Biodiesel & SVO Home
Biodiesel & SVO Forums
General SVO Discussion
Water Heater in Pipe not working - what am I doing wrong?|
Hello Wade,
Well possibly not is all lost (except for that heater element anyway). Im going to assume from your post that you have it hooked up the heating element to 220V. From my understanding of your post, that seems to be the only error in my opinion you made. If you have some electrical knowledge, hook a new element up to 120V. Now it will heat more slowly, but your element life should last you quite awhile. The reason being is that oil does not have the heat transfer properties that water does, in other words, the element cannot get rid of the heat it produces in oil like it can in water, and the end result is an element that is basically burnt up. Good luck and happy possessing Randy Randy H. |
if the H2o element is up, like in your diagram, there could be an air pocket, resulting in frying the heater.
air is bad. it will cause the element to burn out, and if there is (enough) air, oil, and heat, there will be fire. Be the change you hope to find in this world.-Gandhi |
The water heater element I was using was a 110V element. Do you mean that I should be using a 220V element, but only running it on 110?
Also, would an arrangement like this work better? OIL INPUT FROM PUMP | | | |__ | __| OUTPUT TO OC-20 | | | | HEATER ELEMENT Wade |
Good Morning Wade,
Yes, running a 220v heater element on 110v is exactly what I mean. I use a 5500W/220v low density element in my appleseed prossessor at 110v. (a low density element is alot longer than a high density element of the same wattage, so per inch of heating element it dosent get as hot as a high density element, and the end result is less chance of burn out and/or longer element life). Also as Mobetta described, if air gets trapped around the element, it will burn out. Randy H. |
One more vote that an air pocket killed the element. The same thing happened to me in my first experiment of the sort. Since then I've made sure the lines are clear of air before turning on the element, and all is well. For the sake of safety, I still never run it unmonitored!!
Cheers, John |
member 2008 Sponsor |
Quite possibly. But most 22vac water heater elements powered on 110vac can survive that.
Dana दान danalinscott@yahoo.com http://vegoilconversions.netfirms.com/ VegOil Conversions by Dana Linscott- VO Conversion Consultation for large and small trucks, VO fuel related businesses, co-generation(power/heat)projects, and Conversion Webinars, |
Ok, I changed things around. Water heater element on the bottom (220V 3800W), input on the top, output on the side of the T. It worked GREAT!!
Thanks for the input guys! Wade |
Glad i could help out Wade.
In my opinion thats what everyone is here for, to help each other out, share information and gain knowledge. Peace and happy trails Randy Randy H. |
