Biodiesel & SVO Home
Biodiesel & SVO Forums
General SVO Discussion
What metals can be used around WVO?|
Congrats Gerry! It seems that mild steel can be fine. I would guess that what Dana has stated about water, etc. in the oil could be the problem.
I am anal only to the point where my wallet can take it.
LOLOLOL Chaz Pix of my CF- http://s58.photobucket.com/albums/g279/Skulptor/Centrifuge/ 1973 GMC bus w/8V71 Detroit Fuel oil furnace converted Passive solar underground home at www.amstudio.us |
Diesel in Seattle $3.69 a gallon, on fill-up in my truck $92.00
One fill-up in my bus $553.00 How much was that tank again? |
Ummmm, HDPE tanks can only have efittings added by plastic welding, most producers will install any fittings you like for a few dollars each, there is no need to butch up a good tank when the vendors will install what you like for less than a cheeseburger. Miled steel tank shave been found to accellerate polymerization by most users, FN74, Brian Miller, etc. I like the links to that other website though, it is almost like a forum but there only seems to be one poster. Is it a private forum with one member? Can others post there? I hear the moderator just deletes everything others post, is that true??? |
I am one of 218 member posters and have never been "deleted" or moderated, so I would say, you have been misinformed. Though your argument is very clever, I don't think it will lead to the results you desire. gandhi |
member 2008 Sponsor |
Actually there are several methods to add fittings other than welding. I am currently on a weeklong phase one fleet conversion (mechanic training) and the workdays run to ovver 14 hours. If anyone is interested in more info on this I will try to provide it when timer permits. The conversion basics site is intended as an information archive...though it does have the capacity for individuals to post if they wish. This message has been edited. Last edited by: Shaun, Dana दान danalinscott@yahoo.com http://vegoilconversions.netfirms.com/ VegOil Conversions by Dana Linscott- VO Conversion Consultation for large and small trucks, VO fuel related businesses, and co-generation(power/heat)projects, |
I just noticed that "journeytoforever' lists POR15 as a suitable coating to withstand biodiesel inside the processors:
http://journeytoforever.org/biofuel_supply.html#rust I emailed to ask if they are using standard POR15, or the POR15 Tank Sealer jake ---------------------------- '99 Benz e300d (SVO conversion underway) '87 Samurai LWB - parts hauler & mule (ACME VW diesel kit, HoH, Pollak) ***Garage full of VW 1.6 + 1.9 bits... for sale!*** |
I used the front stock tank in my 1994 F250 for a while and had polymerization issues which after about 2-3 so years (100% WVO), resulted in rapid filter clogging and possible IP damage issues. I have changed to a plastic tank for WVO. I recommend using aluminum or plastic tanks for WVO . I wonder what it would look like if I had been using WVO /Rug/ or diesel blend instead of 100% WVO ?
BTW - Direct fit poly tanks are sold by J.C. Whitney ( made by www.mtscompany.com ). As stated earlier , avoid copper and don't use any zinc containing components - http://biodiesel.infopop.cc/eve/forums/a/tpc/f/15960555...361055602#6361055602 Some tank coatings may be OK with WVO but here is one case where POR15 did not work - http://www.frybrid.com/forum/showthread.php?t=5566 This message has been edited. Last edited by: rkpatt, 1994 F250 IDI 7.3 NA E4OD |
What water content (PPM) was in your veggie, RK?
The pre-filtered and dewatered oil was hot pan tested be before in was pump into the tank . However, the vehicle sits for weeks at a time with only a partial tank of WVO . I periodically drained a about 1/2 gal form a bung mounted of on the bottom and never saw any free water but I suspect that it did pick up some moisture from condensation ("rewatered "). Maybe a desiccant hydraulic tank breather aka tnk vent dryer, would have helped - http://www.agmcontainer.com/agm_main...n.htm?utm_id=9 , http://198.170.245.162/catalogs/SentryCata.pdf . Maybe install one of those or a DIY version on tank vent line or WVO storage tank to address condensation issues.
air may have something to do with it. Air driers may not really provide much difference. Maybe just provide an access port for regular cleaning? what you think?
well i saw a little in this thread about fuel tanks. I did not read the whole thread...
but i coated my steel tank on my 86 chevy with a PPG epoxy industrial floor coating that i had left over from my garage. I coated the tank over 3 months ago and it working great. I cant find my thread about doing it......wheres the search at? Oh....i found chevy side tanks at jcwhitney now.....wish i would have seen that.....i wouldnt have screwed around cleaning then coating my steel one. 86 k10 shortbox 6.5L turbo rollin on 39.5x18 16.5 M/T Baja Belted |
https://www.greenroadenergy.com/images/vegetableoilasfuel.pdf
updated link might want to read vegetable oil as fuel by Joe Beatty good luck Omar www.omarsales.com |
I'm not trying to take sides in the steel versus aluminum debate, but I can't help wondering whether Brains' advice about adding a cleaning access port to mild steel tanks would actually be better than using aluminum tanks. My reason for considering this is that although it takes aluminum tanks "twice as long for the oil to polymerize" than oil in mild steel vessels, I'm wondering whether it's better to have a tank metal that makes skin, rather than a metal tank that makes filter plugging/free floating vegpoly particles? Assuming it took about an hour, would an annual or semi-annual steel tank scraping be more money efficient than changing plugged fuel filters when they eventually do get plugged with small particles of vegpoly? Are vegpoly particles bobbing around in a 1/2 full mild steel tank more likely to stay suspended or more likely to adhere to the vegpoly caked on the steel tank walls? If they are more likely to cling to the walls, then maybe it's better to let them form chicken skin and then srape the goop off every so often. Again, I'm not chosing sides, I'm only wondering out loud. |
In my processing shed the pure VO exposed to air will polymerize, the VO-D1 blend does not, and the new VO-D1-jetB blend does not either. jetB is a kero-naphtha mix. |
What ratio in the blend? |
