Sponsors    Home    Forums  Hop To Forum Categories  General SVO Discussion    Flat Plate Heat Exchanger Installations
Page 1 ... 10 11 12 13 14 15 16 17
Sideways is not the best way to install a FPHE. But better to have the fuel ports on the upside than the coolant. Hopefully there is enough coolant flow to prevent a buildup of air in the top half of the FPHE in the coolant passages.
Dana
दान
danalinscott@yahoo.com
1980s Semi
This daily hauler has an 80 gallon veg tank and an 80 gallon diesel tank. No onboard collection necessary as it’s home every night! This truck is plumbed with our new removable hydraulic style stainless fuel and coolant lines. Equipped with a Racor 100
http://www.enviofuel.com/?page_id=36&thumbpage=1&galpage=1&picture_id=21
have a good read
Omar
www.omarsales.com
On this Blog you'll be able to follow my progress on the conversion of a 1976 model W123 Mercedes to run on unmodified vegetable oil (UVO), or waste vegetable oil (WVO). I'll post stuff and upload some pics to show you how to do this yourself on your own vehicle Smile
good read
blog spot
http://oztayls.blogspot.com/
Originally posted by Mr Ryan Mix:
I'm sorry folks- my pictures disapeared because yahoo photos generates a link for the picture, but it is time sensative. I'll have to upload them one at a time...
Here is the heat exchanger with insullation.
Does anyone know the name for the role of steel used to bend around the FPHE shown at the post above?
Sounds daft but cant find anything on ebay -
David
Edit: sorry, just realised the photo does not display from the quoted post but it does appear in quite a few others.
Location: England | Registered: 21 December 2007Reply With QuoteEdit or Delete MessageReport This Post
Originally posted by bones:
...Does anyone know the name for the role of steel used to bend around the FPHE shown at the post above?...
its called something Strap LOL. I looked all over too since you mentioned it and cant find it either though I've seen it. Might be something like "Nail Plate" or "nail strap"
Here is a hardware page with some pics of things simular he might have made it from
_________________________
Thanks Coach, will take a look -
Heres a couple of pic's of heated filter together with FPHE, looks kinda small compared to the 20/30 plate jobbies but this is custom made a really kicks out the heat.
After testing I moved everything together as close to the IP feed as poss to avoid loss of heat.
With both of the above achieve mid 70c at the Pollak feed.
David
Quick Question,
I just ordered a FPHE from Omar and have been researching how to plumb it in. I am running a stock Greasecar on a 2000 Jetta TDI. I am thinking about putting it in parallel to the heated filter. I think that would give the lowest resistance. How much resistance does a FPHE have? If I do it that way will the majority of the coolant go simply to the filter side and avoid the FPHE. Since it is a Jetta with a tight engine compartment I would like to avoid an extra ball valve if possible. What's everyone thinking?
2000 Jetta TDI w/ Greasecar+FPHE 32,000 miles on grease thus far!
Location: Lawrenceville, NJ | Registered: 24 October 2007Reply With QuoteEdit or Delete MessageReport This Post
The FPHE will probably be less restrictive than the rest of the GC coolant plumbing. But it will remove a lot of heat from the coolant before it gets to the rest of the system.
Normally I suggest a seperate parallel loop for the FPHE with a balancing valve. These are avaialable in fairly compact form. For more info on this look at: http://www.websitetoolbox.com/tool/post/voconversionbasics/vpost?id=2273794 The bottom schematic may be the best option though you might want to fine tune the second loop using a hose clamp or heavy ziptie.
Dana
दान
Another question. Now that I know how to plumb it what size hoses does the GC system use. I thought it would be good to match their size. Also any thoughts on where I could get these additional coolant hoses to make the plumbing work?
Rather then reinventing the wheel I'm going to ask another question. Does anyone have any wise words on where and how to mount a FPHE on a 2000 Jetta TDI with a stock Greasecar? I'm sure people have done it before. If anyone could pass some pics my way that would be great. Thanks!
knabe189
Is this heat exchanger different than the one i can buy at my local plumbing wholesaler? I looks identical and both are copper. Is this unit manufactured just for wvo or is it just a standard heat exchanger?
95 Chevy K1500 6.5 TD not on WVO yet but soon!!
Location: Rochester, MN | Registered: 22 January 2008Reply With QuoteEdit or Delete MessageReport This Post
Give us a pic and price for the one from the plumbing supply...
Hello Folks. Since everyone here was so helpful I thought I would give back. Here is a pic of my setup in case anyone else is need of placement ideas for FPHE in a Jetta w/ Stock Greasecar system. I put it right next to the heated filter which worked surprisingly well. Coolant goes down and out, wvo goes up and out. Temps are running 180ish after IP after 10 min. They used to be 130 after 1/2 hour. Thanks for everyone's help!
-knabe189
2000 Jetta TDI w/ Greasecar, FPHE, TDIheater 15,000 miles since Oct '07!
  Powered by Eve Community Page 1 ... 10 11 12 13 14 15 16 17
