Sponsors    Biodiesel and SVO Forums Home    Forums  Hop To Forum Categories  Straight Vegetable Oil (SVO) as fuel  Hop To Forums  General SVO Discussion    Best current filtration method? Best simple method? Uplflow?
I've had a centrifuge system years back and found it to be ok. I used it for used motor oil and although it took a lot of the sludge out, it was still not enough to not coat my injector tips with carbon. Maybe it wasn't the filtration... but I will say it still looked black after the CF.
I've read a while back that upflow filtration is the new best way. Is this still the case?
95 Ford Powerstroke Diesel 2 tanks diy
84 GMC 6.2 Diesel
Had: Several Diesel Mercedes
Location: Missouri | Registered: December 19, 2006Reply With QuoteReport This Post
There really a best simple method. To a large degree it is a matter of time and the available space you have.
If you are talking about just pouring it in at one end and getting a decent product at the outlet with no other immediate effort an upflow filtration system is okay. At some point however work is needed to clean the set up of the crap that accumulates.
Registered: January 21, 2009Reply With QuoteReport This Post
