What are some good brands of filters and sites to get them? thanks Big Grin
bearring
Location: ga | Registered: 17 July 2008Reply With QuoteEdit or Delete MessageReport This Post
Do you mean for prefiltering, or for an on-board filter? Try using the search function hear and at burnveg.com once you have define your term more clearly. There is a lot of info already posted in both sites.
1984 Volvo 240
Elsbett 1 tank/glow plugs/injector nozzles/FPHE/fuel filter heater system, block heater, ILH
20%Kero, 80%WVO winter blend
Location: New Jersey | Registered: 09 August 2006Reply With QuoteEdit or Delete MessageReport This Post
pre filtering. sorry
bearring
The info you are looking for is probably in the VO/PO fuel processing section at: http://www.websitetoolbox.com/tool/mb/voconversionbasics
Indexed so it's easy to find.
Dana
दान
danalinscott@yahoo.com
we still have some 1 micron filter bags here are a few links to read if you have time
good luck
Omar
www.omarsales.com
Flat Plate Heat Exchanger (FPHE) installs
http://biodiesel.infopop.cc/eve/forums/a/tpc/f/159605551/m/6421006031
wvo filter bag ideas and waste veggie oil filtering http://biodiesel.infopop.cc/eve/forums/a/tpc/f/159605551/m/6961060812
heated waste oil filter ideas http://biodiesel.infopop.cc/eve/forums/a/tpc/f/159605551/m/7521042961
wvo (waste veggie oil) tank ideas http://biodiesel.infopop.cc/eve/forums/a/tpc/f/15960555...591014102#7591014102
