Sponsors    Biodiesel and SVO Forums Home    Forums  Hop To Forum Categories  Straight Vegetable Oil (SVO) as fuel  Hop To Forums  General SVO Discussion    PTC Thermistor and Electric Inline Heater.
Page 1 2 3 4
Originally posted by powersavers:
its a pretty easy figure, to get flow rate, figure max speed roughly 60 mph, @30 mpg= 2gal per hour total,1/2gal per hour per line on a 4 cyl.
Flow rate is higher than that because an amount of fuel (varies per manufacturer) exits thru the injector as unused (injector return lines). Granted by the size of the injector return lines that I have seen thats not that much additional flow.
Sorry that Im not a diesel wiz but does fuel continually flow thru the injector return lines?
_________________________
Just wanted to know if anyone has actually hooked up one or more of these 12V ptc thermistors to effectively heat thier filter,fuel lines,tank or other parts?
If so what did you do and how does it work? Big Grin
Location: VA. | Registered: March 05, 2004Reply With QuoteReport This Post
Wink
Location: Kirkland | Registered: January 10, 2003Reply With QuoteReport This Post
Omars been digging again. Smile
Anyone?
Registered: December 20, 2006Reply With QuoteReport This Post
Omar......well?????you thinkin?????? Cool
Location: Hi in the Cascades | Registered: August 30, 2005Reply With QuoteReport This Post
have a good read bob you can get an idea from the links good luck
Another Low Cost PTC (self-regulating) heater source
http://www.dbk-usa.com/product...aters/autodiesel.htm
some interesting fuel heating products
http://www.dbk-usa.com/product...ers/liquidheater.htm
Have fun out there
Omar
www.omarsales.com
RE: the second link...
...like some of the other electric inline heater "alternatives", there are a few things that should be noted...
It looks like a Vegtherm, but isn't.
They don't even want to sell for automotive application, whereas the Vegtherm was designed and used for the specific task of heating vegetable oil in our application.
The push on connectors have not been used on a Vegtherm since about 2004 (we use bolted on connections and wires ready to connect).
Vegtherm - proven, effective, reliable... $99 with relay, circuit breaker, and connectors.
Edward Beggs
PlantDrive(tm) International
plantdrive.ca@gmail.com
http://www.PlantDrive.ca
Location: Salmon Arm, BC, Canada | Registered: November 23, 2001Reply With QuoteReport This Post
http://www.specsensors.com/srh.asp
Self-Regulating Heaters
Features
* No thermostat needed
* Virtually unlimited life
* No moving parts to wear
* Very low cost
* No electrical noise
* Efficient
Description
Positive Temperature Coefficient thermistors are truly remarkable for their ability to function as self-regulating heating elements. They can operate at a nearly constant temperature over a broad range of voltage and dissipation conditions. PTC heaters can be manufactured in many different configurations. These include discs, rectangles, squares, cylinders, and various shapes with holes to increase surface area. Multiple PTCs can be used in parallel to provide constant heating over a larger area.
have a good read
Omar
www.omarsales.com
Build-in PTC liquid Heater
Build-in PTC liquid Heater for installation in sites where sufficient clamping contact must be guaranteed. This is necessary in order to continuously maintain optimum heat transfer.
Operating voltage: 12-240V
Insulation voltage withstanding: min. 3750V
Surface temperature: 100-250C
Rated Power watt: 50-500W
Power-watt density (Heating power-watt per water contact area): approx. 6W per cm2 (water temperature @25C)
more info here
http://www.amwei.com/views.asp?hw_id=66
PTC Thermistor Heater - Mar, 30 2010
PTC Thermistors (thermal resistor), also called PTC stone, are ideal heating elements. Thanks to self-regulation properties, heating devices based on PTC thermistor technology can generally dispense with control and regulating components as well as with over-temperature protection, PTC thermistor heating elements are used wherever measurement and regulating equipment as well as heating devices must be housed in tight confines. PTC Heating elements can be designed to be square, rectangular, round, ring or doughnut form, or housed in aluminum, stainless steel, silicon casing.
http://www.amwei.com/sort.asp?sort_id=6
makes 12volt tube heaters
have fun Omar
www.omarsales.com
The POP Diesel Electic In-Line Heater™ (patent pending) is built to provide better heat transfer for vegetable oil fuel than any other electric heater on the market. It allows the free flow of fuel while incorporating an internal structure to increase surface area for heat exchange and more precise fuel temperature control.
http://www.popdiesel.com/inlineheater.htm
found this heater
Omar
www.omarsales.com
A very nice description of the technology used in the Vegtherm and Vegsensor, which were both professionally designed to our specifications for the task at hand. Since we buy in bulk, we have been able to offer at competitive prices in a complete and available package tailored to the SVO application. Thank you for posting, Omar, and have a Merry Christmas.
Edward Beggs
have a good new year Ed sell lots! Big Grin
Omar
www.omarsales.com
ps.
If you want to save a few $ here is a link so you can make your own wvo in line heater
http://biodiesel.infopop.cc/ev...05551/m/83410762/p/1
make your own wvo heated tanks
http://biodiesel.infopop.cc/ev...591014102#7591014102
make your own wvo heated filter
http://biodiesel.infopop.cc/ev...9605551/m/7521042961
This message has been edited. Last edited by: Omar,
http://www.nomacon.by/new/auto_en/auto-tp.php
Heated in-line fuel standpipes (ТП) are intended for the diesel fuel intake from the tank under extended ambient temperature range including under low temperature conditions down to -40°C when the intake of the frozen and condensed fuel is impossible by standard fuel standpipes. The pre-starting period fuel and slotted filter heating is conducted by electric heater operating on car battery (car system) power. During engine operation fuel heating is conducted by heated return fuel in the ТП-101 (102) as well as by heated fluid – engine cooling system antifreeze in the ТП-201 (202) and ТП-301 (302). Liquid heating maintains battery power capacity and depending on temperature and applied ТП model usually provides fuel patency along the entire fuel main line. Under low temperature conditions the simultaneous electric and liquid heating is provided.
Heated fuel standpipes ТП-100, ТП-200, ТП-300 by NOMAKON™ in their modifications have the same length and the same mounting dimensions over flanges and nipples as standard fuel in-line standpipes in the MAZ, KAMAZ trucks and others. Consequently, ТП may be installed instead of a standard fuel standpipe as well as a special spare fuel standpipe for winter conditions.
ТПs have manual heating control and are also connected to the system of automatic heating control system СПА-101 (201). In the case of manual control a switch with indication is mounted in the cabin within visibility zone from the driver's seat. The switching-on of the heater is conducted by pressing the button of the switch.
interesting web site
have a good read
Omar
www.omarsales.com
Thanks to the innovative injection molding technology for PTC ceramic, FormFit™ heating elements from EPCOS can be fashioned into virtually any shape or form imaginable such as tubes, nozzles or rotor blades of ventilators.
good read
http://www.eeca.eu/epcia_resis...on_linear_resistors/
have fun
Omar
www.omarsales.com
Hello Guys, long time since I've been here reading.
Discovered you were discussing heaters, so I just thought I could show you this one enclosed here.
The filter itself is built in inside the heater, which is a double walled cup, where coolant water circulates inside. Thought it would be better than the copper tubes around the filters as i have seen here. We have two sizes of them for standard filter-head.
The small one has a cap. of 35l per 100 km, the other one 35 l per 100 km,
Price is 48 $ each. The filters should last 20 000 km if you use good oil.
Filter is 5 micron rated.
Also suitable for Common Rail and PDI, pressure tested up to 6 bar 230 psi
Location: Sweden | Registered: February 07, 2007Reply With QuoteReport This Post
Are they just coolant heated or is there an electric heater also?
do you manufacture the filters? looks good
Omar
www.omarsales.com
