Sponsors    Biodiesel and SVO Forums Home    Forums  Hop To Forum Categories  Straight Vegetable Oil (SVO) as fuel  Hop To Forums  General SVO Discussion    Rebuild kits for Walbro pump
Could someone please point me in the right direction to find a rebuild kit for my FRB 5. Would be great if I could find a seller in Canada.
Thanks.
2001 f-350 ext cab 7.3. 04/10 DIY check valve system. 20 plate FPHE,Fass HPFP set at 70 PSI, TIH, Davco 322 filter head with 10 micron spin on filter,150 micron prefilter, Hydraforce purge valve, 60 liter poly tank with hotfox, ss braided hose to heads,, oil temp, pressure & fuel gauges.
Location: Nova Scotia. | Registered: July 26, 2008Reply With QuoteReport This Post
throw it in the trash. these FRB pumps are too weak for veggie.
Sorry thats my experience. I suggest a gerotor style pump, noticeably better.
6.2L GM 1979 K5 blazer -Single tank w/electric preheaters.
Blend =66%WVO, 33% #2 diesel .
4 100watt IP line heaters
custom 160degree 300watt racor 1000 filter heater
polyeurethane 1/2" pickup
other fuel lines flouroelastimers
plastic fuel cell , Mallory 140gph gerotor fuel pump.
OC-50 dieselcraft centrifuge run by SBC gear pump -
Location: texas | Registered: February 28, 2008Reply With QuoteReport This Post
Where would I find one? I would still like to find a rebuild kit for the walbro. I can use it for things.
Nothing like posting in a post that is 5 years old. But I'll give it a chance, I'm having the same issue. Does anyone know if this pump has a rebuild kit?
Thank you,
Michael
Michael R Mullins
Green Conversions
www.austingreenconversions.com
87 MB 300SDL with greasecar kit
VW 98 Jetta TDI with greasecar kit, Installed March 2005. totaled
Location: Austin TX | Registered: August 04, 2004Reply With QuoteReport This Post
they used to sell them however the liability is not worth it is what a company engineer told me over the phone
Registered: September 20, 2015Reply With QuoteReport This Post
