The AERA rebuilt-engine break-in procedure can be found here. It includes information on oil designations. It isn't specific to Mercedes diesels, but has enough explainatory information to make an informed decision.
I've worked on a few engines that had not had their headbolts retorqued. That is an aspect that hasn't been mentioned in this discussion, but is critical for most engines after running for a few hours. Cheers, JohnO |
I've replaced a few mono-torque head gaskets on older engines, both my own and customer's. I've also replaced quite a few blown headgaskets that were supposed to be retorqued, but weren't due to lazyness and wishful thinking. They left me with the impression that they may work ok on modern car engines, but may not work with older engines. The easy way to tell is to recheck the torque after a while - if the head bolts have loosened, then they need retorqued. If they are still at spec, then they don't. Why wait until a head gasket fails? It's easy enough to check the torque of at least one or two headbolts on any engine. Many engines require removal of the cam or other complication to reach all of the headbolts, but that shouldn't prevent you from checking the torque on headbolts that aren't blocked by the cam. If you discover that the headbolt is dramatically lower than spec torque, then it's worth the additional effort to gain access to them all.
hheynow - you didn't mention how old your 300D is, nor if the head gasket was the kind that is advertised as not needing to be retorqued. Do you know if it is? Is this too far off-topic? Retorquing headbolts isn't related to WVO use, but rather to care of rebuilt engines. A side comment - My Mazda diesel headbolts had never been retorqued since leaving the factory. The engine ran just fine at over 200,000 miles. I checked the torque and it was only a little more than 50% of spec. I retorqued the headbolts and readjusted the valves. Nothing at all seemed to have changed, but the mazdadiesel discussion group believes this helps bump up compression a little. They might be right. Cheers, JohnO |
Seems Risky. Unless it was leaking, I would have let it be. What was your method? Remove bolt, clean/oil/retorque? (One by one)? S. Caxambu |
Nope, didn't remove the bolts (different engines have different rules) - this is from the shop manual - Back the bolt off 1/4 turn, then torque to spec in one smooth motion. Mazda 2200 diesel engines don't use "stretch" bolts like VW and some others. Anyone know what Mercedes use?
The Mazda is a pushrod engine, so compressing the head gasket decreases valve clearance. An overhead cam engine (e.g. Mercedes) won't have that problem. Cheers, JohnO |
1500 miles was my rule of thumb and it's worked for 4 cyl. 5 a little longer maybe 2k max though and the rings should be seated. Shame only Elsbett seems to have a handle on Diesel's VO sealing rings. Perhaps a wider groove and a fatter ring would seat more properly in VO. But in Lyle Cummin's book Diesel's Engine they talk a lot about the failure of rings in the beginning of Rudy Diesel's work. Though it seems by the time he was using VO he had a stable engine design so it makes me wonder how much work it would be to widen the grooves and fatten the rings - boring the chambers and grooving the pistons - I figure on a bored block it's only the bare min you have to keep to diesel. Save your oil - Fuel the planet Dodge TD50 2.3L '83 HP injectors SVO; D#2/BIO mix main tank Greasecar 2 tank heated filters/ Racor HE/ dual FPHE (31plates total) Fattywagon customized extra long single heater (15A) relayed on toggle. 120 gal saddle WVO fuel tank settling filtration. Graco blue devil transfer pump DC OC20 80psi PS pump 1/4hp 1725rpm Westinghouse motor |
Muzak I'm delighted you didn't read me the riot act for not getting a rebuilt 617.952 turbo.
______________________________________ '97 Ford F-350 7.3L PSD - Plant Drive kit '84 Mercedes Euro 300D NA - Custom two-tank Running on vegoil and biodiesel since May 2006 |
