Sponsors    Biodiesel & SVO Home    Biodiesel & SVO Forums  Hop To Forum Categories  General SVO Discussion    ventilation for warm WVO filtering
hf
Hi - new here, still in the "research stage" regarding WVO/diesel, but haven't seen this topic addressed here or elsewhere:
How should you ventilate, if at all, while heating your WVO to 90+ F degrees indoors (for better filtering) in your basement or garage?
Every kitchen I've seen has at least a indoor-indoor fan above the stove (and preferably ventilation to the outdoors) for safety so that VO doesn't accumulate in the rafters and become a fire hazard. So I'd have to presume that a WVO warm filtering system would need similar ventilation, unless done entirely outdoors (not an appealing idea during our Boston winters Wink And I'm guessing I shouldn't make our clothes dryer exhaust duct "dual use".
Since I'm leaning toward acquiring the Dana Linscott "simple handpump" plans, I'd especially appreciate replies suitable for that system if set up indoors (presuming the plans don't address that - perhaps a bad presumption?) Especially glorious would be a set of plans for DIY-challenged types like me Wink
Registered: 21 July 2008Reply With QuoteEdit or Delete MessageReport This Post
I stick a 7 gallon enamel container on top of a wood stove indoors with a lid it's not a danger at all, oil has a very high heat tolerance before it catches fire. So as long as you have a low flame, a wood stove that's burned down to coals for example, there's a little more danger with an open flame.
I would definitely go with the garage over the basement though for fumes. Ideally you might just use a half size electric water heater. There's a lot of info about doing that safely, especially when you're just heating VO and not mixing methanol. You can hand pump VO provided it's not colder than frige temp.
Dodge TD50 2.3L '83
Greasecar 2 tank fleetguard filters/ Racor heated diesel filter/1000FH
Graco transfer pumps
DC OC20 in the works
Location: Sonoma Coast Northern California | Registered: 09 October 2006Reply With QuoteEdit or Delete MessageReport This Post
As someone who has put money and time into the DSE filtration setup, Dana Linscott's simple handpump system, John Galt's upflow setting system (the better of the three), let me say that I would have saved a lot of time, effort and money if I had invested in a centrifuge (I spent about 800$ of my CF, which consists of a gear pump, electric motor, FPHE and airhose and compression fittings I had laying around the garage) to begin with. Keep in mind you might be able to do a centrifuge for a lot less than what I spent: I simply after messing with different systems for a year or so decided I wanted to get it working and have it work right. If you can scalp a gear pump from a scrapyard you might be able to do a whole CF on the cheap.
Just my two cents.
Unheated upflow system: Initial batch in progress
1993 GMC Sierra K2500 6.5L mechanically injected (yay no PMD) w/ 74 gallon aux tank + homebuilt veg kit NOT YET INSTALLED (because it's 0F outside)
Location: Pembine, WI | Registered: 26 December 2007Reply With QuoteEdit or Delete MessageReport This Post
VO doesn't put out any hazardous fumes when heated. You might want a fan to get rid of bad smells that some VO has. A bathroom vent fan would be cheap and easy.
95 Dodge Cummins 4x4 Running on B100 and 2 tank WVO, 81 Mercedes 300D on V80/D20 blend
Definately learn your lessons outside. I'm at it 3 years and would love to get it out of my garage to an outbuilding. No real fumes, but mine smells like fried foods if i leave the top off. Stay out of the basement....you WILL splill this stuff. 100% guaranteed. But at $5/gal diesel, you'll just smile and clean it up. Big Grin
Merk
03 TDI WVO Converted. 12 gal marine tank in trunk w/copper heat excahnger no intank connections, coolant heated copper coiled fuel filter, HIH, two 3 port fuel valves
Location: Etna, NH | Registered: 19 January 2006Reply With QuoteEdit or Delete MessageReport This Post
