Sponsors    Home    Forums  Hop To Forum Categories  General SVO Discussion    FPHE made in USA
Don't need a big one, but DudaDiesel is Chinese stuff. Any thoughts?
Mike Goodman
High Point, NC
83 MB 300SD
81 Rabbit Caddy Truck
Diesel Craft CF proces
Location: High Point, NC | Registered: 30 September 2005Reply With QuoteEdit or Delete MessageReport This Post
Surplus Center used to offer a US-made, welded steel unit, original meant for a tractor. About $20. Brake line fittings fit the in/out ports, and the coolant ports are pipe thread if I recall right.
I never did find a place to mount it in my VW. Space under the hood is a premium.
JohnO
technically Taiwanese...
2001 Ford Excursion 7.3l PSD
1984 Ford F-250 6.9l IDI
Over 18,000 miles on WVO.
^ I agree
Running on
And yes, there is a difference.
And yes I will purchase American every time I get a chance if there is a comparable facsimile, as easily available - even if it costs more (within reason e.g. paid $69.00 for a FPHE from Duda - if a similar one made in the US had been available I would have gladly paid up to $100.00 for the same.
What is the URL to the Surplus Center?
Registered: 12 April 2006Reply With QuoteEdit or Delete MessageReport This Post
Ones I use:
Made in USA:
http://www.flatplate.com/
copper and nickel brazed, 3X8" x 10 - 50 plates
I might even have a spare 20 plate if interested.
Small FPHE:
Easily fits in my VW TDI, 2kW of heat:
http://www.monopoel.de/catalog...her-wt-a8-p-424.html
1-tank Elsbett VW TDI , 115,000 SVO miles.
Location: Ct,USA | Registered: 19 November 2001Reply With QuoteEdit or Delete MessageReport This Post
Where woulod one be able to purchase these FPHEs retail?
Purchasing info
The A8 WT can be bought from the site linked. monopoel.de.
Use Google translate web page to fill out info. Shipping will be steep from Germany.
But I know of no other place that sells the small FPHE.
You should be able to buy direct from Flat Plate. I did and bought 3 units.
I just emailed and phoned their sales dept, iirc. Just get a 3"x10" 10or 11? plate copper brazed.
Should be around $120, iirc.
Sounds like a good opportunity for someone to become a US distributor.
Originally posted by jburke:
Purchasing info
Purchasing info
I have a couple made in U.S.A. FPHE's.
Both are 3" x 10" with standard NPT fittings
Both are new unused.
#1 is a copper brazed 20 plate made by I.T.T Standard in Buffalo New York.
Cost is $119.
#2 is a nickel brazed 30 plate made by Flat Plate Inc of Pennsylvania.
Cost is $199.
Send me a PM if interested.
johnO
I got a 10 plater to fit in the air inlet on the right side of the hood latch, 15 was too fat. Photos of it on another car are in Omars FPHE thread
Merk
03 TDI WVO Converted. 12 gal marine tank in trunk w/copper heat excahnger no intank connections, coolant heated copper coiled fuel filter, HIH, two 3 port fuel valves
Location: Etna, NH | Registered: 19 January 2006Reply With QuoteEdit or Delete MessageReport This Post
