Sponsors    Home    Forums  Hop To Forum Categories  General SVO Discussion    HELP ME DANA!!!
Closed Topic Closed
Dana,
I RECENTLY DISCOVERED A MINOR PROBLEM WITH MY JETTA TDI... I RUN A SINGLE TANK SYSTEM WITH A HEATED FILTER AND INJECTOR LINE HEATER.. I RESIDE IN FLORIDA WHERE ITS USUALLY 80 DEGREES OR HIGHER. mY BLEND I USE IS 20% RUG AND 80% WVO...
THE PROBLEM: WHEN MY TANK GETS TO ABOUT 1/4 IT TAKES A BUNCH OF CRANKING TO GET IT STARTED. AFTER IT STARTS, SOMETIMES IT STALLS AFTER ABOUT TEN SECONDS OF IDILING... EVNTUALLY I GET IT STARTED AND ONCE THE ENGINE IS AT TEMP , IT WON'T STALL.
DO YOU HAVE ANY IDEA WHY THIS WOULD BE HAPPENING?
Location: south florida | Registered: 05 June 2006Edit or Delete MessageReport This Post
The rug and the veggie oil are separating from each other and the oil is going to the bottom.
I have to say I use a lot less than 20 percent diesel for start up and flush on my two tank system.
"I don't get it" ---Tom Hanks as Josh in the movie Big.
Robert
In Fort Lauderdale running a 1985 Gold Mercedes 300d custom aluminum tank (18) gallons looped return with return to diesel tank. HOH wraped filter FPHE. Greasecar valves.
Location: Ft Lauderdale, FL | Registered: 01 June 2002Edit or Delete MessageReport This Post
Ive heard this issue before on many different configurations (two tank, on tank, blending etc.)
first thing to do to eleminate some possibilities is to use up your tank and start filling with diesel untill the whole system is nothing but diesel. If problem still exist then you've narrowed the issue down to something beside alternative fuels.
_________________________
Location: North Tx | Registered: 23 November 2002Edit or Delete MessageReport This Post
Nick,
I wish I could help..but I would need more info and will be leaving for a week in the backwoods on Teus. I suggest you take the above advice and turn off your line heaters and heated filter when you switch to pure diesel. This will help you isolate the problem.
Dana
दान
danalinscott@yahoo.com
Location: Central MN..Brrrrrr! | Registered: 06 November 2001Edit or Delete MessageReport This Post
Closed Topic Closed
