Home
Forums
General SVO Discussion
Lets put together a list of all the cheapest prices for parts...|
http://cgi.ebay.com/Biodiesel-oil-wvo-overflow-tank-ala...QQrdZ1QQcmdZViewItem
Biodiesel oil wvo overflow tank alarm I use this as my insurance that I have no leakage out of any of my tanks. Uses three aaa battteries. This is left over from my . Sensor can be mounted 56 inches away from base. Produces audible alarm when liquid reaches sensor prongs. Lets me set my automation and sleep good. A must for processors Brand new, never been used Omar www.omarsales.com |
Can you make the manual and installation guide freely available. I need to find out if this might be a worthy addition to my conversion. Send us also the physical dimension, connector requirement, temp sensor requirements etc. Jojo |
Hi JoJo,
If you go to the VO Control website: http://www.vocontrol.com/ Ray's got the owner's manual available as a PDF download. I printed it out (we're going to be testing one soon) and it's got everything you ask for. Craig www.PlantDrive.com 1972 Land Rover Defender/Series Hybrid, 300Tdi, Two-Tank PlantDrive system: HotFox, Vormax, Vegtherm Standard Wife's car: 2001 VW Tdi New Beetle: PlantDrive TwoTank system: Donut tank for start-stop, VegMax, Vegtherm standard, 3-3-port valves, controller |
http://cgi.ebay.com/Biodiesel-WVO-SOY-OIL-110gal-Sealed...QQrdZ1QQcmdZViewItem
Biodiesel WVO SOY OIL 110gal Sealed Reactor 4 BioFuel You are biding on 110 gallon biodiesel reactor that we have used for 6 months that we are selling because we bought a 400 gallon reactor. The biodiesel reactors are made of high quality steel with safety in mind. O |
http://cgi.ebay.com/ebaymotors/Vegetable-Oil-FILTER-HEA...mZ260031589378QQrdZ1
This is a Vegetable Oil Filter Heating Coil for converting your Vehicle into using Vegetable oil. It is made of 5/8" Copper Tubing with one 5/8" Flare nut on one end. This is made to use with Fleet Guard filter #FF5156 or Napa #3472. (Filter is not included). The inside measures approx. 3" by 3 1/2" high. winter is comming .... heat your wvo filter Omar www.omarsales.com |
I built this heated fuel filter following the Frybrid example for a waste vegetable oil conversion on my VW TDI. I used another one that I built for the TDI, which works very well, so this is up for auction. I used a fuel filter head from a 1983 VW diesel, an oil cooler from a 1998 audi. It uses VW diesel fuel filters with water separators that can be purchased at any auto parts store. On line I've found them for as low as $8 each. It uses a metric thread, so I had to use a special die to cut the threads and prepare the filter head to hold the fuel filter. Anyway, its worked well for me and is a much cheaper solution to heating fuel than the expensive models. I think it works just as well. http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewIte...2&fromMakeTrack=true |
Brand New Exactly as Pictured!! Made in the USA with Heavy Duty Components. The heat exchanger is a Low Pressure Drop/High Flow Unit with Multiple Aluminum Heat Transfer Plates for Maximum Heat Transfer. Waste Vegetable Oil, Bio-Fuel, Diesel, Fuel Oil, etc. always goes thru the included High Performance 4 Micron 1 Quart Filter. The filter is commonly available and reasonably price (Extra filters are $10 and ship free with purchase USA-48 States). Connect with standard 5/8" Heater Hose & 3/8" ID Fuel Line. The assembly stands 9 1/2" tall; the fittings can be rotated in any direction for a custom installation. For everything http://cgi.ebay.com/ebaymotors/WVO-BIO-SVO-Diesel-Fuel-...QQrdZ1QQcmdZViewItem found a few wvo heated filter on ebay www.omarsales.com |
have a few of these totes that I have been hoarding for storage. They had phosphoric acid in them and are totally clean. They have a two inch ball valve on the outlet and like a six inch manway on top. I can ship them if you like or deliver them for a fee or if you like you can pick them up. Email me on shipping issues. I take ebaying seriously and am a good seller. I will try to ship within 48 hours
http://cgi.ebay.com/ebaymotors/Biodiesel-Tote-275-gallo...mZ260033957495QQrdZ1 need something bigger than a 55 gal drum? Omar www.omarsales |
Omar, how much are your totes, and where are they located? I can't get to Ebay.
1985 Mercedes 300D, sold, Heat exchanger and injector line heaters, all single tank. 1997 E300D Benz using 50% diesel, 50% VO single tank |
jimsocrates@hotmail.com
here is the guys email he is located in Spokane, Washington I think there was a guy in FL selling them also have to check Omar |
I also have several in Lincoln, NE. These contained water soluble cutting oil. Clean up very easily. 275 and 330 gallon sizes.
Norman |
StorminNorman can you post a link? thanks Omar |
http://item.express.ebay.com/_Car-Truck-Parts__Elsbett-...rtsQQcmdZExpressItem This is the best kit you can buy to convert your diesel VW to wvo. More details here: http://www.elsbett.de/ Retails for right around $1000.00 with current conversion rates, but it's here in the U.S. now, so you save on shipping and wait time have fun www.omarsales.com |
http://cgi.ebay.com/Biodiesel-Production-Software-Homeb...QQrdZ1QQcmdZViewItem
In addition, the program will allow you to track and build historical information regarding your batches such as..... * Suppliers * Collection equipment * Collection rotation * Vegetable oil quality * Types of catalyst used * Titration results * Notes on pre-processing procedures, test batch results, test batch washing results, post processing notes * There is even a built in graph showing supplier quantities. * Sort and track batches by Supplier/Titration/Batch Completion Status/Processing Date/Catalyst/Feedstock Used and more * Include cost for Vegetable Oil/Methanol/Catalyst/Overhead/Magnesol * Track cost per gallon/liter * On screen on the fly conversion to metric * Built in tools... * Calculator * Liters to gallons converter * catalyst cost per gram calculator * Methanol/Catalyst cost per gallon/liter/gram converter * on screen audible count down timer * On screen and hard copy Batch Recipe including calculations for multiple carboys or single container Methanol/Catalyst containers and scale settings Biodiesel Production Software Homebrew WVO Conversion www.omarsales.com |
http://cgi.ebay.com/ebaymotors/Industrial-grade-filter-...mZ330032787002QQrdZ1 Industrial grade filter system GREAT FOR WVO/BIODIESEL bag filtering system great for wvo and biodiesel www.omarsales.com |
Free shipping anywere in the USA Box of 8 5"diameter x 119" long 1 micron prefilter bags 1 micron prefilter bags are ideal to filter waste vegetable oil. You can make several filter socks out of one tube ! Or you could make the mother of all wvo filters!!! We have a limited quanity of surplus Seamless Tube filter socks. Each one has a 5" hoop on one end... Anyway great price and like I said we have a limited quantity so order one or buy a box of 10 and stock up before they are gone!! we have to make room for more Heat Exchanges and Mercedes parts! this aution is for a box of 8 1 micron prefilter bags 5"diameter x 119" long http://cgi.ebay.com/ebaymotors/8-SVO-Filter-Socks-Veggi...mZ200031235997QQrdZ1 www.omarsales.com |
If I made 14" filter bags, I could make 8.5 filter bags with this length. You're selling this for $49.90. This means I am paying $5.80 for each 14" section that I make. Kindda expensive, don't you think. I can buy 1 micron filter bags from filterbags.com for $2.75 for a 14" bag and I don't have to worry about cutting and sewing them up. Just a thought that you might consider lowering the price to make it competitive. Jojo OOPS.. I made a bad booboo. Are you selling 8x of these 119" sections. If so, then this is very competitive in price. |
| Powered by Eve Community | Page 1 2 3 4 5 6 7 8 9 10 |
Home
Forums
