I think that is correct if I understand you.. Let me repeat what I think I am hearing from you: If you plug the banjo bolt, no returning fuel will enter the stock filter. All the returning fuel will go to the tank. (or to a valve in my case) |
That is what I am thinking. I ask this question on another forum and had one reply that some fuel may seep past the threads of the bolt. That sounds very posible to me, so I will leave on a stock filter and plug the feed line holes with something.
Here is a 1979 VW rabbit install 16 plate HE with coolant wrap wvo filter. Wvo tank is a cut down (6 3/4 inch high ) 55 gal. drum fits in the spare tire spot ....
Omar www.omarsales.com |
Mercedes 240D install
more photo's of install of 240D http://www.imagestation.com/album/pictures.html?id=2092843616 |
[URL=
]wvo road test [/URL] Video of 16 plate Heat Exchanger 175F at the IP in a 300sd Mercedes Omar www.omarsales.com |
http://www.youtube.com/watch?v=9sQwccnH3KM
Our Generation on the history channel does a piece on a company in Pittsburgh that converts diesels to run on waste vegetable oil. check out the flat plate Heat Exchanger install! Fossil Free Fuel www.fossilfreefuel.com great clip Omar www.omarsales.com |
clean install, are those hydraulic hoses and fittings?
06 VW Jetta TDI |
1984 MB 300 SD Turbo |
read about his veggie trip ... http://www.backcountrymagazine.com/conor1.html have a good read Omar www.omarsales.com |
Down under truck Here are some photos of the SVO conversion recently installed by Fitian (MB300D81) in my ’97 Mitsubishi Triton ute. Once again Fitian has done a very nice job despite severe space constraints, there is certainly a lot less vacant real estate under the bonnet of a Triton compared to a MB300D. It is a two-tank conversion, with veg oil going in the main tank and bio in a small start-up tank I made to fit against the front bulkhead of the ute back. There is one 30 plate heat exchanger before the CAV filter and 6 port valve, and a second 20 plate heat exchanger before the injector pump. http://www.biofuelsforum.com/svo_users/3347-mitsubishi_..._svo_conversion.html have a good read Omar www.omarsales.com |
Hi Omar.
Thanks for including the link to cleangrease. Although many svo kit & component vendors offer advice and a few wvo collection parts, I agree with cleangrease that there should be more products and info available for wvo recovery. I know that some will disagree with what I just said, but consider the testy little interactions that come by every time someone starts selling wvo refineries with no dewatering mech or no support basket for bag filters which strech with hot oil. Sure there is a library of old posts here on how to refine wvo, but not every svo user/enthusiast knows about our forum yet. Sorry to go OT, but the link needed a little mention, I thought. |
http://www.alaskavegoil.org/golf The No-Frills Alaska Special conversion on a 1992 VW Golf, with an early 1981 1.6NA diesel engine. have a good read Omar www.omarsales.com |
Few words about thread sealant
http://www.greasecar.com/forum_topicview.cfm?frmtopicID=14091 Permatex 14a. It has teflon in it and works great. One down side is that you need to let it set good....3 to 4 days, before use under preasure. Hotwheelbill http://www.youtube.com/watch?v=5dRtZ2tLwII here is a video clip of permatex 14A install good luck Omar www.omarsales.com We use and recommend Permatex High Temperature Thread Sealant, with Permatex High Performance Thread Sealant as a close second. Both have Teflon, neither require any curing time. NAPA usually has both, and both are available online. Craig Craig Reece You gotta go with Permatex 26B---Hi Temp RTV Silicone. Bullet proof stuff. Tom yaz |
the system was putting out some serious heat. this particular 300SD now has a veg therm and a FPHE! probably one of the only vehicles really ready for a harsh Chicago winter. http://www.greasecar.com/forum_topicview.cfm?frmtopicID=16672 |
| Powered by Eve Community | Page 1 ... 9 10 11 12 13 14 15 17 |
