Sponsors    Home    Forums  Hop To Forum Categories  General SVO Discussion    Flat Plate Heat Exchanger Installations
Page 1 ... 6 7 8 9 10 11 12 ... 17
http://www.frybrid.com/forum/showthread.php?t=3127
Here is a FPHE install on a 240 D by BGKast
have a good Sunday
Omar
www.omarsales.com
First Question From Me...
I want to get a 16 plate exchanger. My trunk tank will be heated. I have a Kamatsu fuel heater that I will also use. I'll be using the "hose-in-hose" set-up to get under the hood. Would it be best to install the exchanger after the fuel valves so it gets a big shot of heat before the injectors...or should I install it before the valves? I'm in STL and it gets cold in the winter!
Ken
Location: STL | Registered: 04 September 2006Reply With QuoteEdit or Delete MessageReport This Post
I install my fphe (heat exchanger) before the valve and use a inline electric heater (glow plug inline heater or vegtherm type of inline heater 12v 15 amp.) before the ip... the electric inline heater keeps the wvo hot right before the ip ... just make sure you turn off the inline heater when you switch back to diesel! good luck Omar
www.omarsales.com
Originally posted by Omar:
a few guys have mounted the HE on it's back
no air problems yet... anyone have a problem with air??? Omar
www.omarsales.com
Omar,
That's the heat exchanger you sold me for my bus. It's been in there for about a year and there are no air problems that I've noticed. After warmed up (20 minutes of driving) I still get steady temps ranging from 185-195F, but it's ready to switch over much earlier.
Location: Tallahassee, FL | Registered: 22 January 2006Reply With QuoteEdit or Delete MessageReport This Post
http://www.benjaminellis.net/benjaminellisdotnet/projects/WVO/TDI.htm
VW TDI Waste Vegetable Oil conversion
take a look at this install! great job Benjamin!
have a good read Omar
www.omarsales.com
FYI everyone there has been a price increase on Flat Plate Heat Exchangers from the Manufacturer ...
I will share a quote from the email I received
Our president and general manager just went to Japan to
negotiate with the stainless steel supplier; the pricing is breaking the
record almost every single week, and our supplier is afraid of even giving
out quotes. Current material prices have increased enormously. Copper
increased nearly doubled since the beginning of this year, and nickel
price rose by 2.5 times as well, and nickel is one of the main elements
for stainless steels.
Have a good week Omar
www.omarsales.com
anyone out there in NY? may want to read this
have a good weekend Omar
Major NY newspaper is doing a story for xmas with a "green xmas" theme. One of the shots they are looking for is a green car that could be converted to run off of vegetable oil. The shoot will take place in NYC. They are looking for something vintage. Preferably 70s or 80s. They want to be authentic as possible, so they need a car that could be converted that is in green in color. The car would not be driven, everything is fully insured, and the owner is paid for their time. Contact Chris at 212-929-3909 or e-mail at info@cooperclassiccars.com
http://www.frybrid.com/forum/showthread.php?t=5034
here is a link to a 26 plate HE install in a 300SD
have a good weekend
Omar
www.omarsales.com
Here is a fphe install on a MB in Australia
see more at this link
http://www.biofuelsforum.com/svo_users/1014-mercedes_300d_conversion.html
How the fphe works
Omar
www.omarsales.com
Hey Omar
Just received my FPHE today
Thanks.
This message has been edited. Last edited by: Meshbackhats,
Location: akron, Ohio | Registered: 18 November 2004Reply With QuoteEdit or Delete MessageReport This Post
Has anyone done any tests to see what kind of improvement in VO temps one might see after upgrading a 16 plate to the next size (24?).
As far as Omar's shipping goes. Just give it a little more time. The day my FPHE arrived, the USPS shipping status was identical to yours.
(¯`·.¸¸.->1986 300SDL | 15,000 miles on WVO since 11/25/06<-.¸¸.·´¯)
Self-designed + Built | ArcticFox+HOH+HotHead+FPHE+Vegtherm | Veg in OEM Tank
Location: Trenton, NJ | Registered: 25 June 2006Reply With QuoteEdit or Delete MessageReport This Post
[QUOTE]Originally posted by grindMARC:
Has anyone done any tests to see what kind of improvement in VO temps one might see after upgrading a 16 plate to the next size (24?). QUOTE]
Yes...I and others have tested quite a few various sizes (both larger in dimension and more plates) to see what the effect is of greater surface area on VO temp.
Generally FPHE are only able to raise the the VO temp to around 20° cooler than the indicated (at the FPHE inlet) coolant temp.
Also generally...although more VO/coolant interface (through more or larger plates) will raise VO closer and closer to the same temp as the coolant exiting the FPHE there is a sharply diminishing return on the investment of larger FPHE.
And since the post IP temp of VO is usually not changed much by a FPHE that raises the pre-IP VO temp to over 150°F adding a larger FPHE may have no overall effect. How close to the coolant inlet temp is you VO outlet temp now?
Dana
दान
danalinscott@yahoo.com
On this Blog you'll be able to follow my progress on the conversion of a 1976 model W123 Mercedes to run on used cooking oil (UCO), or waste vegetable oil (WVO). I'll post stuff and upload some pics to show you how to do this yourself on your own vehicle Smile
Bruce Taylor
http://oztayls.blogspot.com/2006/07/it-all-comes-together-conversion.html
http://www.3cats.com/vJet/
Flat plate Heat exchanger helps out greasecar kit WVO temp at IP
Omar
www.omarsales.com
evan
Jetta 96 1.9TD 16gallon spray tank, filter in trunk, hoh, fphe, lift pump, ILH
http://biodiesel.infopop.cc/eve/forums/a/tpc/f/159605551/m/4151080291
  Powered by Eve Community Page 1 ... 6 7 8 9 10 11 12 ... 17
