Sponsors    Home    Forums  Hop To Forum Categories  General SVO Discussion    Lets put together a list of all the cheapest prices for parts...
Page 1 2 3 4 5 6 7 8 9 10
Transform a 55 gallon drum & 100# propane tank into Free Heat from a Zero Smoke Waste Oil Heater you can build in about 2 weeks.
· Heating Capacity:
70,000 Btu’s – 200,000 Btu’s (with adjustable fuel feed)
· Fuel Consumption:
0.6 to 2 gallons per hour
· Fuels:
-Waste Motor Oil
-Waste Vegetable Oil
-Transmission and Hydraulic Oils
-Mineral Spirits
-Machine Cutting Oils
-Synthetic Oils
-Gear Oils.
-BioDiesel or Fuel Oil at any ratio together or separately.
· Dimensions:
30” Diameter x 68" Tall + Fuel Tank of your choice.
· Weight:
~250 Lbs. (Without Fuel Tank).
· Electrical:
110 VAC / 15 Amp Circuit.
· Compressed Air:
Less than 0.5 CFM @ 80psi
· Controls:
Manual Ignition and Shutdown
· Construction:
Commonly available materials
· Skill Level:
Requires proficiency at Tig or Mig Welding, basic metal fabrication skills and basic electrical skills.
· Special Tools Required:
Mig welder or Tig welder, Torch or other way to cut plate steel.
· Lifetime Expectancy:
20 years
· Maintenance Interval:
3 days to 1 year depending on type of fuel used.
· Estimated Construction Costs:
Between $200 and $500 depending on your resourcefulness.
· Construction Time:
1 to 2 weeks.
http://www.murphysmachines.com/waste_oil_heater.html
you guys on the east coast should take a look at this ... keep your shop warm ...
Omar
www.omarsales.com
Just wanted to keep this post going
Location: Windsor, ON | Registered: 10 February 2007Reply With QuoteEdit or Delete MessageReport This Post
Here is my filter vessel that I have not made yet.
And here is my heated pickup that I made out of 3/4 and 1/2 inch copper pipe.
Sorry my camera was on micro mode. But you can figure it out if you squint.
This is the filter I bought for my truck and it is an amazing value. It is coolent heated,12v heated, water in fuel sensor and a thermistat. Very big, so could work on any vehicle. http://cgi.ebay.ca/ws/eBayISAPI.dll?ViewItem&item=14009...=cross_promot_widget
http://cgi.ebay.com/ebaymotors/Walbro-6067-similar-to-6...mZ140098847973QQrdZ1
This is a brand new lift pump that I purchased to use in my vegetable oil conversion, but I ended up using the 12v version of this pump (I have a dual 12/24v system) for various reasons. It comes with all mounting hardware. All sales are final. Buyer pays actual shipping. Feel free to ask any questions... Check out my other auctions for more veggie oil stuff...
Here's some details.
Walbro's 6067 pumps offer exceptional performance in a variety of demanding applications. The are perfect for automotive, truck, off-highway, agriculture, RV, and military or industrial applications. This pump is specifically for diesel fuels, though it is highly recommended on many websites for biodiesel and vegetable oil.
Because Series 6000 pumps have only three moving parts, there is practically nothing to wear out. Electronic circuitry, encased in epoxy to resisty shock and vibration, eliminates mechanical switching for exceptional reliability. A magnetic filter traps metallic particles. This pump has a 420 micron filter for diesel. Filters are easily accessible for cleaning.
The 6067 has a pressure rating of 10 psi. Series 6000 pumps are self-priming and have high lift capabilty. The 10 psi version is particularly useful with high heads, long lines and high lifts.
http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewIte...:watchlink:middle:us
This info is from this company's web site www.spinnerii.com The spinner II 60SE is a highly efficient bypass filtration device. It diverts a small sidestream of oil for processing and returns clean oil to the crankcase. the centrifuge opperates at speeds in excess of 6,000 rpm to force contaminates out of the oil. this force slings contaminates smaller than 1 micron out of the oil and packs them into a dense cake on the wall of the cleanable bowl. expendable items are the collection paper and rubber o rings which are readily available and inexpensive. The three ports are oil supply, oil return, and air supply, There is lots of other good info on their web site. This item is used but is clean and works fine. This unit is similar to the 960 except the bowl is aprox 1" smaller in height. The third picture shows the two units bowl and paper size.
I have sold a few to buyers who are using them to filter waste veg oil
Husky Collapsible Water Tank — 50-Gallon, Nonpotable, Model# BT-50/30 Oz. Vinyl
Bladder tank has many practical uses. Farmers and firefighters alike find applications for this easily transported tank. Easy to handle and folds down for compact storage. Nonpotable water tank can be used for gray water storage. Air tested before shipping to assure no defects.
http://www.northerntool.com/webapp/wcs/stores/servlet/p..._200327917_200327917
Omar, you always have interesting stuff, but there's one thing I don't understand; why do you post links to E-bay items when they always dead end into a "sorry, bidding for this item has ended" message? If you are the vendor, don't you know when the item has sold?
I always click on the link in the hope to learn more about the product, but the bidding is always over!
sometime the vendors has the product in their ebay store and sometimes it is just an idea that should be looked at ... O
Okay. Links to the store would be longer lasting, I think. Auctions end relatively quickly.
WEBB 525
COOLANT HEATED FUEL STRAINER
DIESEL, BIO-D, WVO
Lightly used (pre-tested) in a WVO system (shown still mounted).
Includes hose barb fittings and custom mounting plate with clamps.
Plate mounts to a flat vertical surface with four 1/4" bolts or studs.
Top is easily removed (v-band clamp with thumb knob) to lift out conical nylon mesh strainer screen (approximately 30 micron) for cleaning. Bottom ball valve drain.
Perfect for pre-filtering and heating your fuel of choice. Adds quite a bit of heat to the fuel. I had planned a multi-stage on-the-fly WVO setup but dicovered two tanks are really needed for that. Unit will be flushed out and well packed. Feel free to ask questions. Check my other auctions for related item(s). Thanks and best regards.
http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewIte...si_widget,osi_widget
Anohter low cost filter source ( but Fram) w/free shipping over w/$75 order - www.filterbarn.com
1994 F250 IDI 7.3 NA E4OD
I have added a "component Bargains" section to the VOconversionbasics info center "forum" for bargain/closeout/surplus stuff that might be useful for those converting to VO. I will try to keep it current...so please let me know if any of the items linked to there become sold out or otherwise unavailable.
Dana
दान
danalinscott@yahoo.com
http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewIte...m=&item=150132324909
THESE OEM SURPLUS ALUMINUM FUEL TANKS ARE HIGHEST QUALITY. AVAILABLE IN 40,50,60,80 AND 100 GALLON SIZES, SOME ARE POLISHED, DOES NOT INCLUDE MOUNTING BRACKETS. SOME MUST GO TRUCK FREIGHT BECAUSE OF DIMENSIONAL CONFIGURATION. CALL WITH YOUR REQUIREMENTS FOR PRICES, (WE JUST RECIEVED OVER 300 NEW ROUND ALUMINUM FUEL TANKS,22,23,25 & 27 INCH DIAMETER,) VARIOUS GALLON, CALL FOR SPECIAL PRICING) MANY HAVE FUEL CAPS, NO COMPROMISED INTEGRITY, ALL STRUCTURALLY SOUND. TANKS ARE FREIGHTLINER, STERLING AND WESTERN STAR OEM!! UPDATE, JULY 2006, WE JUST RECIEVED ANOTHER SHIPMENT OF TRUCK, MOTORHOME AND BUS,NEW! FUEL TANKS, SOME SQUARE WITH BUILT IN STEP, A NUMBER OF HYDROLIC TANKS. STEEL AND ALUMINUM.
$325
good luck Omar
www.omarsales.com
  Powered by Eve Community Page 1 2 3 4 5 6 7 8 9 10
