Sponsors    Biodiesel and SVO Forums Home    Forums  Hop To Forum Categories  Straight Vegetable Oil (SVO) as fuel  Hop To Forums  General SVO Discussion    Can I leave power to my Walbro FRB-5 pump...
Even when I am not using it?
I had this same pump on my old single tank Mercedes to boost the WVO to the mechanical pump, but that was a single tank system, so the pump ran all the time--I just had it switched to my ignition. It's an "on demand" reciprocating pump, so it ran only fast enough to maintain pressure (8-11 psi). When I had it looped, you could hear it clicking very slowly--and when I purged to the tank, it would speed up.
My question is this--I have a 7.3 Excursion, and I would like to use the pump to assist the stock pump, and run a positive pressure to help eliminate vacuum pulling in air. When running on diesel, the pump would have no demand. If I simply wired it to a switched circuit, it would receive power whenever the key is on--given it is an "on-demand" pump, would it shorted its life if it had power when the WVO was not being used? Should I add an extra switch to manually toggle it back and forth when I switch?
Any experience appreciated.
N
2001 Excursion
Stock diesel tank, plus 55 aux WVO tanks from Northern tool. HIH to Raw Power pump (stock pump plumbed parallel as a backup). 30 plate FPHE, 203* tstat, heated canister filter, Thermometer controlled Vegetherm mega in case I ever want to visit Alaska and need a bit of a boost. Mechanical selector and loop valves plumbed into floor left of drivers seat. 249k miles--75k on biodiesel/WVO.
Location: Florida | Registered: May 03, 2012Reply With QuoteReport This Post
I'm thinking I would not add a separate switch, but power it to the switch-over switch...whatever that becomes.
Merk
2016 GMC Canyon, 2.8 4 Cyl Duramax
Location: Etna, NH | Registered: January 19, 2006Reply With QuoteReport This Post
I have mechanical valves plumbed into the floorboard to the left of my driver's seat--so...separate switch will be a complete add on. But definitely thanks for the view and reply.
2001 Excursion
I see, no electric valves...hmmm Yeah so no choice but to wire it up to a switch.
Merk
