Some Pics of my little contraption..
(Yes the legs are too short..was that cut twice after measuring once or cross your i's and dot you t's?) http://www.greenroadsupply.com/images/tank4.jpg http://www.greenroadsupply.com/images/tank3.jpg http://www.greenroadsupply.com/images/tank2.jpg My little scheme is to let the cubbies settle for a few weeks. Drain off the good stuff, pitch the creamy water. At this point the oil already pours "clear". Let the oil settle in the tank, apply heat if needed. Drain water and any other crap from th bottom. Attach filter, pump, let circulate as long as I please then into the containers. I would have to think I have put 10K at least on oil, 20K overall. This wont work I imageine for very dirty,watery oil, but I have generally good oil. |
