Sponsors    Home    Forums  Hop To Forum Categories  General SVO Discussion    Flat Plate Heat Exchanger Installations
Page 1 2 3 4 5 6 ... 17
Looks pretty, doesn't it?
Location: Tallahassee, FL | Registered: 22 January 2006Reply With QuoteEdit or Delete MessageReport This Post
I made these brackets to mount the heat exchanger, but then realized that there was no room to mount it.
It ended up fitting nicely snug on top of the transmission.
Here you can clearly see that there was no room to mount it, but it's pretty secure where it is.
ANY marine store will show you a SMALL heat exchanger..50 bux. TROU
Registered: 02 January 2005Reply With QuoteEdit or Delete MessageReport This Post
Ryan,
I agree with John above re the angle of the installation. The instructions on these units state/picture to install them upright. I am not sure why this is, but it may be to stop a build up of materials in the fine corrogations inside the HE as John says, or minimising air locks is another explanation I've heard.
Your insulation around it looks pretty good, and I am impressed by your temperature figures. They are better than mine, so the trouble you went to with insulation, and maybe even laying the unit flat, is obviously working as intended.
My instal is at http://members.iinet.net.au/~tim.law/landcruiser/heater/
Regards
Tim
Location: Perth Western Australia | Registered: 30 December 2005Reply With QuoteEdit or Delete MessageReport This Post
The reason for mounting them vertically (in both planes) is to avoid air bubbles in them which reduces liquid-plate contact and reduces the effecienvy of the FPHE.
Remember that the connections for one or other fluid will be on the low side and thus the high side of that series of chambers will have a significant amount of air present, which cannot be purged from the FPHE by the turbulent flow.
Mounted vertically, only a small amount of each chamber will have air present (above the top connections).
hey all
I have yet to install my FPHE b/c I was holding out for exact fittings to mate w/ the GB4 (3/4" GHT) thread on the outlet ports
but how about threading the inside of the ports instead?
looks like they'll take a 1/2" NPT thread
and if I hold it upside down when I'm cutting them, presumably any loose cuttings will fall out
then a brass barb will fit right in there
any reason not to do it this way?
thanks
rOLf
2 yrs and 100k mi on WVO - '93 VW EuroVan 2-tank w/ tank heat/HOH/10-micron heated Fleetguard, FPHE
Location: NE USA | Registered: 09 April 2005Reply With QuoteEdit or Delete MessageReport This Post
I know Dana L. rethreaded his to accept NPT fitting, he said it took 10 minutes with a thread cutting die. I tapped the inside of one side of mine for 1/4" NPT, for the fuel barbs, the threads were a little shallow but I put on sealer and it hasn't leaked yet.
I believe if this is done on the coolant inlet/outlet it will restrict coolant enough to significantly diminish the final temp of the VO passing through..at least on larger engines.
thanks
Dana
दान
danalinscott@yahoo.com
Dana, he said he's starting with a 3/4" fitting, not a 1/2" like we got. That should be big enough, right?
Yup..my bad!
Reading too fast. Roll Eyes
Thinking too slow. Frown
Dana
दान
Holy smokes! It’s still in the mid 30sF here in Rochester, NY, and my heat exchanger is really cooking now! I took a trip to the dentist (about 15 minutes expressway travel) today and my fuel was steady between 175-185 without use of the Vegtherm! I’m a bit anxious about warmer weather and will have to do some research on how hot is too hot. Maybe the insulation is a bad idea...
Re: Installation orientation ( I like the sound of that...): Thanks for the info. I had not thought about sediment and air build up in the heat exchanger, but I'm not too worried about it. I got another heat exchanger once that suggested the same, but said when upright installation is not possible, laying flat is acceptable- just never downside-up.
That's a good thing. You don't have to worry about warmer weather, the oil will not get hotter than the coolant temperature.
Location: Denver, CO USA | Registered: 19 June 2003Reply With QuoteEdit or Delete MessageReport This Post
My pollak is going to die if I get heat like that Big Grin
Registered: 05 January 2006Reply With QuoteEdit or Delete MessageReport This Post
[/QUOTE]That's a good thing. You don't have to worry about warmer weather, the oil will not get hotter than the coolant temperature.[/QUOTE]
Isn't it possible that the coolant temp may be hotter in the summer?
Not if your thermostat is operating properly. The cooling system is designed to keep the engine at a constant temperature.
Yup..my bad!
actually, Dana was right
I have the same FPHE you guys got - was quoting wrong size pipe - opening is 1/2" true = 1/4" NPT
I got to the store and thought exactly what Dana said and ended up getting female (external) NPT adapters so as not to restrict coolant flow
if junction feels iffy I'll have threads cut to NPT
(I think adapters for these particular threads may be available though - in the US they seem to be called GHT (garden hose thread) instead of GB (Europe/Japan))
rOLf
I got mine in, but I can't get the whole system to burp (this is the first time it is up and running) There is a picture on my burping thread: http://biodiesel.infopop.cc/eve/forums/a/tpc/f/159605551/m/8121080531
The FPHE should be downstream of the fuel selector valve.
I'm not doing this
do you really want 180° diesel fuel in your IP?
rOLf
  Powered by Eve Community Page 1 2 3 4 5 6 ... 17
