get the layers started on the wvo. Any more thoughts???
Tim...do you see this as a way to collect directly from the collection bins? I still would do extensive filtering but it sure would make it easier to initially separate water and gunk.
Topic Closed
