Sponsors    Home    Forums  Hop To Forum Categories  General SVO Discussion    Flat Plate Heat Exchanger Installations
Page 1 ... 4 5 6 7 8 9 10 ... 17
Sure, I'll post 'em when I get a few shots taken. Really not much different than what is pictured above.
Location: SC | Registered: 31 August 2004Reply With QuoteEdit or Delete MessageReport This Post
I thought I should finally post my GPHE installation -- although it is pretty much the same as those already pictured.
I have a dual tank setup with the stock tank for veggie but no tank heat. I use one six port valve and a three port valve for switching: tank selection, filter selection, and return. I'm using return to both tanks for now. The 26-plate heat exchanger works great and I'm getting 160F+ temps after the FPHE and 150F+ after the filter. That is in cold weather (well, cold for california).
Thanks again, Omar!
79 Mercedes 300D. Two tank set-up. FPHE and injector line heaters.
86 6.2L Suburban 4x4. Two tank with two electric pumps. currently running diesel only.
Location: West Texas | Registered: 09 November 2005Reply With QuoteEdit or Delete MessageReport This Post
Hi gang - very informative thread.
One thing I was unable to surmise: does anyone suggest placing a heated filter *after* the FPHE as cheap insurance? I worry something will corrode or fall off the HE, causing havoc in my IP. But conversly, I worry that placing the filter last would negate any heat gain created by the HE.
Dan
Location: Raleigh, NC | Registered: 12 April 2006Reply With QuoteEdit or Delete MessageReport This Post
Yes..in nearly all cases I advocate this configuration. No reason that a fliter should cool the VO and IMO a filter shoudl be the last components the oil sees before the IP.
Dan
Dana
दान
danalinscott@yahoo.com
Thanks Dana - I defer to your expertise!
I use a small sight glass filter before the ip... O
Bought a 16 plate HE from BK's buy and it went on a 300D. Temps from the Lovecraft conversion were at best 100 F. Ambient temps have been in the high 60's as a rule. It also had a new hotter thermostat installed in an attempt to raise temps from the filter. Now with the FPHE installed, temps around town are consistently at 180F. I guess they do what they are supposed to!
Omar; By the way, my check's in the mail for the 26 plate.
Michael
Location: CA | Registered: 04 December 2005Reply With QuoteEdit or Delete MessageReport This Post
do you have any photo's you could post? glad to hear you have some hot wvo at the IP! O
www.omarsales.com
Having the filter last may be the most conservative approach . However, you will not get the full benefit of the very hot heat exchanger oil when you first switch over . I wonder what this does to the IP and injectors over time. I suggest wrapping a coolant heater (like Dana's coolant hose type filter around the filter and insulating it well) to at least warm that initial slug of oil to be heated .
Dan
1994 F250 IDI 7.3 NA E4OD
Ike
Concerning a HE, would there be any danger/problem with running diesel fuel through a HE as well as WVO? In order to place my HE as close to my IP as possible, I have to place it n a fuel line that is shared by both WVO and diesel.
Location: Goldsboro, NC | Registered: 17 June 2005Reply With QuoteEdit or Delete MessageReport This Post
Ike,
I know this thread is long, but your answer is in here. (I think I asked this question before myself!) If you have a chance, thumb (or click) through it. The concern is lubrication of the IP.
Goodluck
Location: Tallahassee, FL | Registered: 22 January 2006Reply With QuoteEdit or Delete MessageReport This Post
Ike,
Goodluck
While the libricity of diesel fuel drops rapidly with temperature rise, the presence of even 1% veg oil in the diesel can provide a significant lubricity improvement in the diesel , so that heating of the diesel is not an issue in relation to lubricitation of the IP.
Ike
Thanks for your input. Mr. Ryan Mix, you're right, I admit I took the lazy way out. I usually try and find the answers before I look. Anyway, thanks for the info, it will help me mount the HE as close to the ip as possible.
Ike
No problem, Ike. I hope I didn't come across the wrong way. It's hard to tell without voice inflection- strictly informational.
Smile have a good weekend Omar
Take a look at this PSD install by the
Professor
http://www.frybrid.com/forum/showthread.php?t=4388
Omar
www.omarsales.com
Fellas think sticking the fphe right next to the bottom drain of an AL tank will be enough heat to get the oil flowing in winter?
Location: nj | Registered: 06 September 2005Reply With QuoteEdit or Delete MessageReport This Post
Not if you live in a cold climate.
Dana
दान
Professor's
2003 PSD is an early year model - 7.3.
see more at this link
http://www.frybrid.com/forum/showthread.php?t=4388&page=1&pp=10
O
www.omarsales.com
off topic:
Yep it never fails... speed boats, off-roading, hot-rodding...
there's always that one guy that can't be happy with average and just has to blow everyone out of the water with perfection... lol Big Grin
reminds me of a guy I know with an all t-304 stainless steel chassis for his dragster...
Location: iowa | Registered: 19 December 2005Reply With QuoteEdit or Delete MessageReport This Post
  Powered by Eve Community Page 1 ... 4 5 6 7 8 9 10 ... 17
