Greetings,
I am new at this and just getting started. This station will cold filter pretty well but it isnt finished. Paint , among other things. We have got a dieselcraft cf and the pump and motor but havent hooked it in yet. We were going to mount the cf to the side of the gray barrel, but as per SunWizard, we will build a stand and "hang" it inside.[ For noise ] This also makes it so I can move the unit to another tank. The whole thing is sectional. Changes are easy, just unstack and replace or remove that section. There are safty chains hanging from the ceiling to prevent falling over and aid in cleaning or changeing. The lowest barrel is heated with propane for now and will be surronded with setteling tanks. The worst will be drained from the bottom of the setteling tanks , then slowly pumped to the top. Gravity flows thru 3 different filter fabrics. Not finished yet. Comments are welcome. Thanks. thymekiller "...the road goes on forever, and the party never ends..." |
http://www.youtube.com/watch?v=AC3_VIak5Lo
this is my youtube video of my setup, just put it up a couple of minutes ago 96 6.5td with homebuilt veg conversion centrifuge setup about 20.000 kms on oil. |
http://s481.photobucket.com/albums/rr177/extremeyoshi230/my%20oil%20setup/
these are the pictures from my setup, still under construction figured i would save the server bandwith and put them up on a free site instead. 96 6.5td with homebuilt veg conversion centrifuge setup about 20.000 kms on oil. |
nice centrifuge setup. Where did you get your filterfuge, ive been trying to find some other cetnrifuges cheaper than the dieselcraft
got my filterfuge about 6 months ago from dieselproducts.com they are in ontario, since i am in canada to it was easier than getting it out of the states 300 bucks canadian with an extra bowl, extra seals and shipping if i am remembering correctly.
