Sponsors    Biodiesel & SVO Home    Biodiesel & SVO Forums  Hop To Forum Categories  General SVO Discussion    How does a centrifuge work
I understand spinning at high speeds, centrifugal force, etc., but I'm stuck on how the centrifuge actually captures the junk. ???
Seeing Wenchris's excellent thread about making his own centrifuge leaves me wondering where the junk get's trapped? From other things I've seen it looks like the junk just adheres to the inside of the centrifuge - is this right? And if so, then how do you know that you don't have "overflow" of junk moving with the oil into your clean tank?
I would love to copy Wenchris's model with an old router that I have sitting around, but I've got to get my mind around it first...
Thanks!
Dan
99.5 Jetta TDI, Elsbett single-tank (incl. modified injectors & glow plugs, FPHE, heated filters), running on WVO/Diesel blend
Location: Oregon | Registered: 19 March 2008Reply With QuoteEdit or Delete MessageReport This Post
no real way of knowing if you are apssing junk, other than getting used to knowing how long it takes to fill, and cleaning it before you get to that point, trial and error
hence the contineous cycling of a oil spun(dieselcraft or such) and doing several passes works well, and always have a polishing or finishing filter as youre backup on the way to the tank of youre vehicle
96 6.5td with homebuilt veg conversion
centrifuge setup
about 20.000 kms on oil.
Location: Edmonton Alberta | Registered: 30 May 2008Reply With QuoteEdit or Delete MessageReport This Post
www.simplecentrifuge.com had a video of their centrifuge in action.
In my Acme I can see the output clarity in my clear 1/2" hose, but for water I have to do a HPT after adding each new heated 3 gal batch to my 5 gal supply cooler.
I also use a 10 mic polishing filter.
Mike
Registered: 08 August 2006Reply With QuoteEdit or Delete MessageReport This Post
