Sponsors    Biodiesel & SVO Home    Biodiesel & SVO Forums  Hop To Forum Categories  General SVO Discussion    Can you loop the stock return instead of switching?
Closed Topic Closed
On my current setup Iam switching the returns, looping the veg. side and returning the stock side back to the factory tank but, Iam getting wvo in my diesel tank. So either install a delay timer for the return swiching valve or just loop the return all together and use no valve at all.I dont see why I cant do this.
83 chevy c30 6.2 crew cab
custom coolant heated tank
2 custom billet heated golden rod filter heads
facet pump
26 plate FPHE
thermocouples measuring temps in the tank,lines,IP and filter heads
running as of 5/16/06!
Location: Howell, MI. | Registered: 20 April 2005Edit or Delete MessageReport This Post
if you wanna go this route then you should leave the valve in place so that you can purge air out of the system, then put your loop T after the inlet selecter valve as close to the injection pump as possible. you will have to have a longer shut down period on diesel because you will be flushing out the pump and return lines. takes about 5 to 10 mins depending on your setup. i would just use a 30 second delay on switching. i have ran both systems and i feel that it is well worth it to have two valves.
-jared
Ride a Bike
Location: Cambridge NY, Plymouth NH | Registered: 21 April 2005Edit or Delete MessageReport This Post
Closed Topic Closed
