Sponsors    Home    Forums  Hop To Forum Categories  General SVO Discussion    Lets put together a list of all the cheapest prices for parts...
Page 1 2 3 4 5 6 7 8 9 10
For the Racor turbine filters 500, 900, 1000 the cheapest elements I have found other than the occasional great deal on Ebay is Marinefilters.com
95 Chevy PU 4x4
86 300SDL sold
83 240D Euro sold
81 VW Rabbit sold
Location: Islamorada Fl USA | Registered: 18 November 2003Reply With QuoteEdit or Delete MessageReport This Post
That Autohausaz place is great! I was going to buy a shutoff valve somewhere else for $70, but this place has them for $20!! And I got a air cleaner housing brace for $12 (retails over $100)! I also bought a new primer pump for less than $10. Plus I got 4 upper control arm bushings, a new oil filler cap, 2 brake pad sensors, new antenna seal, and a new breather hose all for $70 including shipping! I am a happy camper!
Registered: 21 August 2005Reply With QuoteEdit or Delete MessageReport This Post
Nick,
Which fuel filters will fit this oil cooler?
Originally posted by nick kaplan:
$8-15 110V or 220V in-tank water heater element
This filter is a tad more expensive than buying the parts and building one urself but more than half the price of the frybrid or greaseworks sandwhich design.
http://cgi.ebay.com/ebaymotors/Remote-Thermostatic-Oil-...dZ1QQsspagenameZWD1V
Registered: 14 August 2005Reply With QuoteEdit or Delete MessageReport This Post
Nick or others - Are you using that filter head ?
I wonder about the specs on "thermostatic" part and wheter it can be disabled . Also waht 2-10 micron filters are available for this filter head size ? - Thanka
1994 F250 IDI 7.3 NA E4OD
Concerning the "oil cooler" posted in the ebay auction (link in posts above).
This does not appear to be a heat exchanger, but a remote mount filter head and a sandwich "diverter" that mounts to the block.
The seller has the two assembled together to give the appearance that it would be a remote filter and a heat exchanger, but I do not believe that this is what it is.
I believe he simply put them together because they would fit.
If anybody has evidence otherwise, please do share (because I sincerely hope I'm wrong...I really would like it to be a heat exchanger).
Clem
Location: Columbia, MO | Registered: 29 November 2005Reply With QuoteEdit or Delete MessageReport This Post
many of these or simular have been continualy added to the DIY/FAQ thread over the years. In this thread there is a cheap part link for both building collection equipment and one for building a WVO powered vehicle etc.
_________________________
I have yet to test it out but I just got my 1000 watt bucket heater from Jeffers' Livestock for about $35 shipped. Check it out here:
http://www.jefferslivestock.com/ssc/product.asp?CID=2&m...8LTNQU3M6KGG8LEG3UD6
Location: Copperhead Road | Registered: 06 November 2005Reply With QuoteEdit or Delete MessageReport This Post
nope, not using that head...just looked really interesting. i really don't know if it is HE or not. i assumed it was. dana says it is not a flat plate. he didn't say if it was a different type of heat exchanger or something different all together???-Nick
Registered: 22 October 2005Reply With QuoteEdit or Delete MessageReport This Post
I'll explain my thoughts a little better, hopefully.
To the muscle car crowd, an external oil cooler is usually added with one of these "sandwich" adapters the goes between the block and the filter. This is plumbed in SERIES with the filter and simply allows a point for the hot rodder to "tap in" to the oil system so he can run a hose to and from the air-to-oil exchanger (typical, cheap transmission or oil cooler).
So when the seller says "oil cooler" he is referring to the "oil cooler adapter" that we see threaded onto the remote mount filter head...I think
The adapter will easily spin on to the remote filter head (it's designed to attach where an oil filter does), the seller, for whatever reason, has them attached this way. But I'm relatively certain that it's not a heat exchanger.
What he seems to have listed is a filter head similar to this and an oil cooler adapter similar to this
I just don't want to see anybody buy that and have it not be what they are expecting. Again, I hope I'm wrong, but I doubt it.
Clem
as your wvo heats up you made need an extra valve or two ... Roll Eyes Omar
6-port Pollak Fuel Director Valve
http://stores.ebay.com/evalero1_Fuel-Valve_W0QQcolZ4QQdirZQ2d1QQftidZ2QQtZkm
Location: Stouffville, Ontario | Registered: 08 September 2005Reply With QuoteEdit or Delete MessageReport This Post
This guy sold me a vormax for a pretty good price. $325 plus S&H
http://base.google.com/base/items?oid=1876570294768218131
Registered: 13 January 2006Reply With QuoteEdit or Delete MessageReport This Post
anyone have a contact for a cheap filter bag vessel/housing? thanks-Nick
The Hot Head looks interesting although I haven't heard of anybody using it.
http://vegpower.com/order/catpage.cfm?cat_selected=57&startrow=13
http://www.filterbag.com/x100.html
take a look at this link Omar
Another bag filer housing / vessel . Ths one uses standard bags - http://www.mcmaster.com - page 327 - 6870K58 .
What about a good "dry" vacuum gauge? Does anyone have a line on where to get one of these?
Registered: 25 October 2005Reply With QuoteEdit or Delete MessageReport This Post
use a sight glass that has meatal hose fittings... do not us the plastic screw in type they will crack (I ran one for about 5k before the plastic ends cracked in half)
http://store.summitracing.com/default.asp?Ntt=fuel+filt...target=egnsearch.asp
You can buy the sight glass here or Autozone has them for about $10.
do not over tighten the glass itself it can crack .. (I have done that too) however make sure it is not leaking air some times they vibrate loose just enought for a small leak so check for drips ... good luck Omar
www.omarsales.com
Originally posted by Omar:
....You can buy the sight glass here or Autozone has them for about $10.
It has been reported that some of these cheapies like Autozones are manufactured with a Zink compound metal. There fore they eventually fall apart with long exposure to veg. oil. Small materials may be breaking away from the zink housing into your fuel system durring its demize
Here is link to another related thread on parts purchasing -
http://biodiesel.infopop.cc/eve/forums/a/tpc/f/359605551/m/5011005131
  Powered by Eve Community Page 1 2 3 4 5 6 7 8 9 10
