Sponsors    Home    Forums  Hop To Forum Categories  General SVO Discussion    Lets put together a list of all the cheapest prices for parts...
Page 1 2 3 4 5 6 7 8 9 10
7 gallon aluminum tanks for $59.
Could be easily modified for VO use.
http://www.harborfreight.com/cpi/ctaf/Displayitem.taf?itemnumber=94801
_______________________________________________
Location: On my computer at this moment :) | Registered: 13 October 2007Reply With QuoteEdit or Delete MessageReport This Post
http://www.speedwaymotors.com/p/1633,59_Aluminum-Fuel-Line.html
91011429-10 1/4" Aluminum Fuel Line, 10 Ft
EA $8.99
91011429-20 1/4" Aluminum Fuel Line, 20 Ft
EA $12.99
91011430-10 3/8" Aluminum Fuel Line, 10 Ft
BX $10.99
91011430-20 3/8" Aluminum Fuel Line, 20 Ft
BX $14.99
91011430-30 3/8" Aluminum Fuel Line, 30 Ft
BX $18.99
91011440-10 1/2" Aluminum Fuel Line, 10 Ft
BX $14.99
91011440-20 1/2" Aluminum Fuel Line, 20 Ft
BX $18.99
91011440-30 1/2" Aluminum Fuel Line, 30 Ft
BX $22.99
91011441-10 5/8" Aluminum Fuel Line, 10 Ft
EA $20.99
91011441-20 5/8" Aluminum Fuel Line, 20 Ft
EA $24.99
91011441-30 5/8" Aluminum Fuel Line, 30 Ft
EA $28.99
good luck
Omar
www.omarsales.com
We have been running road tests on this aluminum bodied, 3-port WVO/SVO 12-volt fuel tank selector valve (also available in 24-volt) with easily-replaceable Viton seals. It has 12-mm ports with 1/2 inch NPT threads, a maximum operating temperature of 212° F, it is a bubble-tight valve (which means it is not going to leak like some of the other valves used for WVO) and it even has a small red light that tells you when you have switched to WVO! We have run this valve in VWs, Mercedes, and larger pickup trucks with good results.
Other details you may want to know:
Max operating pressure: 1 MPa (10 bar) = 145 psi
It will take two 3-port valves to replace one 6-port valve.
Email us about our 24-volt valves!
If you want to buy two or more valves we will combine shipping
$49
Omar
www.omarsales.com
This message has been edited. Last edited by: Omar,
http://cgi.ebay.com/ebaymotors...tZRaceQ5fCarQ5fParts
modified brass fittings for making a hose-in-hose (or more accurately, tube-in-hose) heat exchanger. These fittings seal well against the hoses-no need to double up hose clamps. There are no threaded fittings to leak except, unavoidably, the main compression nut. As long as this nut is not overtightened you will have a perfect seal. All parts are bubble tested to 50 psi. I will guarantee that no leaks occur at the soldered junction. They take paint well and look outstanding painted flat black.
You are buying the two fittings- enough to make 1 hose-in-hose any length you like. Picture two shows the simple construction and fluid flow. You will need to supply a length of 3/8 od tubing- aluminum works best and is available for less than $1/ft, but copper or polyethylene tubing will also work. You will also need a foot shorter length of 3/4 id heater hose, available at any auto store or tractor supply house (or less than $0.50/ft on ebay). Finally, four standard worm drive hose clamps complete the project.
This design uses 1" PEX tees and brass compression fittings. You may find these at larger hardware stores but will pay more for the fittings alone, and still have to custom lathe cut the 3/8 fittings to fit. I am able to offer this low opening price due to quantity purchases of the materials.
You can make a professional looking hose-in-hose for your WVO, SVO or beer brewing project for less than the cost to cobble one together from your hardware store. There's no reason a WVO conversion can't be functional and look good at the same time!
Custom request? Need male or female NPT on the hose return? Email me for a quote on custom fittings. I will substitute 5/16" or 1/2" tube fittings at no cost if request is made prior to auction completion.
new wvo products? ... anyone?
Omar
www.omarsales.com
Mid West Fuel Injection www.mwfi.com click the dieselstore,click Stanadyne FM100 filters and head $60.Damn good 5 micron filter with extra fitting to loop your fuel back into filter. Features easy bleed screw.
126 diesels yahoo groups
83 SD straight exhaust 94 Cobra
Cold air,real cold.Cobra electric radiator fan,Monark nozzles,5 psi electric fuel pump.85 amp alternator 12" subs.26 psi boost
0-60 10.8, 37 mpg highest
2 tank,wvo,boost guage ,line heaters,coolant heater Fattywagons customer.
Amazon.com
Good old place to go for glow plugs??? Wink
Damn right that's cheap! And these may be the only metric size plugs that will thread an American 1/8 pipe fitting so for alternative uses that's great stuff. They also fit several Ford models.
Dodge TD50 2.3L '83 HP injectors
SVO; D#2/BIO mix main tank
Greasecar 2 tank heated filters/ Racor HE/ dual FPHE (31plates total)
Fattywagon customized extra long single heater (15A) relayed on toggle.
120 gal saddle WVO fuel tank settling filtration.
DC OC20 80psi PS pump 1/4hp 1725rpm Westinghouse motor
Location: Sonoma Coast Northern California | Registered: 09 October 2006Reply With QuoteEdit or Delete MessageReport This Post
Muzak, Autolite GPs do not have a great reliability reputation. Anyway, their model 1110 is probably better suited to your application.
S. Caxambu
Location: Seattle WA | Registered: 11 August 2005Reply With QuoteEdit or Delete MessageReport This Post
[IMG]http://i.ebayimg.com/20/!Be48GLQCGk~$(KGrHqYOKkYErzqoyGBTBK+GU64JRQ~~_35.JPG[/IMG]
another glow plug wvo heater!
ebay
http://cgi.ebay.com/Svo-Wvo-Bi...?hash=item518e380d75
have fun
Omar
www.omarsales.com
This dual Magnet Mount Surface Thermometer is specifically designed to measure surface temperature. May be used on any magnetic surface. These instruments feature two high temperature alnico magnets that act as the thermometers base and hold the instrument in place on magnetic surfaces. The bimetallic sensor is located in a draft shield and is in virtual thermal contact with the surface to be measured. This gives the instrument a relatively quick response time. The thermometer reaches sensing equilibrium (stability) within three minutes
http://cgi.ebay.com/Magnetic-S...?hash=item3c9de47b81
something to look at
Omar
www.omarsales.com
  Powered by Eve Community Page 1 2 3 4 5 6 7 8 9 10
