Biodiesel & SVO Home
Biodiesel & SVO Forums
General SVO Discussion
Help! my coolant won't flow!
Topic Closed|
Just a oouple thoughts...
1. Is it possible that you actually T'd in on the wrong side of the heater core? 2. Sooner or later you may want to consider a metal line in the interior of the HIH. There have been some reports of PEX not being quite up to the task over the long haul. Good luck. Charlie 2000 Excursion 7.3L Running VO |
I had to install an auxillary pump on my veggie system on my benz, my food service salesman had to install one on his too. I hear reports of people having great success without the pump but I haven't had any luck yet. I even had a new water pump on my benz and it still wouldn't push the coolant throught the veggie system. I didn't have a problem with mine running down the road but in town going slow or idling behind the pizza shop it would cool right down to nothing.
86 F250 veggie since May 2005 25,000 miles and counting 78 Benz 300D converted Feb 2006 2,500 miles and no longer counting 92 F250 converted on May 2,2005 14 000 miles and counting 81 rabbitt 84 benz 300d |
It can be reall PITA to burp the air from the cooling system of the 616 and 617 engine. I bet that is the problem.
Go to http://www.mercedesshop.com/shopforum/forumdisplay.php?f=15 and do a search using "burping, burp, Coolant, hose" Use the fill in box that says something like not all words have to be present. _________________________ If you believe you can't YOUR RIGHT; But equally so.... if you believe you can, YOUR RIGHT as well. |
member 2008 Sponsor |
I have heard it's a pain to get a Benz to flow, so I put in a FPHE and used full sized 5/8" hose to feed it. It flows well, but the length of hose to and from is pretty short, not all the way to the tank and back like yours.
1985 Mercedes 300D, sold, Heat exchanger and injector line heaters, all single tank. 1996 Suburban, 2 tank conversion. 1997 E300D awaiting conversion |
You could install somewhere in there at a high point a temporary RV water pump? Once it all seems to be working right take the pump out. Then you only got that small amount of air from removing the pump to deal with?
Pizzaman, Where is the MB aux. water pump in the system anyway? _________________________ If you believe you can't YOUR RIGHT; But equally so.... if you believe you can, YOUR RIGHT as well. |
OK... spent the day messing with this problem. The fix was one of 2 things. I installed bigger fittings on my HIH tees so more coolant would flow. (3/4" instead of 1/2") then gave the whole system a reverse "enema" with a garden hose hooked up at the input side of the SVO heating system. I let the hose run with the reservoir cap off until all the gurgling stopped. I suspect it was an air in the lines problem all along, more-so than the new fittings, but it can't hurt. Thanks for all the replies. If it wasn't for this forum and others like it, I would have never tried these coversions.
now I got mostly water in my cooling system.... thank goodness it's summer! gotta pull out that old anti-freeze tester to see. where the heck did I put that.... |
Jeep,
I put it on the end of the vegoil system where the coolant would be coldest. Just before the t back into the coolant system at the water pump. 86 F250 veggie since May 2005 25,000 miles and counting 78 Benz 300D converted Feb 2006 2,500 miles and no longer counting 92 F250 converted on May 2,2005 14 000 miles and counting 81 rabbitt 84 benz 300d |
John,
Would you be able to post photos or schematics of the conversion on your 190D? I'm getting ready to convert my 1984 190D 2.2, and I'd love to see what you came up with. Thanks, Jason 1984 Mercedes 190D 2.2 (not yet converted) |
I had a very similar problem getting my coolant to flow nice and hot all the way back to my veggie tank in the trunk. I installed a 12 volt RV aux. water pump in the trunk and I have a switch to turn it on on the dash. When the car is heated up and i've been running the pump, the fittings in the trunk are hot to the touch! This is with 20 feet of hose to the trunk and 20 back to the tee into the coolant line. so it's a long stretch, the l in sdl stands for long wheel base! My car is looooooooong. This has worked extremely well for getting very hot coolant all the way back there. otherwise the coolant will take the path of least resistance through the heater core or straight into the radiator and never even think about making the trip bake to my trunk.
'87 MBZ 300sdl HIH, Goldenrod heated, dedicated veggie filter, Vegtherm Inline Fuel Heater, two solenoid set up with looped veggie return before the heater |
Topic Closed
