Sponsors    Biodiesel & SVO Home    Biodiesel & SVO Forums  Hop To Forum Categories  General SVO Discussion    Transfer pumps?
Any advice on what type 12v transfer pumps are good to use from experience?
bearring
Location: ga | Registered: 17 July 2008Reply With QuoteEdit or Delete MessageReport This Post
I like the Fill-rite 1604. See: Recommend a pump for moving oil
I have the FR 1604 and the FR 1612 10gpm.
The 1604 shakes like a mofo and is very slow, but can handle thick oil, and is quiet comparatively.
The 1612 pumps at a good speed, is somewhat noisy and less expensive. Tuthill tech. says that this pump is not made for veggie oil, but the description says it can handle light oils. Lots of folks use this pump for wvo, but I'm not certain of it's longevity.
Location: San Francisco | Registered: 20 February 2008Reply With QuoteEdit or Delete MessageReport This Post
I've been using the Fill-Rite 1604 for about 2+ years to push pre-filtered oil through a 10 micron Goldenrod, and it's still going strong. It's not terribly fast, but it certainly is robust.
94 6.5TD Dually Suburban
Location: Rockville, MD | Registered: 20 August 2006Reply With QuoteEdit or Delete MessageReport This Post
I use a http://www.harborfreight.com/cpi/ctaf/displayitem.taf?Itemnumber=9576
but only on clean oil from carboy to tank, not for filtering.
Merk
03 TDI WVO Converted. 12 gal marine tank in trunk w/copper heat excahnger no intank connections, coolant heated copper coiled fuel filter, HIH, two 3 port fuel valves
Location: Etna, NH | Registered: 19 January 2006Reply With QuoteEdit or Delete MessageReport This Post
I use the same one as merc, cant beat the price, I do have a harbor frieght 40 minutes from my house that makes it nice.
Registered: 17 August 2008Reply With QuoteEdit or Delete MessageReport This Post
After burning out my new Northern Tuthill/Fill-rite 1612 after 15 minutes I took the time to call there rep. It definetly is not designed to pump wvo. I have since been settling for the little Flotec at 70 bucks until I can hook up a gear pump. I melted the 30amp fuse that is in line. I passed on the 1604 as it did not pump as fast. Oh well.
Registered: 27 March 2008Reply With QuoteEdit or Delete MessageReport This Post
Yeah, my fuse just melted on my Fill/Rite 1604. I'll be sending it back...
The fuse is also starting to melt on the Fill Rite 1612. WTF??
Perhaps I can splice in some heavier gauge wires to handle the extra stress of WVO. The 1612 was made for oil though...
This message has been edited. Last edited by: vegobsession,
I would suggest using a modified SBC 350 oil pump coupled to a powerful 12volt motor
Location: texas | Registered: 28 February 2008Reply With QuoteEdit or Delete MessageReport This Post
