Biodiesel & SVO Home
Biodiesel & SVO Forums
General SVO Discussion
Gravity Filtering in a 5 micron felt bag, will it flow?
Topic Closed|
I've had no trouble getting oil to gravity flow through 5 micron filter felt I get from Mcmaster. I've always supported my bag instead of letting it hang. I don't do a whole lot at one time so never kept track of flow rate. Just had a thought, if you suspended the bags in 55 drum with support, could you just upend the full water bottles in the sock and that way not have to stand around as they filtered? I could see being able to do 3 water bottles set up at one time with 3 supported sock filters. At the moment I have a 25 micron inside the 5 micron bag thats filtered for a while.
86 300SDL 83 240D Euro sold 81 VW Rabbit sold |
member 2008 Sponsor |
At room temperatures and if you have any hydrogenated oils present, the 5 micron bag will clog in just a few gallons. Heating to 100 degrees F really helps.
I prefer to do a stepped filtration. Rather than going right to the 5 micron, I go through 100, 50, 25, 10 and finally 5 micron. Yes, that's 5 filters but I find I can filter way more than 5 times the oil as compared to just one filter. Todd 2002 F-250, 7.3l PSD on grease since 2004 |
My setup is like the one you have planned except I have 4 holes on top of the drum.
If the oil is well settled, I can continuosly pour 5 cubies thru 4 filters before I have to wait. If you are patient you can run close to 100 gallons thru a filter. What I do is line the filter w/ old clothes. The filtering is slower but the filters last 3X as long. I have filtered oil down to 32F using this method so at 70F you should have no flow issues. |
I put a 5 gallon water jug in the bungs and cut a 6" round hole in the bottoms. I suspend the sock filters in the water jug which empty into the 55 gallon drum. I have a wooden stake goin thru the handles of the jugs so that they wont tip. I can pour about 1 cubie thru 3 of these filters in one shot. The reason for the 5 gallon jugs is that I get almost 50+gallons into the barrel. If you cut the 6 inch holes in the top and then hang the filters you lose like 20 gallons of storage in the drum. I take a t-shirt filter which I suspend in the sock filter and when the gummys clog it I just take it out and throw it away. I am getting about 200gallons thru this setup. I am a blender and I just take the final product and add 10% kero to it and I go. I am in so FL so heat i do not use for now.
I have gravity fed through 2 x 1 micron 4" filters. If the oil is well settled, it flows slowly but can usually run 20 gallons of oil through in 20-30 minutes.
jake ---------------------------- '99 Benz e300d (SVO conversion underway) '87 Samurai LWB - parts hauler & mule (ACME VW diesel kit, HoH, Pollak) ***Garage full of VW 1.6 + 1.9 bits... for sale!*** |
Hi Mark, 1. Yes. 2. I'm guessing an hour or less, from full to empty filter, depending on temp and how dirty the filter is, and how dirty the oil is. I have 4 bags, which I can get about a cubie in, then I go away and do another one later. When filters were new, it would flow pretty quickly. 3. Yes, but slower. I do the same thing. Pour slowly and don't pour the crap oil through, as you know... Cheers 1993 GMC Sierra 6.5L TD converted 6/19/07. 2 tank, heated pickup, HIH, coolant HE, electric and coolant heated filter. "Blend Loop" gradual switchover. Running great with 10,000+ miles 1984 GMC Soyburban 6.2L Died 6/2007, broken crankshaft. ~25,000 WVO miles |
I put layer four bags (25, 10, 5, 1) and let in hang thru a 7" hole in my drum. Fill 5 gal water bottle with oil and flip over and let it flow. filters at a decent rate as long as you settle for a few days first.
1983 Holiday Rambler 6.2 Banks TD 1987 Mercedes 300TDT 1984 Isuzu P'up 4x4 diesel 1983 Maxima wagon LD28 1985 D50 Ram 2.3 TD 1984 Isuzu P'up longbed diesel |
Thanks, guys!
I tried it last weekend with a combination 10 - 5 double layer bag from McMaster, an the flow rate was impressive. I see how you can go down to 2 micron and still have a decent flow rate. I am truly impressed: Still a little skeptical that any filtering actually took place, but I felt good enough to put it in my vehicle. I made about 5 gallons, and still flowing like there wasnt much resistance at all. P.S. my oil was well settled. 1983 Mercedes 300CD oil is oil... but fresher is better. VO+Car= (a beautiful thing) |
Currently my oil temperatures are around 10°C. If I have oil without any high melting point oil, I can pour it thru my single 5 micron, as fast as I can refill the bucket from the collection drum.
As soon as a bit of high melting point oil accumulates on the filter bag, the flow reduced rapidly. At the present, my bag filter is half full of high MP oils and it has taken me 5 days to filter 25 litres of oil. When it is nearly full, I will remove the material liner, empty it into a container for a friend to make biodiesel from, wash it and put it back into use. I have done this at least ten times since I last washed the filter bag. I have a 1 micron filter bag which I treat in the same manner and which has a similar flow when high MP oils are present. "Fatmobile 3" '84 MB300D Silver/Grey with dark blue interior. 290kkm My car - 2 tank UCO conversion working well. 22 000 km so far on UCO "Josephine" '82 MB300D White with Palamino MBtex interior. 385kkm Wife's car. 20 000km on UCO blends. "Elizabeth" '81 MB 280E Good body now re-engined as a 300D with the engine from the '79 300D.70 litre UCO tank, 2 pollacks switch FP, filters and IP between Start and UCO tanks. '79 300D poor body (donor & parts) "Fatmobile 2" '80 MB300D White with dark Blue interior 230kkm (My first MB) - 5000 km on biodiesel / UCO blend - Found new owner (Sold in 2004). "Fatmobile" a '90 Mazda 2 litre diesel on UCO with biodiesel start/purge. - SOLD in Dec 2003 after 40 000km on UCO. |
When I first thought about filter bags, the image in my mind of big messy bags of oil hanging from my cealing turned me off. But, when I realized that they weren't as big as I thought, and that you could hang them inside of a container like a barrel, bucket etc, I tried it, and couldn't be happier. This seems way better than what I was doing before (pumping through water filters). Faster, simpler, and just working out better for me.
Topic Closed
