air bubbles or plugged filter come to mind
Regards, Scott 1987 Mercedes 300D - 2 tank VO |
Scott - Starting to plug the filter was my original thought (filter is just starting to pull 3-5mmHg vacuum when climbing hills first thing in the am), but I thought I was just switching over prematurely now that it's getting colder.
Air bubbles? Any idea how this happens? thanks again as always peace and love billyO '93 Dodge 250 - 5.9L cummins, 275K w/40K VO miles so far. Cold-upflow settling with gravity feed through 10 and 3 micron spin-on filters (which have not needed changing for 500+ gal and counting. Hooray for cold-upflow settling! Thanks john galt! ) |
Billy, is your onboard filter heated?
1984 Volvo 240 Elsbett 1 tank/glow plugs/injector nozzles/FPHE/fuel filter heater system, block heater, ILH 20%Kero, 80%WVO winter blend |
240- If by onboard filter you mean my VO filter, then yes, it's coolant wrapped, if you're talking about the diesel filter, then no. I don't think the filter was the problem because when the engine started to stall I didn't notice my vacuum gauge indicate that I was pulling much (if any) of a vacuum.
thanks for the help as always peace and love billyO '93 Dodge 250 - 5.9L cummins, 275K w/40K VO miles so far. Cold-upflow settling with gravity feed through 10 and 3 micron spin-on filters (which have not needed changing for 500+ gal and counting. Hooray for cold-upflow settling! Thanks john galt! ) |
How large is your veg tank and where is the fuel pickup located in that tank. I have had problems with pulling a slug of air into the fuel pickup during braking, acceleration, or on sharp turns when the fuel in my 2ft X 2ft X 4 ft 100 gallon bed mounted farm fuel transport tank gets low. I am now reworking one of these tanks so that the fuel will be drawn from about a half gallon sump in the bottom rear center of the tank to try and eliminate this problem.
Hey all. Had the problem again today and found out that I have a leaky fitting between the VO filter and the looped return T (I saw bubbles). It seems that I'm sucking air, enough to cause problems when stopping for brief periods while running on VO, but not enough to cause the engine to die when running at highway speeds. Looks like I've finally got the motivation to change my VO filter set-up like I've been planning. I'll try to post before and after photos if interested.
Thanks again for all the suggestions and help. as always peace and love billyO '93 Dodge 250 - 5.9L cummins, 275K w/40K VO miles so far. Cold-upflow settling with gravity feed through 10 and 3 micron spin-on filters (which have not needed changing for 500+ gal and counting. Hooray for cold-upflow settling! Thanks john galt! ) |
When my system was first in and plumbed to pull fuel through the filters, I would get an air buildup in the diesel filter head that caused stumble / stalled when turning a hard left corner, at street speeds. The fuel level tilted and the air pocket dipped lower on one side and the pump sucked a big gulp of air... stumble. At steady speeds level street levels evened out and the pump would be constantly sipping a good mix of fuel and air, not what you want, but enough fuel to not cause the problem. All those bubbles, ah, the bubbles, the nightmare of pulling fuel... it's much better to push liquid fuels. So all got changed when I re-did the plumbing to push fuel through the filters. All bubbles have gone away, and stayed away.
Scott - Thanks for the post, but my system is a pusher too. The bubbles are VO leaking out when the system is pressureized.
If the leak is in a pressurized area, you can't be sucking air, you simply get a VO drip. YVORMV - Your veg. oil results may vary, see www.burnveg.com/forum 95 Dodge Cummins 4x4 +87 300TD wagon Running on 2 tank WVO, 81 Mercedes 300D on V80/D20 blend Low fossil house- 100% solar/wind power, 90% solar heated. |
SunWizard - Yes, I agree that a drip would happen when the system is pressurized, but when running on diesel with a looped return and a leak, there would be no pressure in the system anymore, and the fuel running through the loop would pull a small vaccum from the VO line that runs between the VO filter and the looped return T.
