Sponsors    Home    Forums  Hop To Forum Categories  General SVO Discussion    Lets put together a list of all the cheapest prices for parts...
Page 1 2 3 4 5 6 7 8 9 10
Heavy-Duty 3 way and 2 way Switching Valve
Heavy duty solenoid cartridge valve
Simple 2 wire hook-up
12vdc rebuidable
Comes with your choice of NPT, Push-Lok, or AN fittings (please specify when ordering)
All prices include shipping
$60
http://www.greasekings.com/?page_id=3
something to look at
Omar
www.omarsales.com
RE: www.filterbarn.com - I called them and was told that their filters were closeouts , new old stock etc .
Anyone here purchased from them have comments ?
I have bought filters from www.filter1.com ( Wix products) , www.jmesales.com ( cim-tek) got first quaility new filters below retail and happy with them but the prices at www.filterbarn.com got my attention . -
1994 F250 IDI 7.3 NA E4OD
Registered: 05 August 2006Reply With QuoteEdit or Delete MessageReport This Post
Whooo. I just hit the filterbarn link and found out my $7.40 fuel filters are made by Fram for $4.25. Very nice , thanks!!
Smile
for me, filterbarn is shipped overnite, too.
For sale is a new 2 in 1 heat exchanger and fuel filter for veggie use. The fuel enters this unit and travels through a heat exchanger composed of about 20 plates where it is very efficiently heated using engine coolant and then filtered. This unit is 9 inches long, 4 inches wide, and 5.5 inches high. It uses 5/8 inch heater hose for the engine coolant that warms the fuel. If you need an efficient compact veg heater and filter, this will satisfy your needs. This 2 in 1 unit is very efficient and "Top of the Line". It has a 0.25 inch thick steel mounting plate with two mounting holes and will work if mounted with the filter upright or downward. These units without the mounting plate sell for over $500 in England and are available in limited supply. If you have a bulky conversion to downsize or have been looking for a compact unit due to limited space, then this will work for you.
There is a port for a temperature gauge sending unit shown in one of the pictures. We do not have a source for the gauges. A plug is supplied with the unit (not shown in the pictures) to plug this port.
Please don’t ask questions that are explained in this auction or that you need to research on your own. "How is the fuel heated? How does the veg get to the unit? or can you use it to heat straight Diesel?"
We will gladly respond to sensible questions that have been researched and analyzed before hand. Please note that you are bidding to buy not later decide to forego payment. If you are not sure you want this item or don't have the cash then don't bid. Delivery confirmation required. Local pickup is available only after payment has been made. Shipping to AK or Canada will probably cost extra, so please contact me for a total if you are there
http://cgi.ebay.com/ebaymotors/2-in-1-Heat-Exchanger-Fu...QQrdZ1QQcmdZViewItem
Avoid problems. Upgrade all your brass fittings to stainless steel for CHEAP!
http://www.buyfittingsonline.com/
They are made in China but the machining looks fine.
This message has been edited. Last edited by: hheynow,
Running on
Great link. That's cheaper than I payed for some of my brass fittings.
Registered: 20 December 2006Reply With QuoteEdit or Delete MessageReport This Post
Location: Atlanta, GA | Registered: 31 July 2006Reply With QuoteEdit or Delete MessageReport This Post
Budda, that's a GREAT price on 30 plate exchangers
Sediment filters for cheap in bulk
Running on
Hi bill,
Hope your magnum is everything you wanted. They are performing very well in every application so far and yield about 173F oil from 190F coolant using the magnum only, no heated line or tank heater. As far as the Fram is concerned it's nice to save a few bucks but I would most definitely compare the quality, The Baldwin is a very high quality American made unit. I also like Wix filters, very good. But I do know Fram to be a lesser filter.
GreaseKing of Cali
www.greasekings.com
Sorry, I don't know how to edit a previous post, but here is the correct new listing.
http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&item=280147796801
Does anyone have a good source for relays to control solenoids etc. How about push lock fittings? Tigafila
Registered: 23 March 2007Reply With QuoteEdit or Delete MessageReport This Post
You can find relay kits, including wire and switch, int eh WalMart auto dept. They are marketed to use to install fog lights, but tehy will work for anything, and they are $10 a kit.
Thanks for the tip, wouldn't have thought of that. Anyone have a line on push lock fittings? Tigafila
275 Gallon totes/storage
For those that are in Georgia or close enough it makes sense and need large capacity storage.
  Powered by Eve Community Page 1 2 3 4 5 6 7 8 9 10
