Sponsors    Home    Forums  Hop To Forum Categories  General SVO Discussion    Flat Plate Heat Exchanger Installations
Page 1 ... 12 13 14 15 16 17
WVO dual tank setup on a HDJ81 Turbo Diesel Landcruiser DI
http://www.biofuelsforum.com/svo_users/4541-wvo_dual_ta..._landcruiser_di.html
have a good read
Omar
www.omarsales.com
http://www.valvoline.com/images/products/productpages/bottle_bot_ZXG051.jpg
what coolant do you use in your system?
G-05® Antifreeze/ Coolant
http://www.valvoline.com/pages/products/product_detail.asp?product=10
remember to flush you coolant system once a year and use distilled water
Omar
www.omarsales.com
FPHE in Toyota truck. I agreed with welder's conclusion that perfectly vertical wasn't necessary, plus limited space led to a ~45° orientation. Hot coolant in at the bottom right, cold fuel in at the upper left. There were no problems purging air from the system.
The FPHE is connected between the fuel feed pump and the fuel filter and all connections are under a positive pressure of about 30PSI.
This message has been edited. Last edited by: john galt,
'89 Toyota 3.4L TDI + FPHE
BD+ULSD+VO+JetB blends
FPHE in Toyota truck with insulating cover by
http://otterbaysuits.com/
FPHE in Toyota truck with 2 layer Arctic insulating cover by
The insulating covers reduce the warm-up time/distance by 25% to 30%.
The two layer Arctic FPHE Cover is shown before installation in the next message.
winter is on it's way something to think about
good read
http://www.burnveg.com/forum/viewtopic.php?t=189&postda...storder=asc&start=45
have fun
Omar
www.omarsales.com
I installed a 30 plate heat exchanger from Omar this weekend. I am extremely pleased! I am not a mechanic, and did not install my Greasecar kit on my 7.3L Power Stroke myself. However, after reading the forums, I figured I could do this pretty easily and I was right. No problems at all.
I used Permatex Hi-Temp thread sealant for the hose barbs on the FPHE. I mounted the FPHE vertically, as the manufacturer’s directions stated, under the hood with a large hose clamp threaded through two holes in the body. I ran all the hoses and insulated them with foam pipe insulation.
I cranked the engine, it sputtered for about two seconds and then ran normally. No problems with air in the fuel lines. I got it up to operating temp and checked for leaks, and there were none, so I took it out for a ride. Earlier in the day (it was 70 degrees air temp) I had driven it about 40 miles, and the veg oil temperature was 125 degrees. That was the hottest temperature that it reached. When the engine reached 180 degrees, I switched to vegetable oil. The initial temp of the veg oil was 94 degrees. Within one minute the veg oil was 124 degrees. Within three miles the veg oil temp was 160 degrees. As I have continued to drive it, I have found that the veg oil temperature reaches within 12-15 degrees of the coolant temperature quickly.
Registered: 05 September 2008Reply With QuoteEdit or Delete MessageReport This Post
Here's one of Omar's 26 plate's on my 1993 Chevy 6.5. I used a heavy duty 5mm thick dirt bike inner tube to insulate it from vibrations and to keep heat in. It's attached to a steel plate with a large hose clamp. I also added 3/8" rubber cushions on the bottom.
1985 Mercedes 300D with Greasecar kit.
1993 Chevy 3500, my own conversion.
Location: Philadelphia, PA | Registered: 19 March 2008Reply With QuoteEdit or Delete MessageReport This Post
1998 VW Jetta TDI VO Conversion Installation
http://www.nickpisca.com/Alamo/InstImages.html
good read have fun
Omar
www.omarsales.com
Kirkh,
Where did you mount your heat exchanger on the 7.3L? I have mine horizontal on the frame rail and am only getting 120 - 130 F temps on VO.
Scott
2000 F250 7.3L Biodiesel
2006 Jetta TDI Biodiesel
4.5 kW Grid Interconnected Diesel Genset on WVO
Registered: 01 March 2008Reply With QuoteEdit or Delete MessageReport This Post
http://biodiesel.infopop.cc/eve/forums/a/tpc/f/159605551/m/6421006031/p/7
what is your coolant temp? did you insulate your fphe and wvo fuel lines? how did you plumb your coolant flow for you wvo system?
omar
www.omarsales.com
The truck is a modified system with a 203* thermostat, DP Tuner and flow through regulated return with a pressure regulator set at about 64 psi.
My coolant comes from the head to the insulated FPHE mounted down along the rail. The coolant then flows to a hot head filter and on to a tank in the bed with a homemade hot stick heater and returns to the pump side of the cab heater line. The lines are all insulated.
The fuel flows from the heated pickup to the FASS pump, hot head filter and then to the FPHE. The system uses check valves and a DPDT fuel pump relay to switch between the stock pump/filter and the WVO pump and filter. These lines are also insulated.
I do not have an accurate water temp guage on the truck, just the factory idiot guage. My fuel temp guage is located on the switching manifold where the two fuel systems are distributed to the head. I killed my IR temp gun in a vat of oil so I need to get a new one and start shooting temps.
Your flat plate heat exchanger should be the first unit to have the coolant from the head ... then your heat exchanger in the wvo tank… heated wvo filter... you need to find out your coolant temp. Did you plumb your fphe with opposite flow? Just a thought Omar
You can get more heat out of your FPHE if you insulate it with some high density foam (recycle an old sleep bag mat) do your fuel lines also
let us know what happens
Omar
www.omarsales.com
The FPHE should have it's own coolant heating loop from the head to the FPHE and back to the pump inlet. All the other coolant heating devices can run off another coolant loop. Don't put the coolant heated devices in series; that will restrict the coolant flow through the FPHE.
  Powered by Eve Community Page 1 ... 12 13 14 15 16 17
