Biodiesel & SVO Home
Biodiesel & SVO Forums
General SVO Discussion
suggestions on this setup? I *may* have everything together : )
Topic Closed|
Why the facet pump? I do not think its needed and I think the added pressure may cause problems...
1997 Mercedes E300 Diesel |
If I didn't use the facet pump, how else would the fuel move through the system?
Just the IP? Also, what about for priming the system after changing filters? |
the mb lift pump has no problem pulling the vo on my 83 and 85 mb. prime the filter by filling it before you install it.
IN GOD WE TRUST-EVERYONE ELSE IS CHECKED NCIC |
member 2008 Sponsor |
I use a Facet boost pump on my PSD system. The disposable fuel filters clog in a matter of miles even with a heat exchanger in the tank.
I now use a standard spin-on automotive oil filter as a screen to protect the Facet pump. Most are 25 to 30 micron, more than sufficient to protect the pump. Do you have any sort of heat exchanger in the fuel tank? How do you get the oil flowing at all? Todd 2002 F-250, 7.3l PSD on grease since 2004 |
Can the greasecar solenoid handle 160*? I know the pollak valves experienced problems at these temperatures. I am going to go with a similar setup with my 2000 TDI, but was going to buy the frybrid valves for the reason above. |
Todd, Perhaps you should review your filtering of the vegetable oil before you add fuel to the veggie tank. I have many thousands of Km on the same fuel filter. When I went to a finer on-board veggie filter (changed due to system reconfiguration), I started having filter plugging issues. I am now starting to filter to 1 micron. The "throw away" inline fuel filters seem to last quite well with oil filtered to 5 micron before fuelling the vehicle. My vehicle (Fatmobile) has the stock fuel pump connected to the veggie tank (a Hollety Blue is for the start tank). An inline filter is installed before the stock fuel pump. Apart from when I have hasd the fuel system apart to recoinfigure it, the only time I have considered replacing it is when I have had high MP oils in the veggie tank. Even then, some hot water poured over this filter has rapidly cleared the blockage. "Fatmobile 3" '84 MB300D Silver/Grey with dark blue interior. 290kkm My car - 2 tank UCO conversion working well. 22 000 km so far on UCO "Josephine" '82 MB300D White with Palamino MBtex interior. 385kkm Wife's car. 20 000km on UCO blends. "Elizabeth" '81 MB 280E Good body now re-engined as a 300D with the engine from the '79 300D.70 litre UCO tank, 2 pollacks switch FP, filters and IP between Start and UCO tanks. '79 300D poor body (donor & parts) "Fatmobile 2" '80 MB300D White with dark Blue interior 230kkm (My first MB) - 5000 km on biodiesel / UCO blend - Found new owner (Sold in 2004). "Fatmobile" a '90 Mazda 2 litre diesel on UCO with biodiesel start/purge. - SOLD in Dec 2003 after 40 000km on UCO. |
I think the most important issue on vehicle filter clogging is oil temperature. Second most important issue is the presence of hydrogenated oils.
The 'disposable' filters I was talking about are the little inline filters that are only a couple inches long and not even as wide. They don't have much surface area. When I had all those filter clogging issues I was also dealing with some partially hydrogenated oils and was still running on the original Greasel automatic transmission cooler heat exchanger. Since changing to my own heat exchanger I have not had any problems. I have also added to my filtration setup. Back then I warm filtered to 5 micron and cold filtered on the way into the truck at 10 micron. I now warm filter to 1 micron and then cold filter to 1 micron as well. My hope is to collect enough oil to do some longer term storage of the filtered product. This will allow any hydrogenated oils to settle to the bottom. Then I will only pump from the top. Todd T 2002 F-250, 7.3l PSD on grease since 2004 |
This part will give you problems... the facet and small filter isn't goin to like cold VO The carter FP's we use will suck through the HIH no problem... why not get one and put it on the hot / outlet end of the HIH? If it was more fun everyone would be doing it! |
Thanks John. Is there a specific model of carter fuel pump you recommend?
Also, is it available locally, or online is the best bet? In another thread, I've been looking for some engine bay mounting advice (insert joke here _______), any more help would be greatly appreciated: http://biodiesel.infopop.cc/eve/forums/a/tpc/f/159605551/m/7031009341 Thanks folks! |
you really do not need a pump with the Mercedes lift pump it will pull veggy fine... I would recommend the Frybrid valves and use the prefilter but move it upto the engine compartment where it will get hotter VO, and see how it holds up there
The part #'s are on the install page of my site...
Topic Closed
