Sponsors    Biodiesel and SVO Forums Home    Forums  Hop To Forum Categories  Straight Vegetable Oil (SVO) as fuel  Hop To Forums  General SVO Discussion    PTC Thermistor and Electric Inline Heater.
Page 1 2 3 4
Hello Omar,
they are only coolant heated, but we do have an electric heater to be "wrapped" on the filter.
They are 150 watt, but two can be used together. Also we have added 2 small ball valves to close the circulation of coolant water when desired and when exchanging filters. This to avoid loss of coolant water.
Ill enclose an another pic. here.
But we preferred to use the PTC-heaters on top instead, they are 300 W
It's just that the only heat the incoming oil, and to reach 50 C you need two of them.
Then we can insulate the filters with a neoprene rubber hose/sock to avoid loss of heat.
If anyone want to buy one, we can deliver to USA and CA.
This message has been edited. Last edited by: steinar,
Location: Sweden | Registered: February 07, 2007Reply With QuoteReport This Post
can we buy them on your web site? let us know
Omar
www.omarsales.com
Location: Kirkland | Registered: January 10, 2003Reply With QuoteReport This Post
Hi all,
we will within a week or two, have these filters for sale.
The new about these filters are:
Compared with many other heated filters, these filters has a much higher heated surface.
A large surface to heat is important when talking about vegetable oil.
We enclose a filter-cartridge inside the heater, so we achieve a tight and very close contact with the heater. Therefore you will exchange both heater and filter in one.
The heating liquid might be;
a, coolant water from engine
b, returning engine oil from turbo
c, engine oil from engine, taken out from an outlet where you have pressure, eg.
oil pressure sensor.
As addition we have developed a double PTC-heater.
These heaters are 2 x 150 watt, 12 Volt. They are delivered incl. wires for both heaters
including connectors, relay-socket and relays You will receive 2 relays and two relay-sockets
The efficiency of the PTC heater is so high, that you might come up to 100°C. They are of course equipped with a temperature regulator to keep temp. steady on 70°C.
We do believe that this filter will make it easier to exchange filters without mess and get a better heating.
Any US or Canada buyers is welcome.
Any questions is welcomed.
selkomotor.no
PTC Water Heater With 12 to 240V Rated Voltage (PR4-35)
Model NO.: PR4-35
Standard: Pr4
Productivity: 900, 000, 000 PCS/Year
Unit Price/Payment: T/T
Trademark: Hwalon
Type: Varistor
Function: Degausssing
Installation: SMD Resistor
Material: Ceramic and Metal
Resistance: Variable Resistor
Package Type: Throught Hole
Export Markets: North America, South America, Eastern Europe, Southeast Asia, Africa, Oceania, Mid East, Eastern Asia, Western Europe
more info here
http://hwalon.en.made-in-china...Voltage-PR4-35-.html
have fun good luck
Omar
www.omarsales.com
Hi guys,
Been in Asia for almost 3 months, and not very active on the net.
The mentioned filters are now updated at the web-shop on www.selkomotor.no
The language are only Norwegian, but I can translate or answer any questions.
All prices is incl. Norwegian VAT, so you can withdraw 20% from the price.
If you buy several filters (5 and up) , we can look into a discount.
The advantage with this electric heater, is that you get a temperature up to 70 C, compared with the previous who only made 30 C. I guess the customers will prefer the new one. Also the water or oil heated filter has become popular, but it is still new to the market.
We also got a new oil burner, which swallow any kind of oil, and it is not dependant of pressurized air to work. It has its own pump to produce a pressure.
I do have some English text, for those who are interested.
Function :
This is Installed on the top of fuel filter. Improving cold start performance of diesel vehicle in winter or cold area as decreasing viscosity of fuel by heating filter. The heating element of heater is PTC(Positive Temperature Coefficient). Heater is a core component of common rail diesel fuel filter system
found this
have fun
Omar
www.omarsales.com
ptc heated filter
more info here
http://www.selkomotor.no/
have fun
Omar
www.omarsales.com
read thru this thread for in line heater info or glow plug thread
here is the info on the inline heater for $30
Sorry to tell that the webshop of Selko Motor is closed for some time.
The reason was that the interest for converting diesel-engines is not very high in the oilproducing country of Norway. Seems like the prefer Dino-diesel instead.
It is an higher interest in Sweden, but hard to find someone who want to start a business for it there.
Regards,
Steinar
We pioneered the use of PTC heaters. The Vegtherm. Comes complete with bolted on wiring leads, barbed fittings that will work for 5/16" or 3/8", a quality relay, circuit breaker and connectors, and is still only $99! The optional Vegsensor is also available, which is a simple and inexpensive thermal switch which can be clamped to the injector nut. See details at PlantDrive.com or PlantDrive.ca (Canada). Used successfully in thousands of conversions for over a decade.
Edward Beggs
PlantDrive(tm) International
plantdrive.ca@gmail.com
http://www.PlantDrive.ca
Location: Salmon Arm, BC, Canada | Registered: November 23, 2001Reply With QuoteReport This Post
